    Change background image based on time of day
    backgroundtimeofday
    18 Posts 5 Posters 12.9k Views 5 Watching
    • I
      I_Am_Anthony
      As the title suggests, is there a way to change the background image based on the current time of day in the css file? I’d assume there’s a way to work something into a module, but it’s likely more complicated, especially if I want it to be full screen. Perhaps I need to add a function into one of the .js files to pull from a different css file?
      I’ve found this code for adding a backgrund image from another post by @Wilco89 Thanks btw.
      body {
          background-image: url("paper.gif");
          background-color: #cccccc;
      I’m making a magic mirror for a friend. It will have a standard background image that displays most of the time, but I want to change it to a picture of the evil girl from the ring during late night hours. Should be afun little surprise eventually.
      Thanks.
        j.e.f.f Project Sponsor Module Developer @I_Am_Anthony
        @I_Am_Anthony You won’t be able to do this in CSS alone. CSS isn’t a programming language so you can’t put logic into it to, say, change a style based on time of day.
        However, if you’re willing to get your hands dirty, this would be a fairly trivial module to write. This would be a great starter project for anyone who wants to build their own first module. I believe there is currently a module that puts animated snow on your mirror as a background graphic. I’d take a look at that to get started.
        • I
          I_Am_Anthony
          So, based on your recommendation, I think I’ll implement a simple module that switches between style sheets; each with a different background image. Thoughts?
          Something like this:
          Module.register("background", {
              getStyles: function() {
              var currentTime = new Date().getHours();
              if (currentTime > 5 && currentTime < 23 ){
                return ["normalBackground.css"];
              else {
                return ["scaryBackground.css"];
          Then the different css sheets would be:
          \\normalBackground.css
          body {
              background-image: url("normal.png");
          \\scaryBackground.css
          body {
              background-image: url("scary.png");
          I’m not sure if this will do full screen, or just a specific location for the module. I suppose I’ll have to look into the MM defaults to see where a module is displayed if it isn’t specified.
            @I_Am_Anthony since you’re targeting the body element in your CSS, it won’t matter where you specify the location of the module to be. However, by default, if you don’t specify a location for the module, it’s not shown at all. I don’t know how that will affect your module.
            I’d also suggest that you extract the style sheets and the times during which they are displayed into the configuration. That way you module is reusable by others who might want to use this in a similar way.
            • strawberry 3.141S
              This should not work, as the getStyles function of the module gets just executed once when the mirror boots. I would suggest to create some classes like morning, afternoon, evening, … and in the module you load the css file with those classes, then create an interval which checks the current time of the day. based on that you query for the body like var body = document.querySelector('body'); and set the specific class body.className = 'morning';
              • I
                I_Am_Anthony
                @I_Am_Anthony said in Change background image based on time of day:
                return [“normalBackground.css”];
                Can this be done in the getDom() function, or will that cause it to continually loop and eat up the processor? Apologies, I’m just getting into this and not 100% familiar with the program flow of execution. Something like this?
                    defaults: {
                	night_start: 0,
                        night_stop: 5,
                        night_background: "ring.jpg",
                        day_background: "Splash.png"
                        return ["custom.css"];
                    getDom: function() {
                        if (having markup issues displaying logic) ){
                            body.className = night_background;
                        else {
                            body.className = day_background;
                  @I_Am_Anthony getDom() is only executed when you call the updateDom() function. So in your code, you could have a timer that fires, say, every 10 minutes, and if the time threshold has passed, you can call updateDom().
                  That said, your getDom() function needs to return something, as it expects to get the HTML update for the module from this routine, to be placed in whatever location the module is configured for. Since your module doesn’t have a configured location, using the getDom routine might not be the best place to do this.
                  You can set all of this up in the start() function. Set up a timer, and in the function that gets executed when the timer fires, do your time comparison and update of the CSS class on the body element directly. No need to use getDom for this.
                  • I
                    I_Am_Anthony
                    How does this look?
                        defaults: {
                    	night_start: 0,
                            night_stop: 5,
                            night_background: "night.png",
                            day_background: "day.png"
                        //Do I still need to load the custom.css?
                        // Define start sequence.
                        start: function() {
                    	// Schedule update interval.
                    	var self = this;
                            self.updateBackground();
                    	setInterval(function() {
                    	}, 600000);
                        updateBackground: function() {
                            if ( currentTime >= this.config.night_start && currentTime &#60= this.config.night_stop  ||
                               ((currentTime >= this.config.night_start || currentTime &#60= this.config.night_stop) &&
                                this.config.night_start > this.config.night_stop) ){
                                body.className = this.config.night_background;
                            else {
                                body.className = this.config.day_background;
                    BTW, thanks for helping to walk me through this. I’m pretty rusty on javascript. If I can get it sorted and running, I’ll package it and submit it as a module. Not terribly useful, but hey…
                    J strawberry 3.141S 2 Replies Last reply Reply Quote 0
                      @I_Am_Anthony Looks like it might work! You should call updateBackground() once before setting up the timer so that you’ll have a background at module startup, instead of having to wait for the timer to fire for the first time.
                      • strawberry 3.141S
                        strawberry 3.141 Project Sponsor Module Developer @I_Am_Anthony
                        @I_Am_Anthony night_background and day_background will be undefined.
                        you have to address them like this.config.night_background and you have to change your comparison operators. => defines an arrow function and doesn’t mean greaer or equal then like >= would do. Less or equal would be `
                        • I
                          I_Am_Anthony
                          Good catch on the missing this.config.night_background, thanks.
                          I’m aware that it’s >= and &#60= The markup really hates the less than or equal sign together (because HTML apparently), so I just flipped them for the purposes of markup. Just found that I can use the escape instead: &#60=.
                          Anyway, thanks to both of you @j.e.f.f and @strawberry-3-141 for the help. I’ve updated the code above to prevent repasting. I’ll get it into the mirror soon to test. If it works then I’ll package it and submit as a module.
                          • X
                            xTITUS MAXIMUSx
                            I know this is an old topic but did you get this module finished? if do you have a git hub?
                            • Piranha1605P
                              Piranha1605
                              https://forum.magicmirror.builders/topic/13014/css-switch-module
                              X 1 Reply Last reply Reply Quote 0
                              • X
                                xTITUS MAXIMUSx @Piranha1605
                                @Piranha1605
                                Not exactly what I am looking for. I tried to take @I_Am_Anthony code and tweak it to my needs but, no success. maybe you’ll review my code? :)
                                • Piranha1605P
                                  Piranha1605
                                  You can actually schedule all CSS entries in the module, including the background.
                                  • X
                                    @Piranha1605 Cool! how would one do that? Still a noob.
                                    • Piranha1605P
                                      Piranha1605
                                      @xTITUS-MAXIMUSx said in Change background image based on time of day:
                                      • Install the module
                                      • Enter the time from when to when night is in the config.
                                      • Enter your background in the custom.css
                                      .morning {
                                        background: blue;
                                      .evening {
                                        background: black;
                                      • X
                                        @Piranha1605 Yeah dude I took a gander at your github and then set everything to my needs. I appreciate it!
