    MMM-Tools : System stat monitoring and commanding (ATB Supported)
    38 Posts 7 Posters 21.6k Views 6 Watching
      Mykle1 Project Sponsor Module Developer @Guest
      @Sean said in MMM-Tools : System stat monitoring and commanding (ATB Supported):
      You can just remove required version in module js file.
      I commented out the version check but it still didn’t display on my Pi3B mirror. No errors, terminal or console
      • K Offline
        krisalexroberts
        Worked fine on my mirror on a Pi3B. Just had to remove some of the final commas from the config
          A Former User @krisalexroberts
          @krisalexroberts Thanks! I typed this example not by copy, so i did mistakes. I fixed it.
          • KimzerK Offline
            Kimzer
            Same here. Redownloaded. Used the new settings. No bueno. Doesnt display
              A Former User @Kimzer
              @Kimzer I cant figure out what is problem, more detailed info is needed.
              • rpi model
              • os
              • your configuration values…
              • npm start dev result
                @Sean
                I have to go to work, Sean. I will post that info for you when I get home.
                • randomnoiseR Offline
                  randomnoise
                  Tried this module, even with a default config it doesn’t seem to display any of the actual values, just the titles:
                  Running Rpi3 Raspian Jesse
                  No errors during startup:
                  Starting MagicMirror: v2.1.2
                  Loading config ...
                  Loading module helpers ...
                  Module helper loaded: MMM-Tools
                  All module helpers loaded.
                  Server started ...
                  Connecting socket for: MMM-Tools
                  Starting module: newsfeed
                  Launching application.
                  Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
                  Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                  Use existing news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml
                  Config used:
                  		  module: 'MMM-Tools',
                  		  position: 'bottom_right',
                  			device : "RPI", // "RPI" is also available
                  			refresh_interval_ms : 10000,
                  			warning_interval_ms : 1000 * 60 * 5,
                  			enable_warning : true,
                  			warning : {
                  			  CPU_TEMPERATURE : 65,
                  			  GPU_TEMPERATURE : 65,
                  			  CPU_USAGE : 75,
                  			  STORAGE_USED_PERCENT : 80,
                  			  MEMORY_USED_PERCENT : 80
                    @Sean
                    I just reinstalled MMM-Tool and it is working now. I don’t know why it didn’t work the first time. shrug
                    • Pi 3 Model B, 1GB, Hardware : BCM2709, Revision = a02082, (Sony, UK)
                    • Raspbian Jessie
                      	position: 'top_center',
                    		enable_warning : false,
                    		    warning : {
                    		    CPU_USAGE : 75,
                          		    MEMORY_USED_PERCENT : 80,
                      A Former User @randomnoise
                      @randomnoise only label is displayed, when module is stopped before getting results of script execution of node_helper. Possible suspicious point is…
                      • module(including your other modules) has error, so front electron halts.
                      npm start dev, see the browser dev console. If there is no suspicious message(usually red lines), hmmmm…
                      • KimzerK Offline
                        Kimzer
                        The issue seems pretty straightforward.
                        If i place it top_center. It works fine.
                        bottom_right (where i want it) without any other modules there, it displays the text only. No bars etc. If i re-add the module i already have there it doesnt show at all…
                        ? randomnoiseR 2 Replies Last reply Reply Quote 0
                          @Kimzer that might be related with width vlaue. That might be not bug. I don’t assume how much width user assign to my module. So you could adjust your GOOD view with css by yourself. Give your favorite width or min-width to the module in css.
                          Anyway, someone could feel embarrassed with this inconvenient approach, I’ll add default min-width value in next commit.
                          Thanks for your advice.
                            randomnoise @Kimzer
                            @Kimzer @Sean
                            Yup, can confirm it works just fine in top_left… my top left width happens to be manually set to be 480px due to another module I’m running so that’s probably why its happy now.
                            BTW I forgot to set to RPI, but it actually still worked just fine when set to ATB by default.
                              @randomnoise screen controlling and measuring temperatures are different between rpi and atb.
                              randomnoiseR 1 Reply Last reply Reply Quote 0
                              • KimzerK Offline
                                Kimzer
                                Probably not a bug at all, may be my custom css that is causing issues.
                                Tried min-width and width but really didnt fix anything.
                                  randomnoise @Guest
                                  @Sean I’m not using the screen controls so that’s fair enough. I just compared the temp from MMM-Tools to that from MMM-system stats and yes you’re correct the values are wrong if I set the type to ATB. Forgive my rambling :)
                                    @Kimzer ok, tomorrow i’ll try testing widely and can provide better settings. Sorry for inconvenience of all and thanks for your interesting. After work, I’ll post about that.
                                    • KimzerK Offline
                                      Kimzer
                                      Great stuff! :) Seems like i can run the module fine anywhere but the bottom rows.
                                        @Kimzer You are right. that is so weird, only in the bottom region, it won’t works. I’d never imagined this.
                                        But, now I catch this error, I believe I can solve this problem.
                                          @Kimzer Here is hotfix.
                                          open MMM-Tools.css, find below section, add margin-top:0; there.
                                          .Tools .status_item .container {
                                            width: 75%;
                                            order: 2;
                                            height:100%;
                                            overflow:hidden;
                                            margin-top:0;
                                          MM’s default main.css set margin-top:25px; to .bottom .bar, It makes collision with my css.
                                          • KimzerK Offline
                                            Kimzer
                                            Perfect. I just included it in my custom.css
                                            Thanks for the fix! :D
