    MMM-MyScoreboard
    277 Posts 60 Posters 641.8k Views 63 Watching
    • O
      onetwankyfive
      +1 to NCAAF
      This would be amazing
        j.e.f.f Project Sponsor Module Developer @P-Bo726
        @P-Bo726 So it looks like I’d need to make a pretty significant rewrite to make this module work with multiple instances. Right now my node_helper module stores quite a bit of instance information, including what supported sports modules are required – this part in particular poses a real problem being stored as instance configuration, as opposed to a global module configuration.
        I’ll spend some time thinking about how this might be architected, but I don’t think this will happen any time soon, sorry to say.
        If you wanted to get your hands dirty, you could manually make multiple instances of this module, but it’s really hacky. Make a copy of the MMM-MyScoreboard directory (Say, MMM-MyScoreBoard2). rename MMM-MyScorboard.js to MMM-MyScoreboard2.js. Do the same to the CSS file and rename it to MMM-MyScoreboard2.css. In the MMM-MyScoreboard2.js file, you’ll need to adjust line 12 Module.register("MMM-MyScoreboard" to read Module.register("MMM-MyScoreboard2" and similarly line 38 return ["MMM-MyScoreboard.css"]; to return ["MMM-MyScoreboard2.css"];
        Finally, do a search and replace in MMM-MyScoreboard2.css and replace all instances of MMM-MyScoreboard with MMM-MyScoreboard2.
        Now you have two independent modules - MMM-MyScoreboard and MMM-MyScoreboard2 - that you can configure separately in your config file.
        You can do this as many times as you like, so long as each time you are using a different name.
        • P-Bo726P
          P-Bo726
          Thank you for the response. I’ll take a look at that hack you provided. If you find some "free’’ time and want to work on the multiple instances I would still find some value in it. No pressure, no hurry. I appreciate all the work you have put into this module and the MM forum in general. Great work!
            @P-Bo726 Need to get NFL up and running before anything else. Pre-season starts this week!
            • K
              Krisalexroberts 0
              Could you get this working with Pointstreak? Lots of minority leagues/sports use Pointstreak such as the UK Elite Ice Hockey League (EIHL)
                j.e.f.f Project Sponsor Module Developer @Krisalexroberts 0
                @Krisalexroberts-0 I’ll take a look to see if there is a public data feed available for this. If so, it should be doable. It will take some time to amass all of the logos and such, but I like the potential for many leagues working with a single API.
                I still have to finish with NFL – I had it working with last night’s game, but I’d like to run it against next week’s preseason lineup to see if there are any gotchas before I release it.
                So far I have requests for NCAAF, Pointstreak and eSports. Should be an interesting summer!
                • K
                  Krisalexroberts 0 @j.e.f.f
                  @j.e.f.f you’re a star!
                  I don’t know if this helps: https://github.com/eikeco/pointstreak-leauge-table
                    @Krisalexroberts-0 it does. Seems to be hit or miss as to which leagues have data feeds. Are there specific leagues that you’re looking to see incorporated? Doesn’t look like I can just incorporate blanket pointstreak support.
                    • K
                      Krisalexroberts 0
                      I’m selfish so only care about EIHL
                        @Krisalexroberts-0 An API key is required, but I can’t see anywhere on Pointstreak’s site to get one. Nor can I find any documentation on the endpoints (The link you provided was for standings, not for scores). At this point I’m not sure it’s going to be possible… :(
                          j.e.f.f Project Sponsor Module Developer @Spankythemusical
                          @Spankythemusical @onetwankyfive I’m in the process of gathering everything I need for NCAAF. I’ve managed to source all of the logos for Division I (FBS 1-A, FCS 1-AA). Forgive me if this isn’t obvious to me –
                          college football is not really a thing in Canada – but does anyone care about Division II and Division III? From what I can gather, Division I seems to only be what people generally follow.
                          Sourcing logos for Div II and III looks like it will take some time and work, and I’d like to avoid it if it’s not really something people care about. Even ESPN’s web site only has a few logos for those teams.
