    MMM-Tools : System stat monitoring and commanding (ATB Supported)
    38 Posts 7 Posters 22.3k Views 6 Watching
      A Former User @Kimzer
      @Kimzer I cant figure out what is problem, more detailed info is needed.
      • rpi model
      • os
      • your configuration values…
      • npm start dev result
        Mykle1 Project Sponsor Module Developer @Guest
        @Sean
        I have to go to work, Sean. I will post that info for you when I get home.
        • randomnoiseR Offline
          randomnoise
          Tried this module, even with a default config it doesn’t seem to display any of the actual values, just the titles:
          Running Rpi3 Raspian Jesse
          No errors during startup:
          Starting MagicMirror: v2.1.2
          Loading config ...
          Loading module helpers ...
          Module helper loaded: MMM-Tools
          All module helpers loaded.
          Server started ...
          Connecting socket for: MMM-Tools
          Starting module: newsfeed
          Launching application.
          Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
          Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
          Use existing news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml
          Config used:
          		  module: 'MMM-Tools',
          		  position: 'bottom_right',
          			device : "RPI", // "RPI" is also available
          			refresh_interval_ms : 10000,
          			warning_interval_ms : 1000 * 60 * 5,
          			enable_warning : true,
          			warning : {
          			  CPU_TEMPERATURE : 65,
          			  GPU_TEMPERATURE : 65,
          			  CPU_USAGE : 75,
          			  STORAGE_USED_PERCENT : 80,
          			  MEMORY_USED_PERCENT : 80
            @Sean
            I just reinstalled MMM-Tool and it is working now. I don’t know why it didn’t work the first time. shrug
            • Pi 3 Model B, 1GB, Hardware : BCM2709, Revision = a02082, (Sony, UK)
            • Raspbian Jessie
              	position: 'top_center',
            		enable_warning : false,
            		    warning : {
            		    CPU_USAGE : 75,
                  		    MEMORY_USED_PERCENT : 80,
              A Former User @randomnoise
              @randomnoise only label is displayed, when module is stopped before getting results of script execution of node_helper. Possible suspicious point is…
              • module(including your other modules) has error, so front electron halts.
              npm start dev, see the browser dev console. If there is no suspicious message(usually red lines), hmmmm…
              • KimzerK Offline
                Kimzer
                The issue seems pretty straightforward.
                If i place it top_center. It works fine.
                bottom_right (where i want it) without any other modules there, it displays the text only. No bars etc. If i re-add the module i already have there it doesnt show at all…
                ? randomnoiseR 2 Replies Last reply Reply Quote 0
                  @Kimzer that might be related with width vlaue. That might be not bug. I don’t assume how much width user assign to my module. So you could adjust your GOOD view with css by yourself. Give your favorite width or min-width to the module in css.
                  Anyway, someone could feel embarrassed with this inconvenient approach, I’ll add default min-width value in next commit.
                  Thanks for your advice.
                    randomnoise @Kimzer
                    @Kimzer @Sean
                    Yup, can confirm it works just fine in top_left… my top left width happens to be manually set to be 480px due to another module I’m running so that’s probably why its happy now.
                    BTW I forgot to set to RPI, but it actually still worked just fine when set to ATB by default.
                      @randomnoise screen controlling and measuring temperatures are different between rpi and atb.
                      randomnoiseR 1 Reply Last reply Reply Quote 0
                      • KimzerK Offline
                        Kimzer
                        Probably not a bug at all, may be my custom css that is causing issues.
                        Tried min-width and width but really didnt fix anything.
                          randomnoise @Guest
                          @Sean I’m not using the screen controls so that’s fair enough. I just compared the temp from MMM-Tools to that from MMM-system stats and yes you’re correct the values are wrong if I set the type to ATB. Forgive my rambling :)
                            @Kimzer ok, tomorrow i’ll try testing widely and can provide better settings. Sorry for inconvenience of all and thanks for your interesting. After work, I’ll post about that.
                            • KimzerK Offline
                              Kimzer
                              Great stuff! :) Seems like i can run the module fine anywhere but the bottom rows.
                                @Kimzer You are right. that is so weird, only in the bottom region, it won’t works. I’d never imagined this.
                                But, now I catch this error, I believe I can solve this problem.
                                  @Kimzer Here is hotfix.
                                  open MMM-Tools.css, find below section, add margin-top:0; there.
                                  .Tools .status_item .container {
                                    width: 75%;
                                    order: 2;
                                    height:100%;
                                    overflow:hidden;
                                    margin-top:0;
                                  MM’s default main.css set margin-top:25px; to .bottom .bar, It makes collision with my css.
                                  • KimzerK Offline
                                    Kimzer
                                    Perfect. I just included it in my custom.css
                                    Thanks for the fix! :D
                                    • KimzerK Offline
                                      Kimzer
                                      Any way to make the bars showing ram be transparent?
                                        @Kimzer in css, change #xxx to rgba(00,00,00,0.5) which you want.
                                        Ex) rgba(255,0,0,0.5) will be half-transparent red.
                                        • KimzerK Offline
                                          Kimzer
                                          Went another way and used opacity. Worked great :)
                                          • lavolp3L Offline
                                            lavolp3 Module Developer
                                            @Sean Hi Sean,
                                            the module does not show correct values for SD card space for me.
                                            Actual values:
                                            Shown values:
                                            Any idea?
                                            How to troubleshoot modules
                                            MMM-soccer v2, MMM-AVStock
