    Changing ipwhitelist prevents Mirror from loading correctly
    21 Posts 8 Posters 15.5k Views 7 Watching
    • rcollieR Offline
      rcollie
      I can copy and paste the contents of config.js, but the issue occurs on the unaltered sample as well. Any change made to ipwhitelist causes the issue. At present there’s nothing listed―it’s default. So, the issue doesn’t occur. If I change it to:
      var config = {
      port: 8080,
      ipWhitelist: [],
      the issue occurs. It happens with any, and all ip variations. Hence my reason for not copying and pasting each one―it doesn’t matter what I change it to.
      I haven’t looked at the electron logs, because I can’t find them. I assumed they’d be in ~/.config/Electron/ , but they aren’t. Are they located elsewhere, or do they have to be compiled or exported to a file?
      • U Offline
        Ultimatum22 Module Developer
        Do you have the master or develop branch? I noticed this issue on the develop branch but “ipWhitelist: []” works for me on the master branch without issues.
        • SnilleS Offline
          Snille Module Developer
          @rcollie I’m on develop branch and I’m using this to be able to access the mirror from anywhere (inside my network). I had to add the “address: “0.0.0.0”.” some time ago… :)
          var config = {
          	port: 8080,
          	ipWhitelist: [],
          	address: "0.0.0.0",
          Try it… :)
            pingywon
            I am having the same issue as op and the last post doesnt help. Whenever I change the white list to anything other then default i just get a blank screen with MM
            • rcollieR Offline
              rcollie
              I’m not running the dev.
              I also tried what you suggested Snille with no change.
              • rcollieR Offline
                rcollie
                Alright… Well… It makes no sense (not that it has thus far anyway) but I was playing with different configurations of ipwhitelist today, and all of the sudden
                var config = {
                		port: 8080,
                		ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.0/28", "::ffff:192.168.2.0/28", "::ffff:192.168.3.0/28", "192.168.2.219"],
                worked. The computer I’m working from is the last IP. Literally changed nothing else.
                As far as I can figure just adding mine the the end of the default, for some reason works. Changing anything else (tested by changing it a few more times before coming back to this) broke it again. So this is literally the only way I can get it to work. Which… makes absolutely no sense.
                I’m not going to question it anymore at this point. Just enjoy the fact that its working.
                Maybe this will do something for you too @pingywon Just replace the last IP with your own.
                  pingywon
                  I have come to the same conclusion on my own today. added the single ip of my work station and was able to get access. This works for now, but it is not a long term solution. I installed MMM-admin-panel and want to able to access the mirror from pretty much any ip inside my network.
                  Im going to do some more testing on monday…but im afraid I might have to add every darn IP in my internal DHCP scope just to not have to worry about it.
                  I agree it makes NO SENSE! :)
                  In the meantime let me know if you come up with any other developments.
                  Thank you
                    schlachtkreuzer6 @Snille
                    @Snille When I try this, the log stopped at this point:
                    0|mm | Connecting socket for: MMM-Fuel
                    0|mm | Starting module helper: MMM-Fuel
                    0|mm | Sockets connected & modules started …
                    0|mm | Launching application.
                    0|mm | Access denied to IP address: 0.0.0.0/0
                      schlachtkreuzer6 @rcollie
                      @rcollie yep this works for me too, wierd!
                        psteimann
                        How looks your config.js??
                        • rcollieR Offline
                          rcollie
                          Mine looks like this:
                          var config = {
                          port: 8080,
                          ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.0/28”, “::ffff:192.168.2.0/28”, “::ffff:192.168.3.0/28”, “192.168.2.219”, “192.168.2.3”, “192.168.2.72”, “192.168.2.78”],
                          language: “en”,
                          timeFormat: 12,
                          units: “imperial”,
                            psteimann
                            ok. try to split it into 2 entries…
                            pWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.0/28”, “::ffff:192.168.2.0/28”],
                            you are sure that port 8080 is not used by annother application or blocked by your firewall??
                            First, try the first entry only and then add the second-one
                            ( I used /24 instead /28, works here…)
                            remove the " ," after the font?
                              schlachtkreuzer6 @psteimann
                              @psteimann /
                              var config = {
                              port: 8080,
                              ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.0/28”, “::ffff:192.168.2.0/28”, “::ffff:192.168.3.0/28”, “10.0.0.16”],
                              language: "de",
                                psteimann
                                var config = {
                                port: 8088,
                                ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”,“::ffff:192.168.1.1/24”,“192.168.1.1/24”],
                                ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”,“::ffff:178.198.19.1/24”,“178.198.19.1/24”],
                                language: “de”,
                                timeFormat: 24,
                                units: “metric”,
                                • rcollieR Offline
                                  rcollie
                                  @psteimann I may have misunderstood. Are you asking for help or offering suggestions?
                                    psteimann @rcollie
                                    @rcollie thats the way it works here…:-)
                                    • rcollieR Offline
                                      rcollie
                                      @psteimann I’m still not understanding your intent. I’ve posted a solution (really a workaround), so I’m not clear as to whether you’re trying to help solve a problem that I’ve already solved, or if you are asking for help.
                                        psteimann @rcollie
                                        @rcollie if it works in your way, then its ok. My works also, so just an alternative “help”…
                                          roramirez Core Contributors
                                          About all this mess it up
                                          https://forum.magicmirror.builders/post/27658
