    MMM-Tools : System stat monitoring and commanding (ATB Supported)
    38 Posts 7 Posters 22.8k Views 6 Watching
    • KimzerK
      Kimzer
      The issue seems pretty straightforward.
      If i place it top_center. It works fine.
      bottom_right (where i want it) without any other modules there, it displays the text only. No bars etc. If i re-add the module i already have there it doesnt show at all…
      ? randomnoiseR 2 Replies Last reply
        A Former User @Kimzer
        @Kimzer that might be related with width vlaue. That might be not bug. I don’t assume how much width user assign to my module. So you could adjust your GOOD view with css by yourself. Give your favorite width or min-width to the module in css.
        Anyway, someone could feel embarrassed with this inconvenient approach, I’ll add default min-width value in next commit.
        Thanks for your advice.
        • randomnoiseR
          randomnoise @Kimzer
          @Kimzer @Sean
          Yup, can confirm it works just fine in top_left… my top left width happens to be manually set to be 480px due to another module I’m running so that’s probably why its happy now.
          BTW I forgot to set to RPI, but it actually still worked just fine when set to ATB by default.
          ? 1 Reply Last reply
            A Former User @randomnoise
            @randomnoise screen controlling and measuring temperatures are different between rpi and atb.
            randomnoiseR 1 Reply Last reply
            • KimzerK
              Kimzer
              Probably not a bug at all, may be my custom css that is causing issues.
              Tried min-width and width but really didnt fix anything.
              • randomnoiseR
                randomnoise @Guest
                @Sean I’m not using the screen controls so that’s fair enough. I just compared the temp from MMM-Tools to that from MMM-system stats and yes you’re correct the values are wrong if I set the type to ATB. Forgive my rambling :)
                  @Kimzer ok, tomorrow i’ll try testing widely and can provide better settings. Sorry for inconvenience of all and thanks for your interesting. After work, I’ll post about that.
                  • KimzerK
                    Kimzer
                    Great stuff! :) Seems like i can run the module fine anywhere but the bottom rows.
                    ? 2 Replies Last reply
                      @Kimzer You are right. that is so weird, only in the bottom region, it won’t works. I’d never imagined this.
                      But, now I catch this error, I believe I can solve this problem.
                        @Kimzer Here is hotfix.
                        open MMM-Tools.css, find below section, add margin-top:0; there.
                        .Tools .status_item .container {
                          width: 75%;
                          order: 2;
                          height:100%;
                          overflow:hidden;
                          margin-top:0;
                        MM’s default main.css set margin-top:25px; to .bottom .bar, It makes collision with my css.
                        • KimzerK
                          Kimzer
                          Perfect. I just included it in my custom.css
                          Thanks for the fix! :D
                          • KimzerK
                            Kimzer
                            Any way to make the bars showing ram be transparent?
                              @Kimzer in css, change #xxx to rgba(00,00,00,0.5) which you want.
                              Ex) rgba(255,0,0,0.5) will be half-transparent red.
                              • KimzerK
                                Kimzer
                                Went another way and used opacity. Worked great :)
                                • lavolp3L
                                  lavolp3 Module Developer
                                  @Sean Hi Sean,
                                  the module does not show correct values for SD card space for me.
                                  Actual values:
                                  Shown values:
                                  Any idea?
                                  How to troubleshoot modules
                                  MMM-soccer v2, MMM-AVStock
                                  • lavolp3L
                                    I think you need to use sudo du -hs / instead of du -hs to show usage of all folders. This shows me the 6.5G my system is using instead of the 1.5G which is not enough and supposedly only valid for part of the system.
                                      A Former User @lavolp3
                                      @lavolp3
                                      Thanks for information. I’ll fix it later, however you can modify the source on line 34 of node_helper.js.
                                      lavolp3L 1 Reply Last reply
                                      • lavolp3L
                                        lavolp3 Module Developer @Guest
                                        @sean Also, I think you could cut the line so the dash, or in your case the dot, does not appear.
                                        If I find the time I’ll send a PR.
                                          A Former User
                                          UPDATED
                                          2019-01-13
                                          • Voice warning alert be enabled with MMM-AssistantMk2
