    MMM-Tools : System stat monitoring and commanding (ATB Supported)
    38 Posts 7 Posters 22.7k Views 6 Watching
      A Former User @randomnoise
      @randomnoise screen controlling and measuring temperatures are different between rpi and atb.
      randomnoiseR 1 Reply Last reply Reply Quote 0
      • KimzerK
        Kimzer
        Probably not a bug at all, may be my custom css that is causing issues.
        Tried min-width and width but really didnt fix anything.
        • randomnoiseR
          randomnoise @Guest
          @Sean I’m not using the screen controls so that’s fair enough. I just compared the temp from MMM-Tools to that from MMM-system stats and yes you’re correct the values are wrong if I set the type to ATB. Forgive my rambling :)
            A Former User @Kimzer
            @Kimzer ok, tomorrow i’ll try testing widely and can provide better settings. Sorry for inconvenience of all and thanks for your interesting. After work, I’ll post about that.
            • KimzerK
              Kimzer
              Great stuff! :) Seems like i can run the module fine anywhere but the bottom rows.
                @Kimzer You are right. that is so weird, only in the bottom region, it won’t works. I’d never imagined this.
                But, now I catch this error, I believe I can solve this problem.
                  @Kimzer Here is hotfix.
                  open MMM-Tools.css, find below section, add margin-top:0; there.
                  .Tools .status_item .container {
                    width: 75%;
                    order: 2;
                    height:100%;
                    overflow:hidden;
                    margin-top:0;
                  MM’s default main.css set margin-top:25px; to .bottom .bar, It makes collision with my css.
                  • KimzerK
                    Kimzer
                    Perfect. I just included it in my custom.css
                    Thanks for the fix! :D
                    • KimzerK
                      Kimzer
                      Any way to make the bars showing ram be transparent?
                        @Kimzer in css, change #xxx to rgba(00,00,00,0.5) which you want.
                        Ex) rgba(255,0,0,0.5) will be half-transparent red.
                        • KimzerK
                          Kimzer
                          Went another way and used opacity. Worked great :)
                          • lavolp3L
                            lavolp3 Module Developer
                            @Sean Hi Sean,
                            the module does not show correct values for SD card space for me.
                            Actual values:
                            Shown values:
                            Any idea?
                            How to troubleshoot modules
                            MMM-soccer v2, MMM-AVStock
                            • lavolp3L
                              I think you need to use sudo du -hs / instead of du -hs to show usage of all folders. This shows me the 6.5G my system is using instead of the 1.5G which is not enough and supposedly only valid for part of the system.
                                A Former User @lavolp3
                                @lavolp3
                                Thanks for information. I’ll fix it later, however you can modify the source on line 34 of node_helper.js.
                                • lavolp3L
                                  lavolp3 Module Developer @Guest
                                  @sean Also, I think you could cut the line so the dash, or in your case the dot, does not appear.
                                  If I find the time I’ll send a PR.
                                    A Former User
                                    UPDATED
                                    2019-01-13
                                    • Voice warning alert be enabled with MMM-AssistantMk2
