    Resize custom or main modules
    24 Posts 6 Posters 39.4k Views 10 Watching
    • KirAsh4K Offline
      KirAsh4 Moderator
      Those CSS rules will affect all the modules, as all modules use them. If you only want to affect one single module, then you need to change the rules to point to the specific module. Let’s say you want the text smaller on the newsfeed, then you need to look at the actual HTML being created to get the class named being used:
      <div id="module_8_newsfeed" class="module newsfeed newsfeed" style="transition: opacity 1.25s; opacity: 0; position: static;">
        <div class="module-content">
          <div>
            <div class="light small dimmed">ESPN - Top News, 4 minutes ago:</div>
            <div class="bright medium light">Georgia RBs Chubb, Michel still iffy for opener</div>
          </div>
        </div>
      </div>
      Now you can see that the rules that affect the text, 'light small dimmed' and 'bright medium light' are all contained within the main class 'module newsfeed newsfeed' (on the very first line.)
      Using a bit of CSS juju, doing this:
      .newsfeed .medium {
        font-size: 18px;
      … will make the text of the article headline smaller than the default '30px'. And this will only affect the newsfeed module. All the others also using the 'medium' rule will be unaffected.
      • bokifideB Offline
        bokifide
        Awesome! Thanks for explaining that :) I’ll give it a try now.
        • bokifideB Offline
          bokifide
          Hey so I was testing out the custom.css values to see how it affects the magic mirror and I’m not getting any difference for some reason =/.
          Before
          alt text
          The change (changed the px values to be way lower than what was shown in the original paste above)
          alt text
          After the above change
          alt text
          I was hoping changing those values would mean that I could make it look clean enough to not change the size of specific modules, but I seem to still be missing something :( .
          Regards,
          Boki
          • KirAsh4K Offline
            KirAsh4 Moderator
            '.small' affects the calendar, weather forecast modules, and newsfeed sourceTitle
            '.medium' affects the date (only), current weather EXCEPT the temperature display, newsfeed article title
            '.large' affects the time display and temperature from current weather
            I’m sure there are others I’ve missed.
            Those are all 'master' rules, affecting all those modules. If you want to only change a specific module, you have to follow the steps I mentioned above.
            • zombi27Z Offline
              zombi27
              I know it!
              Tried the same yesterday, and found a “bug” :)
              You inserted your code inside the body { } section (like i did), wich is not working…
              Just erase the body { } from the custom.css and paste the code in the empty file :)
              @MichMich, @KirAsh4: Is the body { } section a leftover from an older version maybe?
              MichMichM 1 Reply Last reply Reply Quote 0
              • MichMichM Offline
                MichMich @zombi27
                @zombi27 Nope, it’s an example to show where your CSS must go … ;)
                I think there is a limit in how far we should spoon feed the users. ;)
                • zombi27Z Offline
                  zombi27
                  okay :D The body section confused me too, so maybe it’s better to keep it empty? just a comment “place css code here?”
                  i could send a pull request? would be my first one :D or how could this be done? totally new to github…
                  • bokifideB Offline
                    bokifide
                    ahh… See I was thinking it was a bug as well, I don’t know much about CSS or programming in general, but I’m glad you clarified that part @zombi27 . I had just gone directly to the main.css to modify the values since I couldn’t get the dashboard to reflect the custom.css values :). I’ll give it a try once I get home.
                    Thanks for the help and direction @KirAsh4 @MichMich @zombi27
                    Boki
                    • KirAsh4K Offline
                      KirAsh4 Moderator
                      Yep, that body { ... } rule is just there as an example. A quick search on 'css example' on Google would’ve shown you oodles of examples on syntax, almost to a fault.
                      • MichMichM Offline
                        MichMich
                        The problem if we change that file now (with an explanation text), it would overwrite files from users who modified it if they update …
                        zombi27Z 1 Reply Last reply Reply Quote 0