                            Spankythemusical @j.e.f.f
                            @j.e.f.f I believe that division 1 is the one that’s followed by the most people. I don’t even know f it’s possible to get info from the other divisions through the major sites.
                            Thank you for doing this. I’m curious to see how far off my attempt is from what you come up with.
                              @Spankythemusical Actually now that I look at the feed I’m using, it appears that it’s only returning games for FBS (1-A) teams, not FCS (1-AA) unless they are playing a FBS team. This is the feed I found. Is this the same feed you’re using?
                              http://site.api.espn.com/apis/site/v2/sports/football/college-football/scoreboard?dates=20170907&limit=100
                              (value for dates is specified to query for a specific day limit sets a maximum number of returned games)
                              In the above example, one game gets returned for September 7 – Idaho State Bengals vs Utah State Aggies – which corresponds to the one FBS game scheduled for that date. However, if I switch the schedule (say on ESPN’s website) I see four games scheduled, one of which is an overlap with the single FBS game, as Utah is an FBS team, but Idaho State is FCS.
                              So it appears that FBS teams play FCS teams, and such games will show up in the ESPN feed. However games that feature FCS-only games do not. It appears that FCS teams play games against Division II or III – I see one game on Sept 7: West Alabama Tigers vs Samford Bulldogs. West Alabama is a Division II team.
                              I have learned from this Wiki that FBS teams don’t play Division II/III teams, only FCS teams, as victories against anything below FCS don’t count for bowl eligibility.
                              https://en.wikipedia.org/wiki/NCAA_Division_II
                              Is this a hard and fast rule? I wouldn’t want to go through the effort of sourcing Div II/III logos if they will never appear against FBS teams.
                              In any case, it appears that I can only support FBS (1-A) games at the moment. Is this good enough for the college football fans?
                                @j.e.f.f Code written for FBS, but also having FCS logos in the folder (for overlapping game types), should work for 99.9% of the people. If that’s possible.
                                I’ll have to look in morning to see if that’s the website that I’ve been using. It does seem about right.
                                  @Spankythemusical yeah certainly doable. I have already sourced all the FBS and FCS team logos. So if the feed only covers FBS games then we should be covered for all team logos.
                                  I’ve learned so much about American college football over the last few days!
                                  • O
                                    onetwankyfive @j.e.f.f
                                    @j.e.f.f This excites me! Div 1 is what I was looking for
                                      @j.e.f.f just FYI, that is the site I’ve been using, minus the date and limit items.
                                        NFL support has been added. To install the update, first go into the MMM-MyScoreboard and execute git pull, the type npm install as there are new dependencies you’ll need.
                                        I monitored games over last week and this week and everything looks pretty good, but I haven’t seen a game go into overtime yet. So I’m not 100% positive things won’t go wonky for an overtime game yet.
                                        Also, there is a new view style added: smallLogos. It’s layout is similar to the default, but each row is the same height as the oneLine view style.
                                        Have fun! And let me know if something looks weird.
                                          @Spankythemusical FYI I’ve got the basic plumbing in place for NCAAF, but I need to wait for some in progress games to test it. Won’t be able to do that until the first week of September, as I’m traveling at the end of August, which appears to be then first week of play.
                                          In any case, what’s interesting is that by manipulating the URL, it’s possible to get scores for all sorts of sports. I’ll easily be able to repurpose this for NCAA basketball and MLS (YAY! I thought this wasn’t going to be possible).
                                          I also might use this feed for NFL, since NFL’s native feed seems to be a bit flaky AND it’s XML (I f***ing hate working with XML). I’ll monitor it over the next few days to see if it performs better.
                                            Spankythemusical
                                            Thank you very much for all your work. I’m sure that you have much more important things to do. I can always wait for live games in order to test. In the mean time I can parse things with python. No biggie.
                                            • 13
                                            • 14
                                            • 2 / 14
