    MMM-SoccerLiveScore
    187 Posts 37 Posters 325.9k Views 35 Watching
      janner6
      Where do you get the league id’s from I’m after league two in England if you have it available?
      Cheers
      • N Offline
        nem1 @bminer1
        @bminer1 said in MMM-SoccerLiveScore:
        Having an issue with the module updating. None of the weekend games updated.
        I’ve the same problem! The module is not up2date. F.e. at the moment the results of the CL matches of Thuesday & Wednesday are not shown. It looks like the module got freezed. I’ve seen this problem often in the past. After restarting the whole mirror, the module is back again. Last restart was on monday. Any ideas? I did not install or change anything in the last weeks.
        • H Offline
          headhunter
          • L Offline
            leer0ybr0wn @bminer1
            @bminer1 I had the same issue so I made a function to overwrite the headings. It’s done client-side post load so not ideal but it’s a start :-)
            You can change the time interval at which it refreshes (it needs to keep doing this if you cycle through leagues).
            setInterval (changePrem,10000);
            function changePrem() {
                var prem = document.querySelector("#module_6_MMM-SoccerLiveScore div.module-content header").innerHTML;
                var premchange = prem.replace("Pr. League", "Premier League");
                document.querySelector("#module_6_MMM-SoccerLiveScore div.module-content header").innerHTML = premchange;
            Make a js file out of this and load it at the bottom of the main index.html file
            • O Offline
              oliveimo
              Hey Guys,
              I just set it up and the scores and blank. Im assuming if no games are on nothing will show? I saw talk about a table but is it live? Thanks! Great work BTW.
              here is my code. I wanna see Spain first and see how it goes. Let me know if there is anything I need to upload for some help. Thanks!
              module: ‘MMM-SoccerLiveScore’,
              position: ‘top_right’,
              header:‘Live-Scores’,
              			leagues : [8],
              		showNames: true,
              		showLogos: true,
              		displaytime: 60 * 1000,
              		showTables: true
                smkr
                Hey LukeCodewalker
                Thank you for the MMM-SoccerLiveScore.
                I would love if You could expand the module to only show the teams I choose and for X days.
                I follow Bayern, Juventus, Roma, and so on. something like this:
                20-5-2017 15.30:
                Bayern 1 - 0 Freiburg
                18.00
                Chievo - Roma
                21-5-2017 15.00
                Juventus - Crotone
                16.00
                Watford FC - Manchester City
                Hull City - Tottenham Hotspurs
                20.00
                FC Barcelona - SD Eibar
                The idea is from the FORZA App at Android.
                BR.
                Sten
                • N Offline
                  nem1
                  Hey, what about the Confed Cup? Is it possible to show? If its still in, what ID do I need to add?
                    McSorley
                    Where does it pull the fixtures from? There is currently a new draw for Europa and Champions League Qualifiers. Europa games are today.
                    • ArzegA Offline
                      Arzeg
                      Hey Guys
                      i think i solved the problem for now with the blank table.
                      The problem is in the config.js the leagues command, if u put only one ID in this command like
                      leagues: [35], // it doesnt work
                      but
                      leagues: [35, 999], // it works. dont know why im not a programmer^^
                      but i have a question too,
                      where can i configure that my header and the scores are not going from the left side to my right side cause i have the clock on the left side and the weather on my right side
                        JoeFranz
                        I have a problem when switching from the results to the table. At the beginning everything runs as it should. After about an hour there is when switching misfires. Attached to the link of a video of the error, hope it works.
                        Does somebody has any idea?
                        Greeting Jörg
                        Video
                        EDIT:
                        For me this is probably the “blank screen problem”
                        With only one league, it only comes to an interruption and then nothing will be displayed. With two leagues, everything works as it should.
                        The tip of Arzeg with the entry [35, 999] unfortunately does not work.
                          JoeFranz
                          Here is another error. If the table is displayed without names, the line with teams etc. is moved about it, does not fit properly.
                          • ArzegA Offline
                            Arzeg
                            Hey Jörg,
                            bad to hear that the tip doesnt work for you.
                            For me it works perfect.
                            But I still have the problem with the width of the module, it goes from the left to the right side and i dont know, how i can change the width…
                            MfG Arzeg
                            EDIT:
                            I dont know if it’s for you a solution but I use MMM-soccer for the table and MMM-SoccerLiveScore as my live ticker, so i set showTables to false in config.js
                            Its not the perfect solution but i can live with it
                            • K Offline
                              knubbl
                              • K Offline
                                knubbl
                                HI,
                                is it possible to send an alarm/notification if there is a goal in any game in a league i set to shown on the mirror?
                                Maybe its quite easy but honestly i do not have any idea how this alterts/notifications work
                                  JoeFranz
                                  The results and the table of the german bundesliga are now also not updated. A pity about an otherwise great module and the author does not care about the errors.
                                  • K Offline
                                    knubbl @JoeFranz
                                    @JoeFranz are u sure? Everything works fine at my mm
                                      JoeFranz
                                      So I have three errors in it. Blank sreen if only one league is displayed, with the table without names fit above the symbols and is not updated now, only after a reboot of magicmirror. Here is my config.js
                                      position: ‘bottom_left’,
                                      leagues: [35, 9],
                                               showNames: false,
                                              showLogos: true,
                                               displayTime: 60 * 1000,
                                               showTables: true
                                      • L Offline
                                        l0cal
                                        i love this module but there is a problem with update live score and table. It don’t work for me. All other installed module works fine and update work well. if i restart mm it loads the new data score etc
                                          master117
                                          I created a new version of this module:
                                          https://github.com/master117/MagicMirror-FootballLeagues
                                          Most of the errors mentioned above, should be fixed. It works with only one league selected for example. The old module also polls its undocumented datasource too often and eventually gets banned, which is why the scores stop refreshing. It does not yet have support for logos.
                                          Greetings,
                                          master117
                                          • F Offline
                                            fabbr
                                            @master117 I just tried and got two errors on the installation:
                                            npm WARN enoent ENOENT: no such file or directory, open ‘/home/pi/MagicMirror/modules/package.json’
                                            npm WARN enoent ENOENT: no such file or directory, open ‘/home/pi/MagicMirror/modules/node_modules/node_helper/package.json’
                                            npm WARN modules No description
                                            npm WARN modules No repository field.
                                            npm WARN modules No README data
                                            npm WARN modules No license field.
                                            When I add the module to the config.js nothing shows up. I tried several different configurations and problem persist. any idea on what I am doing wrong?
                                            • 10
                                            • 3 / 10
