    MMM-Tools : System stat monitoring and commanding (ATB Supported)
    38 Posts 7 Posters 22.8k Views 6 Watching
    • KimzerK
      Kimzer
      Probably not a bug at all, may be my custom css that is causing issues.
      Tried min-width and width but really didnt fix anything.
      ? 1 Reply Last reply
      • randomnoiseR
        randomnoise @Guest
        @Sean I’m not using the screen controls so that’s fair enough. I just compared the temp from MMM-Tools to that from MMM-system stats and yes you’re correct the values are wrong if I set the type to ATB. Forgive my rambling :)
          A Former User @Kimzer
          @Kimzer ok, tomorrow i’ll try testing widely and can provide better settings. Sorry for inconvenience of all and thanks for your interesting. After work, I’ll post about that.
          • KimzerK
            Kimzer
            Great stuff! :) Seems like i can run the module fine anywhere but the bottom rows.
            ? 2 Replies Last reply
              @Kimzer You are right. that is so weird, only in the bottom region, it won’t works. I’d never imagined this.
              But, now I catch this error, I believe I can solve this problem.
                @Kimzer Here is hotfix.
                open MMM-Tools.css, find below section, add margin-top:0; there.
                .Tools .status_item .container {
                  width: 75%;
                  order: 2;
                  height:100%;
                  overflow:hidden;
                  margin-top:0;
                MM’s default main.css set margin-top:25px; to .bottom .bar, It makes collision with my css.
                • KimzerK
                  Kimzer
                  Perfect. I just included it in my custom.css
                  Thanks for the fix! :D
                  • KimzerK
                    Kimzer
                    Any way to make the bars showing ram be transparent?
                      @Kimzer in css, change #xxx to rgba(00,00,00,0.5) which you want.
                      Ex) rgba(255,0,0,0.5) will be half-transparent red.
                      • KimzerK
                        Kimzer
                        Went another way and used opacity. Worked great :)
                        • lavolp3L
                          lavolp3 Module Developer
                          @Sean Hi Sean,
                          the module does not show correct values for SD card space for me.
                          Actual values:
                          Shown values:
                          Any idea?
                          How to troubleshoot modules
                          MMM-soccer v2, MMM-AVStock
                          • lavolp3L
                            I think you need to use sudo du -hs / instead of du -hs to show usage of all folders. This shows me the 6.5G my system is using instead of the 1.5G which is not enough and supposedly only valid for part of the system.
                              A Former User @lavolp3
                              @lavolp3
                              Thanks for information. I’ll fix it later, however you can modify the source on line 34 of node_helper.js.
                              lavolp3L 1 Reply Last reply
                              • lavolp3L
                                lavolp3 Module Developer @Guest
                                @sean Also, I think you could cut the line so the dash, or in your case the dot, does not appear.
                                If I find the time I’ll send a PR.
                                  A Former User
                                  UPDATED
                                  2019-01-13
                                  • Voice warning alert be enabled with MMM-AssistantMk2
