    MMM-Tools : System stat monitoring and commanding (ATB Supported)
    38 Posts 7 Posters 21.8k Views 6 Watching
    • randomnoiseR Offline
      randomnoise @Guest
      @Sean I’m not using the screen controls so that’s fair enough. I just compared the temp from MMM-Tools to that from MMM-system stats and yes you’re correct the values are wrong if I set the type to ATB. Forgive my rambling :)
        A Former User @Kimzer
        @Kimzer ok, tomorrow i’ll try testing widely and can provide better settings. Sorry for inconvenience of all and thanks for your interesting. After work, I’ll post about that.
        • KimzerK Offline
          Kimzer
          Great stuff! :) Seems like i can run the module fine anywhere but the bottom rows.
            @Kimzer You are right. that is so weird, only in the bottom region, it won’t works. I’d never imagined this.
            But, now I catch this error, I believe I can solve this problem.
              @Kimzer Here is hotfix.
              open MMM-Tools.css, find below section, add margin-top:0; there.
              .Tools .status_item .container {
                width: 75%;
                order: 2;
                height:100%;
                overflow:hidden;
                margin-top:0;
              MM’s default main.css set margin-top:25px; to .bottom .bar, It makes collision with my css.
              • KimzerK Offline
                Kimzer
                Perfect. I just included it in my custom.css
                Thanks for the fix! :D
                • KimzerK Offline
                  Kimzer
                  Any way to make the bars showing ram be transparent?
                    @Kimzer in css, change #xxx to rgba(00,00,00,0.5) which you want.
                    Ex) rgba(255,0,0,0.5) will be half-transparent red.
                    • KimzerK Offline
                      Kimzer
                      Went another way and used opacity. Worked great :)
                      • lavolp3L Offline
                        lavolp3 Module Developer
                        @Sean Hi Sean,
                        the module does not show correct values for SD card space for me.
                        Actual values:
                        Shown values:
                        Any idea?
                        How to troubleshoot modules
                        MMM-soccer v2, MMM-AVStock
                        • lavolp3L Offline
                          I think you need to use sudo du -hs / instead of du -hs to show usage of all folders. This shows me the 6.5G my system is using instead of the 1.5G which is not enough and supposedly only valid for part of the system.
                            A Former User @lavolp3
                            @lavolp3
                            Thanks for information. I’ll fix it later, however you can modify the source on line 34 of node_helper.js.
                            • lavolp3L Offline
                              lavolp3 Module Developer @Guest
                              @sean Also, I think you could cut the line so the dash, or in your case the dot, does not appear.
                              If I find the time I’ll send a PR.
                                A Former User
                                UPDATED
                                2019-01-13
                                • Voice warning alert be enabled with MMM-AssistantMk2
