27" barn wood frame mirror (Alexa controlled)
6 Posts 5 Posters 5.7k Views 5 Watching
    jfdesgagne
    I built the frame out of old barn wood. I wanted to make it look oldish, so perfect fitting was not needed. I hooked up a 2m led strip using a 12V power supply and some transistors. Everything is controlled through Alexa using IFTTT.
    Watch the vdeo
    Main image
    Side view
    Living room
    Frame
    Frame inside
    Electornic
    Power supply
    Raspberry
      SvenSommer
      Very nicely done!
      What are the rotary switches in the last pictures for?
      Looking for some building inspiration?
      Check out my large, thin and metal framed mirror on robstechlog.com.
      Modules released:
      MMM-GoogleAnalytics
      MMM-GrafanaChart
      MMM-GrafanaGauges
        jfdesgagne
        Thank you.
        To answer your question, there is no rotary switches. The grey things are wire connector to connect the led strip wires to an wire extension.
          anupam
          Congratulation ! Very Nice Work.
          • T Offline
            tonyk86
            Awesome work! I’m planning on building my first smart mirror for my girlfriend. How difficult was this for a person who doesn’t have any programming skills? Also how much was the total cost of this project?
            • G Offline
              goprojojo
              What Alexa module did you use? I’m still failing with setting up voice recognition for my own mirror
