    MMM-SoccerLiveScore
    187 Posts 37 Posters 334.7k Views 35 Watching
    • ArzegA
      Arzeg
      Hey Guys
      i think i solved the problem for now with the blank table.
      The problem is in the config.js the leagues command, if u put only one ID in this command like
      leagues: [35], // it doesnt work
      but
      leagues: [35, 999], // it works. dont know why im not a programmer^^
      but i have a question too,
      where can i configure that my header and the scores are not going from the left side to my right side cause i have the clock on the left side and the weather on my right side
        JoeFranz
        I have a problem when switching from the results to the table. At the beginning everything runs as it should. After about an hour there is when switching misfires. Attached to the link of a video of the error, hope it works.
        Does somebody has any idea?
        Greeting Jörg
        Video
        EDIT:
        For me this is probably the “blank screen problem”
        With only one league, it only comes to an interruption and then nothing will be displayed. With two leagues, everything works as it should.
        The tip of Arzeg with the entry [35, 999] unfortunately does not work.
          JoeFranz
          Here is another error. If the table is displayed without names, the line with teams etc. is moved about it, does not fit properly.
          • ArzegA
            Arzeg
            Hey Jörg,
            bad to hear that the tip doesnt work for you.
            For me it works perfect.
            But I still have the problem with the width of the module, it goes from the left to the right side and i dont know, how i can change the width…
            MfG Arzeg
            EDIT:
            I dont know if it’s for you a solution but I use MMM-soccer for the table and MMM-SoccerLiveScore as my live ticker, so i set showTables to false in config.js
            Its not the perfect solution but i can live with it
            • K
              knubbl
              • K
                knubbl
                HI,
                is it possible to send an alarm/notification if there is a goal in any game in a league i set to shown on the mirror?
                Maybe its quite easy but honestly i do not have any idea how this alterts/notifications work
                  JoeFranz
                  The results and the table of the german bundesliga are now also not updated. A pity about an otherwise great module and the author does not care about the errors.
                  • K
                    knubbl @JoeFranz
                    @JoeFranz are u sure? Everything works fine at my mm
                      JoeFranz
                      So I have three errors in it. Blank sreen if only one league is displayed, with the table without names fit above the symbols and is not updated now, only after a reboot of magicmirror. Here is my config.js
                      module: ‘MMM-SoccerLiveScore’,
                      position: ‘bottom_left’,
                      leagues: [35, 9],
                               showNames: false,
                              showLogos: true,
                               displayTime: 60 * 1000,
                               showTables: true
                      • L
                        l0cal
                        i love this module but there is a problem with update live score and table. It don’t work for me. All other installed module works fine and update work well. if i restart mm it loads the new data score etc
                          master117
                          I created a new version of this module:
                          https://github.com/master117/MagicMirror-FootballLeagues
                          Most of the errors mentioned above, should be fixed. It works with only one league selected for example. The old module also polls its undocumented datasource too often and eventually gets banned, which is why the scores stop refreshing. It does not yet have support for logos.
                          Greetings,
                          master117
                          • F
                            fabbr
                            @master117 I just tried and got two errors on the installation:
                            npm WARN enoent ENOENT: no such file or directory, open ‘/home/pi/MagicMirror/modules/package.json’
                            npm WARN enoent ENOENT: no such file or directory, open ‘/home/pi/MagicMirror/modules/node_modules/node_helper/package.json’
                            npm WARN modules No description
                            npm WARN modules No repository field.
                            npm WARN modules No README data
                            npm WARN modules No license field.
                            When I add the module to the config.js nothing shows up. I tried several different configurations and problem persist. any idea on what I am doing wrong?
                            • G
                              gashion
                              @fabbr Did you ever get this working? I get the same errors;
                              npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
                              npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/node_modules/node_helper/package.json'
                              @master117 Anything?
                                master117
                                @gashion @fabbr
                                Those are not errors (ERR) just regular warnings (WARN). They are unrelated to whatever issue you are having, they are even unrelated to the module itself, request (the thing being installed) is a semi standard nodejs library and not made by me.
                                I would guess either your config is wrong or there is not enough space on the mirror. If you list your steps and config I may be able to help.
                                • G
                                  gashion
                                  @master117
                                  Here is my config:
                                  			module: 'MagicMirror-FootballLeagues',
                                  			position: 'bottom_center',
                                  			header: 'Live-Scores',
                                  				leagues: [445, 455, 464, 456, 450],
                                          		showNames: true,
                                          		showTables: true,
                                  				showLogos: true,
                                  				apiKey: 'MyApiKey'
                                  • F
                                    fabbr @gashion
                                    I don’t think the API is working anymore. :(
                                    • N
                                      nem1
                                      Is it possible to integrate the World Cup 2018 into this module?
                                        baschke
                                        Is there a way to diasable tables for specific leagues? e.g. I don’t want to show tables for the Champions Leagues, cause it will only show the table of group A.
                                        • G
                                          gashion @baschke
                                          @baschke
                                          When adding leagues in your config, dont add “464”. Thats for Champions League.
                                          • N
                                            nem1
                                            I used this module in the past and I was really satisfied. After a complete reset of my mirror, I had to reinstall all modules. Unfortounatly the MMM-SoccerLiveScore is not working correctly anymore :(
        module: "MMM-SoccerLiveScore",
        header: "Live-Scores",
        leagues: [35,9,1,0],
        displayTime: 30 * 1000
                                            Whats wrong? On the mirror its shown just the header, no error-message.
                                            Thanks a lot.
                                            nem1
                                            • 10
                                            • 3 / 10
