    MMM-SoccerLiveScore
    187 Posts 37 Posters 328.7k Views 35 Watching
    • L Offline
      leer0ybr0wn @bminer1
      @bminer1 I had the same issue so I made a function to overwrite the headings. It’s done client-side post load so not ideal but it’s a start :-)
      You can change the time interval at which it refreshes (it needs to keep doing this if you cycle through leagues).
      setInterval (changePrem,10000);
      function changePrem() {
          var prem = document.querySelector("#module_6_MMM-SoccerLiveScore div.module-content header").innerHTML;
          var premchange = prem.replace("Pr. League", "Premier League");
          document.querySelector("#module_6_MMM-SoccerLiveScore div.module-content header").innerHTML = premchange;
      Make a js file out of this and load it at the bottom of the main index.html file
      • O Offline
        oliveimo
        Hey Guys,
        I just set it up and the scores and blank. Im assuming if no games are on nothing will show? I saw talk about a table but is it live? Thanks! Great work BTW.
        here is my code. I wanna see Spain first and see how it goes. Let me know if there is anything I need to upload for some help. Thanks!
        module: ‘MMM-SoccerLiveScore’,
        position: ‘top_right’,
        header:‘Live-Scores’,
        			leagues : [8],
        		showNames: true,
        		showLogos: true,
        		displaytime: 60 * 1000,
        		showTables: true
          smkr
          Hey LukeCodewalker
          Thank you for the MMM-SoccerLiveScore.
          I would love if You could expand the module to only show the teams I choose and for X days.
          I follow Bayern, Juventus, Roma, and so on. something like this:
          20-5-2017 15.30:
          Bayern 1 - 0 Freiburg
          18.00
          Chievo - Roma
          21-5-2017 15.00
          Juventus - Crotone
          16.00
          Watford FC - Manchester City
          Hull City - Tottenham Hotspurs
          20.00
          FC Barcelona - SD Eibar
          The idea is from the FORZA App at Android.
          BR.
          Sten
          • N Offline
            nem1
            Hey, what about the Confed Cup? Is it possible to show? If its still in, what ID do I need to add?
              McSorley
              Where does it pull the fixtures from? There is currently a new draw for Europa and Champions League Qualifiers. Europa games are today.
              • ArzegA Offline
                Arzeg
                Hey Guys
                i think i solved the problem for now with the blank table.
                The problem is in the config.js the leagues command, if u put only one ID in this command like
                leagues: [35], // it doesnt work
                but
                leagues: [35, 999], // it works. dont know why im not a programmer^^
                but i have a question too,
                where can i configure that my header and the scores are not going from the left side to my right side cause i have the clock on the left side and the weather on my right side
                  JoeFranz
                  I have a problem when switching from the results to the table. At the beginning everything runs as it should. After about an hour there is when switching misfires. Attached to the link of a video of the error, hope it works.
                  Does somebody has any idea?
                  Greeting Jörg
                  Video
                  EDIT:
                  For me this is probably the “blank screen problem”
                  With only one league, it only comes to an interruption and then nothing will be displayed. With two leagues, everything works as it should.
                  The tip of Arzeg with the entry [35, 999] unfortunately does not work.
                    JoeFranz
                    Here is another error. If the table is displayed without names, the line with teams etc. is moved about it, does not fit properly.
                    • ArzegA Offline
                      Arzeg
                      Hey Jörg,
                      bad to hear that the tip doesnt work for you.
                      For me it works perfect.
                      But I still have the problem with the width of the module, it goes from the left to the right side and i dont know, how i can change the width…
                      MfG Arzeg
                      EDIT:
                      I dont know if it’s for you a solution but I use MMM-soccer for the table and MMM-SoccerLiveScore as my live ticker, so i set showTables to false in config.js
                      Its not the perfect solution but i can live with it
                      • K Offline
                        knubbl
                        • K Offline
                          knubbl
                          HI,
                          is it possible to send an alarm/notification if there is a goal in any game in a league i set to shown on the mirror?
                          Maybe its quite easy but honestly i do not have any idea how this alterts/notifications work
                            JoeFranz
                            The results and the table of the german bundesliga are now also not updated. A pity about an otherwise great module and the author does not care about the errors.
                            • K Offline
                              knubbl @JoeFranz
                              @JoeFranz are u sure? Everything works fine at my mm
                                JoeFranz
                                So I have three errors in it. Blank sreen if only one league is displayed, with the table without names fit above the symbols and is not updated now, only after a reboot of magicmirror. Here is my config.js
                                position: ‘bottom_left’,
                                leagues: [35, 9],
                                         showNames: false,
                                        showLogos: true,
                                         displayTime: 60 * 1000,
                                         showTables: true
                                • L Offline
                                  l0cal
                                  i love this module but there is a problem with update live score and table. It don’t work for me. All other installed module works fine and update work well. if i restart mm it loads the new data score etc
                                    master117
                                    I created a new version of this module:
                                    https://github.com/master117/MagicMirror-FootballLeagues
                                    Most of the errors mentioned above, should be fixed. It works with only one league selected for example. The old module also polls its undocumented datasource too often and eventually gets banned, which is why the scores stop refreshing. It does not yet have support for logos.
                                    Greetings,
                                    master117
                                    • F Offline
                                      fabbr
                                      @master117 I just tried and got two errors on the installation:
                                      npm WARN enoent ENOENT: no such file or directory, open ‘/home/pi/MagicMirror/modules/package.json’
                                      npm WARN enoent ENOENT: no such file or directory, open ‘/home/pi/MagicMirror/modules/node_modules/node_helper/package.json’
                                      npm WARN modules No description
                                      npm WARN modules No repository field.
                                      npm WARN modules No README data
                                      npm WARN modules No license field.
                                      When I add the module to the config.js nothing shows up. I tried several different configurations and problem persist. any idea on what I am doing wrong?
                                      • G Offline
                                        gashion
                                        @fabbr Did you ever get this working? I get the same errors;
                                        npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
                                        npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/node_modules/node_helper/package.json'
                                        @master117 Anything?
                                          master117
                                          @gashion @fabbr
                                          Those are not errors (ERR) just regular warnings (WARN). They are unrelated to whatever issue you are having, they are even unrelated to the module itself, request (the thing being installed) is a semi standard nodejs library and not made by me.
                                          I would guess either your config is wrong or there is not enough space on the mirror. If you list your steps and config I may be able to help.
                                          • G Offline
                                            gashion
                                            @master117
                                            Here is my config:
                                            			module: 'MagicMirror-FootballLeagues',
                                            			position: 'bottom_center',
                                            			header: 'Live-Scores',
                                            				leagues: [445, 455, 464, 456, 450],
                                                    		showNames: true,
                                                    		showTables: true,
                                            				showLogos: true,
                                            				apiKey: 'MyApiKey'
                                            • 10
                                            • 3 / 10
