Changing ipwhitelist prevents Mirror from loading correctly
Any changes I make to ipwhitelist prevent (or so it appears) MM from loading. This is true of anything I change it to other than the default. Everything seems to load normally―Pi boots up, desktop loads, launches MM. But, when the screen should load no modules populate. It just sits there… black… taunting me.
I originally intended to use the whitelist filtering to tie into the Remote Control module, but that loads correctly. I can’t get it to allow access but I think that’s a result of whatever the hell is causing mirror to not load correctly.
Any thoughts?
So far I’ve tried every possible configuration, and variation of functioning (or should be) ip addresses, and/or ranges.
I’ve tried including IPv6
I’ve loaded a fresh, untouched config.js, made only changes to the whitelist and I get the same result.
I’ve done everything I can think of short of reinstalling mirror and It’s dependancies.
@rcollie would be good to actually see what you tried exactly. Also can you check for errors in the electron console? and for logs in the terminal?
I can copy and paste the contents of config.js, but the issue occurs on the unaltered sample as well. Any change made to ipwhitelist causes the issue. At present there’s nothing listed―it’s default. So, the issue doesn’t occur. If I change it to:
var config = {
port: 8080,
ipWhitelist: [],the issue occurs. It happens with any, and all ip variations. Hence my reason for not copying and pasting each one―it doesn’t matter what I change it to.
I haven’t looked at the electron logs, because I can’t find them. I assumed they’d be in ~/.config/Electron/ , but they aren’t. Are they located elsewhere, or do they have to be compiled or exported to a file?
Do you have the master or develop branch? I noticed this issue on the develop branch but “ipWhitelist: []” works for me on the master branch without issues.
@rcollie I’m on develop branch and I’m using this to be able to access the mirror from anywhere (inside my network). I had to add the “address: “0.0.0.0”.” some time ago… :)
var config = { port: 8080, ipWhitelist: [], address: "0.0.0.0", ...Try it… :)
I am having the same issue as op and the last post doesnt help. Whenever I change the white list to anything other then default i just get a blank screen with MM
I’m not running the dev.
I also tried what you suggested Snille with no change.
Alright… Well… It makes no sense (not that it has thus far anyway) but I was playing with different configurations of ipwhitelist today, and all of the sudden
var config = { port: 8080, ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.0/28", "::ffff:192.168.2.0/28", "::ffff:192.168.3.0/28", "192.168.2.219"],worked. The computer I’m working from is the last IP. Literally changed nothing else.
As far as I can figure just adding mine the the end of the default, for some reason works. Changing anything else (tested by changing it a few more times before coming back to this) broke it again. So this is literally the only way I can get it to work. Which… makes absolutely no sense.
I’m not going to question it anymore at this point. Just enjoy the fact that its working.
Maybe this will do something for you too @pingywon Just replace the last IP with your own.
I have come to the same conclusion on my own today. added the single ip of my work station and was able to get access. This works for now, but it is not a long term solution. I installed MMM-admin-panel and want to able to access the mirror from pretty much any ip inside my network.
Im going to do some more testing on monday…but im afraid I might have to add every darn IP in my internal DHCP scope just to not have to worry about it.
I agree it makes NO SENSE! :)
In the meantime let me know if you come up with any other developments.
Thank you
@Snille When I try this, the log stopped at this point:
0|mm | Connecting socket for: MMM-Fuel
0|mm | Starting module helper: MMM-Fuel
0|mm | Sockets connected & modules started …
0|mm | Launching application.
0|mm | Access denied to IP address: 0.0.0.0/0 -
@rcollie yep this works for me too, wierd!
How looks your config.js??
Mine looks like this:
var config = {
port: 8080,
ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.0/28”, “::ffff:192.168.2.0/28”, “::ffff:192.168.3.0/28”, “192.168.2.219”, “192.168.2.3”, “192.168.2.72”, “192.168.2.78”],language: “en”,
timeFormat: 12,
units: “imperial”,modules: [ -
ok. try to split it into 2 entries…
pWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.0/28”, “::ffff:192.168.2.0/28”],
you are sure that port 8080 is not used by annother application or blocked by your firewall??
First, try the first entry only and then add the second-one
( I used /24 instead /28, works here…)
remove the " ," after the font?
var config = {
port: 8080,
ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.0/28”, “::ffff:192.168.2.0/28”, “::ffff:192.168.3.0/28”, “10.0.0.16”],language: "de", modules: [ {..... -
var config = {
port: 8088,
ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”,“::ffff:192.168.1.1/24”,“192.168.1.1/24”],
ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”,“::ffff:178.198.19.1/24”,“178.198.19.1/24”],
language: “de”,
timeFormat: 24,
units: “metric”,modules: [ -
@psteimann I may have misunderstood. Are you asking for help or offering suggestions?
@rcollie thats the way it works here…:-)
@psteimann I’m still not understanding your intent. I’ve posted a solution (really a workaround), so I’m not clear as to whether you’re trying to help solve a problem that I’ve already solved, or if you are asking for help.
@rcollie if it works in your way, then its ok. My works also, so just an alternative “help”…
