    MMM-uber and MMM-lyft
    40 Posts 8 Posters 33.7k Views 7 Watching
    • kalK Offline
      kal @shashank
      @shashank it’s a typo in the documentation but 'POOL' should work.
        shashank @kal
        @kal no luck, still Uber X default
        kalK 1 Reply Last reply Reply Quote 0
        • kalK Offline
          kal @shashank
          @shashank Can you post the mmm-uber portion of your config file? It’s working for me.
          You may want to delete and re-download the repo in your Modules folder. I’ve pushed some changes since the first post.
            shashank @kal
            @kal hi, I deleted and reloaded the modules, still same issue, below my config
            module: ‘MMM-uber’,
            position: ‘top_left’,
            header: ‘Uber (DC)’,
            ride_type: ‘pool’,
            lat: XX.XXXX, // use your exact pickup loaction
            lng: XX.XXXX, // use your exact pickup loaction
            uberServerToken:
            • kalK Offline
              kal @shashank
              @shashank like I mentioned, your ride type needs to be capitalized. Use 'POOL' like shown below. Also, the ride_type: needs to be placed into the config portion. You can put it under the uberServerToken.
              			module: 'MMM-uber',
              			position: 'top_left',
              			header: 'Uber (DC)',
              				uberServerToken: 'your_uberServerToken',
              				ride_type: 'POOL'
              S 3 Replies Last reply Reply Quote 0
                shashank @kal
                @kal said in MMM-uber and MMM-lyft:
                ride_type: 'POOL
                hi, i did the changes now it displays as “POOL in null min”
                module: ‘MMM-uber’,
                lat: xx.xxxx, // use your exact pickup loaction
                lng: xx.xxxx, // use your exact pickup loaction
                uberServerToken: ’ ',
                ride_type: ‘POOL’
                • kalK Offline
                  kal @shashank
                  @shashank That means that no uber pool is available in your area. This is an error case that I haven’t dealt with explicitly.
                  To confirm this is the error, you need to look at the console log. You’ll see the ProcessUber returns ‘Time’ and then an object. Go through the object and look for pool as a ride type. It should look like this:
                  You can also try to order an uber pool on your phone to confirm that one is not available.
                    shashank @kal
                    @kal
                    ok, Thank you , let me check
                      shashank @kal
                      @kal hi, i tried changing the location even then POOL not working, i mobile same location POOL is working
                      • kalK Offline
                        kal @shashank
                        @shashank can you post the log from your console? I want to help you resolve this issue but I need more information.
                        Anything related to uber in your log should be posted. Please post in detail the things that you have tried. Any config file changes, etc.
                        Just saying that it’s not working does not help me help you
                          shashank @kal
                          @kal hi, Earlier i had issues using POOL, mention ride_type: ‘uberPOOL’ , now working fine
                          • kalK Offline
                            kal @shashank
                            @shashank that’s weird…the API calls out ‘POOL’. Do you mind if I ask what country you are in?
                              shashank @kal
                              @kal Singapore
                                Sarb
                                @kal Thank you very much for creating these modules! For some reason I am unable to get both the Uber or Lyft module to return any results. The only thing displayed is their respective logos and “Checking for Uber/Lyft status…” messages. It’s been displaying this for hours now. Is there anything special I need to do once I have registered as a developer and gotten the server tokens?
                                • kalK Offline
                                  kal @Sarb
                                  @Sarb Can you post your config file and log? It sounds like a REST API failure…
                                    Sarb @kal
                                    @kal Please see my config entries below:
                                    		module: 'MMM-uber',
                                    		position: 'top_right',
                                    		header: 'Uber & Lyft',
                                    			lat: <>,
                                    			lng: <>,
                                    			uberServerToken: '<>',
                                    		module: 'MMM-uber',
                                    			lat: <>,
                                    			lng: <>,
                                    			ride_type: 'uberXL',
                                    		module: 'MMM-lyft',
                                    			lat: <>,
                                    			lng: <>,
                                    			clientID: '<>',
                                    			clientSecret: '<>',
                                    Sorry for being such a noob but I am not sure where to pull my log file from. I ran a quick search and I read that it is supposed to be in a folder named pm2 in my pi folder but I do not see a folder with that name (even when showing hidden items). I did however notice this in my console window:
                                    Whoops! There was an uncaught exception…
                                    TypeError: Cannot read property ‘statusCode’ of undefined
                                    at Request._callback (/home/pi/MagicMirror/modules/MMM-lyft/node_helper.js:43:97)
                                    at self.callback (/home/pi/MagicMirror/node_modules/request/request.js:188:22)
                                    at emitOne (events.js:96:13)
                                    at Request.emit (events.js:191:7)
                                    at Auth.basic (/home/pi/MagicMirror/node_modules/request/lib/auth.js:24:18)
                                    at Auth.onRequest (/home/pi/MagicMirror/node_modules/request/lib/auth.js:137:23)
                                    at Request.auth (/home/pi/MagicMirror/node_modules/request/request.js:1360:14)
                                    at Request.init (/home/pi/MagicMirror/node_modules/request/request.js:378:10)
                                    at new Request (/home/pi/MagicMirror/node_modules/request/request.js:130:8)
                                    at request (/home/pi/MagicMirror/node_modules/request/index.js:54:10)
                                    • kalK Offline
                                      kal @Sarb
                                      @Sarb your config looks good, but I want to see your log before I open an issue.
                                      We need to view your JavaScript console. Access the mirror directly or whitelist the IP of another computer to access via a browser. Then, go to https://IP.of.Raspberry.Pi:8080 in Chrome and View>Developer>JavaScript Console.
                                      See this this thread for more info.
                                        Sarb @kal
                                        @kal Please see below:
                                        Filtering for Uber
                                        Filtering for Lyft
                                        • kalK Offline
                                          kal @Sarb
                                          @Sarb Two things:
                                          1. Make sure that your uberServerToken and clientID/clientSecret don’t contain the greater/less than characters in your config (these things: <>). Those are placeholders. For example, if your uberServerToken is abc123 then the line in your config should read uberServerToken: 'abc123', without those characters.
                                          2. If that doesn’t work, can you go into the .js file for uber and un-comment this line. Then post the log. You should be looking for one that says ERROR...
                                            Sarb @kal
                                            @kal
                                            1. I can confirm my uberServerToken and clientID/clientSecret don’t contain the greater/less than characters in my config file. I only used those so I wasn’t displaying them. :)
                                            2. Please see screenshot below:
