    Wunderlist, blank screen when Wunderlist module is added to config.js
    9 Posts 4 Posters 4.9k Views 4 Watching
    • N Offline
      NathTheDude
      @Kimzer Hmmmm, maybe. From the times I have missed/messed up config if normally comes up with something like …missing config.js
      • KimzerK Offline
        Kimzer
        Post some of ur config.js so we can see if there is a problem.
        With the module causing problems in ofcorse.
        • N Offline
          NathTheDude
          @Kimzer Thanks for your quick replies. I deleted the Wunderlist and the enhanced Wunderlist folders/modules. Then created the Wunderlist folder again, then did npm install and this seems to have resolved the issue, must of been a problem with the Module.
          • KimzerK Offline
            Kimzer
            Great, glad u got it working :D
            • ceddirrC Offline
              ceddirr
              Same thing is happening to me, but just installed the enhanced folder.
              npm install is going bad :
              pi@mirror:~/MagicMirror/modules $ npm install
              npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
              npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/node_modules/node_helper/package.json'
              npm WARN modules No description
              npm WARN modules No repository field.
              npm WARN modules No README data
              npm WARN modules No license field.
              Any idea?
              Did you just re install the standard folder instead of the enhanced one to solve your problem, please?
              Thank you for your help!
              Cedric
              randomnoiseR 1 Reply Last reply Reply Quote 0
              • randomnoiseR Offline
                randomnoise @ceddirr
                @ceddirr looks like you’re running npm install from the modules directory, you probably want to cd in to the wunderlist folder (which itself is in modules) then run the npm install
                ceddirrC 1 Reply Last reply Reply Quote 1
                • ceddirrC Offline
                  ceddirr @randomnoise
                  @randomnoise Thank you very much!
                  I didn’t know that, but it makes sense!
                  It is working now =)
