    MM & Google Maps Traffic
    16 Posts 4 Posters 19.2k Views 5 Watching
      Mirrorolentia
      There are two catches which I will try to correct:
      1. The Google Maps have their own lifecycle which I could not align with MM module’s. So you may not see the map in the first instance but it will get uploaded within the next interval (as configured in config.interval).
      2. The Maps div element keeps getting refreshed after every interval which is a bit irritating :(
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @birdy
        @birdy you are missing quotes around the drivin mode, should be mode: 'driving'
          devtech8 @Mirrorolentia
          @Mirrorolentia - I was thinking of trying this too, but looks like you have made some progress. I hope to dig into what you have later this week. I had seen some further customization I would like to add when time allows. Thanks for the work on this!
            Mirrorolentia @devtech8
            @devtech8
            Sure that would be great! Thanks!
              birdy
              @Mirrorolentia - wow, thx!! I will test it later :) can’t await
                birdy
                so, as a complete noobie, I just pasted the code (adding Google Api key) in both files.
                I can see, there is a gap in the corner (I hope for the map) and if I get you correctly, the map will load “soon”(?).
                Thank you one more time and will keep u posted.
                Cheers
                Birdy
                  Mirrorolentia @birdy
                  @birdy
                  Yes that is correct. You will need to copy the lines from /global module**/ all the way till end…somehow the comments didn’t embed the code correctly
                    birdy
                    somehow it’s not working:
                      @birdy
                      Seems like the MM system didn’t initialize the module itself :(
                      Are you seeing any errors on the console from where you run “node serveronly” or on the chromium browser i.e from More Tools–> Developer Tools–>Console.
                        birdy
                        you mean like this:
                        Connecting socket for: MMM-Traffic
                        MMM-Traffic helper started ...
                        Ready to go! Please point your browser to: http://localhost:8080
                        { Error: listen EADDRINUSE :::8080
                            at Object.exports._errnoException (util.js:1020:11)
                            at exports._exceptionWithHostPort (util.js:1043:20)
                            at Server._listen2 (net.js:1258:14)
                            at listen (net.js:1294:10)
                            at net.js:1404:9
                            at _combinedTickCallback (internal/process/next_tick.js:83:11)
                            at process._tickCallback (internal/process/next_tick.js:104:9)
                            at Module.runMain (module.js:606:11)
                            at run (bootstrap_node.js:389:7)
                            at startup (bootstrap_node.js:149:9)
                          code: 'EADDRINUSE',
                          errno: 'EADDRINUSE',
                          syscall: 'listen',
                          address: '::',
                          port: 8080 }
                          @birdy
                          Sorry for the delayed response. Got caught with stuff :(
                          By any chance do you have some other server running in parallel which is also listening on 8080 and using any available IPv6 address. Ideally you should have only “node” running with the specified port
                          You can check this with netstat.
                          netstat  -nalp | grep 8080
                          tcp6       0      0   ::: 8080                 ::: *                    LISTEN      2350/node
                          tcp6       0      0 ::1:43558               ::1:8080                ESTABLISHED 2103/libpepflashpla
                          tcp6       0      0 ::1:8080                ::1:43558               ESTABLISHED 2350/node
                          You can try killing that service (In the last column i.e 2350/node, 2350 represents PID. You can use "kill -9 ") and then probably restart the Magic Mirror.
                          Also this may not be related to the actual problem.
                          Please see if you can post your config.js.
                            birdy
                            @Mirrorolentia
                            thanks for helping me and sorry for late reply.
                            Here comes the config:
                            /* Magic Mirror Config Sample
                             * MIT Licensed.
                            var config = {
                            	port: 8080,
                            	language: "en",
                            	timeFormat: 24,
                            	units: "metric",
                            			module: "alert",
                            			module: "updatenotification",
                            			position: "top_bar"
                            			module: "clock",
                            			position: "top_left"
                            			header: "AWISTA & Feiertage NRW",
                            						symbol: "calendar-check-o ",
                            						url: "https://calendar.google.com/calendar/ical/**********/public/basic.ics"
                            			module: "compliments",
                            			position: "lower_third"
                            			module: "currentweather",
                            				locationID: "2934246",  //ID from http://www.openweathermap.org/help/city_list.txt
                            				appid: "************"
                            			module: "weatherforecast",
                            			header: "Weather Forecast",
                            				appid: "***********"
                                			module: 'MMM-Vrr',
                                			position: "bottom_left",
                                    			city: 'Düsseldorf',
                                    			station: '***********',
                                    			numberOfResults: 6,
                                    			displayTimeOption: 'time+countdown'
                            		    module: "MMM-Fuel",
                            		    position: "bottom_right",
                            		        api_key: "************",
                            		        lat: *********,
                            		        lng: ************,
                            		        types: ["diesel"],
                            			radius: 1.4,
                            			max: 2,
                            			rotate: false,
                            		module: 'MMM-Traffic',
                            		position: 'bottom_right',
                            		classes: 'dimmed medium', //optional, default is 'bright medium', only applies to commute info not route_name
                            			api_key: '*********',
                            			mode: 'driving',
                            			origin: '******+Düsseldorf,+Deutschland',
                            			destination: '**********+Essen,+Deutschland',
                            			route_name: 'Home to Work',
                            			changeColor: true,
                            			showGreen: false,
                            			limitYellow: 5, //Greater than 5% of journey time due to traffic
                            			limitRed: 20, //Greater than 20% of journey time due to traffic
                            			traffic_model: 'best_guess',
                            			departure_time: 'now',
                            			interval: 60000,
                            			showWeekend: false,
                            			allTime: true,
                            	                width: '300px',
                            	                height: '300px'
                            and here is netstat:
                            pi@raspberrypi:~ $ netstat -nalp | grep 8080
                            (Es konnten nicht alle Prozesse identifiziert werden; Informationen über
                            nicht-eigene Processe werden nicht angezeigt; Root kann sie anzeigen.)
                            tcp6       0      0 :::8080                 :::*                    LISTEN      1119/electron.js
                            tcp6       0      0 ::1:51608               ::1:8080                VERBUNDEN   1119/electron.js
                            tcp6       0      0 ::1:8080                ::1:51610               VERBUNDEN   1119/electron.js
                            tcp6       0      0 ::1:51606               ::1:8080                VERBUNDEN   1119/electron.js
                            tcp6       0      0 ::1:51600               ::1:8080                VERBUNDEN   1119/electron.js
                            tcp6       0      0 ::1:51610               ::1:8080                VERBUNDEN   1119/electron.js
                            tcp6       0      0 ::1:51604               ::1:8080                VERBUNDEN   1119/electron.js
                            tcp6       0      0 ::1:8080                ::1:51608               VERBUNDEN   1119/electron.js
                            tcp6       0      0 ::1:8080                ::1:51598               VERBUNDEN   1119/electron.js
                            tcp6       0      0 ::1:8080                ::1:51600               VERBUNDEN   1119/electron.js
                            tcp6       0      0 ::1:51602               ::1:8080                VERBUNDEN   1119/electron.js
                            tcp6       0      0 ::1:8080                ::1:51606               VERBUNDEN   1119/electron.js
                            tcp6       0      0 ::1:8080                ::1:51604               VERBUNDEN   1119/electron.js
                            tcp6       0      0 ::1:8080                ::1:51602               VERBUNDEN   1119/electron.js
                            tcp6       0      0 ::1:51598               ::1:8080                VERBUNDEN   1119/electron.js
                            pi@raspberrypi:~ $
