Passing variable from one request to another
8 Posts 2 Posters 3.0k Views 2 Watching
    mongo116 Module Developer
    Hopefully a simple question.
    I am trying to pull data for my heating system, which requires two requests be made. The first request gets the sessionID, and the second logs in using the sessionID and pulls back the JSON data.
    I can see the SessionID in the first request, but how do I have this value available to the second request?
    S 1 Reply Last reply Jul 26, 2017, 2:00 PM Reply Quote 0
      strawberry 3.141 Project Sponsor Module Developer @mongo116
      @mongo116 after the first request you can store the sessionid as a module property and then you can easily access it for your second request. or if you need the sessionid just once you can create another request right after getting the response where you can access the sessionid
        Thanks for the reply. Sorry to be a pain, but any chance of you putting a simple example of both on here.
        S 1 Reply Last reply Jul 26, 2017, 5:16 PM Reply Quote 0
          @mongo116 if you post how you get your session id we can try to help you better
            This is from node_helper.js:
            	request({
            		url: "https://api-prod.bgchprod.info:443/omnia/auth/sessions",
            		headers: {
            				'Content-Type': 'application/vnd.alertme.zoo-6.1+json',
            				'Accept': 'application/vnd.alertme.zoo-6.1+json',
            				'X-Omnia-Client': 'Hive Web Dashboard',
            				'cache-control': "no-cache",
            		method: "POST",
            		body: JSON.stringify(body),
            	}, function (error, response, body) {
            		if (!error && response.statusCode == 200) {
            			var responseJson = JSON.parse(body);
            	request({
            		url: "https://api-prod.bgchprod.info:443/omnia/nodes",
            		headers: {
            				'X-Omnia-Access-Token': ,
            		method: "GET",
            The Session ID is part of the JSON response from the first request (responseJson.sessions[0].sessionId). Session ID needs to be put into the ‘X-Omnia-Access-Token’: , of the second request.
            S 1 Reply Last reply Jul 26, 2017, 8:17 PM Reply Quote 0
              @mongo116 I assume that your code is inside the function getData
              getData: function() {
                request({
                  headers: {
                  method: "POST",
                    // nested request after successfully obtaining the session id
                    request({
                      headers: {
                        'X-Omnia-Access-Token': responseJson.sessions[0].sessionId,
                      method: "GET",
                        // the required data
                        var data = JSON.parse(body);
              M 1 Reply Last reply Jul 26, 2017, 9:03 PM Reply Quote 1
                mongo116 Module Developer @strawberry 3.141
                @strawberry-3.141 Fantastic - just needed to be nested. That now works like a charm - thank you so much :)
                S 1 Reply Last reply Jul 27, 2017, 8:12 AM Reply Quote 0
                  @mongo116 the callback of the request gets executed async, so you can’t put them just next to each other. Because then the second request would be fired before the first one got his respond, by nesting you can ensure that the first request got a respond.
