    MMM-Tools : System stat monitoring and commanding (ATB Supported)
    38 Posts 7 Posters 22.8k Views 6 Watching
      A Former User @Kimzer
      @Kimzer If you are using Pi Zero or… without LXDE, It could not work properly maybe.
      • KimzerK
        Kimzer
        Im not sure what the issue is, simply wont display anything.
        Using a Pi2 model b.
        ? 1 Reply Last reply
          @Kimzer test npm start dev, and see which error messages are thrown in your terminal console, and chromium dev console.
          and report issue on my github, I’ll look and try to fix. :)
          Mykle1M 1 Reply Last reply
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @Guest
            @Sean said in MMM-Tools : System stat monitoring and commanding (ATB Supported):
            His problem might be the same as mine. My mirror is running MM 2.1.0 so your check stopped the module from loading.
            Any chance you can add a PC option or move the check to MM version 2.1.0? I’m not really working with Pi’s anymore. A Windows PC dev machine, a Windows PC laptop and a laptop running uBuntu.
            Nice work Sean!
            ? 2 Replies Last reply
              A Former User @Mykle1
              @Mykle1 okay. You can just remove required version in module js file.
              I cant be sure my module has any dependency to recent MM version. That code was just… habit? :)
              I think it could be alright without version. But I cannot test this night. Yup, here is midnight, after sleep, I’ll do that.
                @Mykle1 maybe genuine Ububtu and Debian, I can add, but not sure. Windows… hmmm my last windows work was 15years ago. ;) I’m oldschooled.
                • cowboysdudeC
                  cowboysdude Module Developer @Guest
                  You aren’t missing anything LOL
                  • Mykle1M
                    I commented out the version check but it still didn’t display on my Pi3B mirror. No errors, terminal or console
                    • K
                      krisalexroberts
                      Worked fine on my mirror on a Pi3B. Just had to remove some of the final commas from the config
                        A Former User @krisalexroberts
                        @krisalexroberts Thanks! I typed this example not by copy, so i did mistakes. I fixed it.
                        • KimzerK
                          Kimzer
                          Same here. Redownloaded. Used the new settings. No bueno. Doesnt display
                            @Kimzer I cant figure out what is problem, more detailed info is needed.
                            • rpi model
                            • os
                            • your configuration values…
                            • npm start dev result
                            Mykle1M 2 Replies Last reply
                            • Mykle1M
                              @Sean
                              I have to go to work, Sean. I will post that info for you when I get home.
                              • randomnoiseR
                                randomnoise
                                Tried this module, even with a default config it doesn’t seem to display any of the actual values, just the titles:
                                Running Rpi3 Raspian Jesse
                                No errors during startup:
                                Starting MagicMirror: v2.1.2
                                Loading config ...
                                Loading module helpers ...
                                Module helper loaded: MMM-Tools
                                All module helpers loaded.
                                Server started ...
                                Connecting socket for: MMM-Tools
                                Starting module: newsfeed
                                Launching application.
                                Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
                                Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                                Use existing news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml
                                Config used:
                                		  module: 'MMM-Tools',
                                		  position: 'bottom_right',
                                			device : "RPI", // "RPI" is also available
                                			refresh_interval_ms : 10000,
                                			warning_interval_ms : 1000 * 60 * 5,
                                			enable_warning : true,
                                			warning : {
                                			  CPU_TEMPERATURE : 65,
                                			  GPU_TEMPERATURE : 65,
                                			  CPU_USAGE : 75,
                                			  STORAGE_USED_PERCENT : 80,
                                			  MEMORY_USED_PERCENT : 80
                                • Mykle1M
                                  @Sean
                                  I just reinstalled MMM-Tool and it is working now. I don’t know why it didn’t work the first time. shrug
                                  • Pi 3 Model B, 1GB, Hardware : BCM2709, Revision = a02082, (Sony, UK)
                                  • Raspbian Jessie
                                    	position: 'top_center',
                                  		enable_warning : false,
                                  		    warning : {
                                  		    CPU_USAGE : 75,
                                        		    MEMORY_USED_PERCENT : 80,
                                    A Former User @randomnoise
                                    @randomnoise only label is displayed, when module is stopped before getting results of script execution of node_helper. Possible suspicious point is…
                                    • module(including your other modules) has error, so front electron halts.
                                    npm start dev, see the browser dev console. If there is no suspicious message(usually red lines), hmmmm…
                                    • KimzerK
                                      Kimzer
                                      The issue seems pretty straightforward.
                                      If i place it top_center. It works fine.
                                      bottom_right (where i want it) without any other modules there, it displays the text only. No bars etc. If i re-add the module i already have there it doesnt show at all…
                                      ? randomnoiseR 2 Replies Last reply
                                        @Kimzer that might be related with width vlaue. That might be not bug. I don’t assume how much width user assign to my module. So you could adjust your GOOD view with css by yourself. Give your favorite width or min-width to the module in css.
                                        Anyway, someone could feel embarrassed with this inconvenient approach, I’ll add default min-width value in next commit.
                                        Thanks for your advice.
                                        • randomnoiseR
                                          randomnoise @Kimzer
                                          @Kimzer @Sean
                                          Yup, can confirm it works just fine in top_left… my top left width happens to be manually set to be 480px due to another module I’m running so that’s probably why its happy now.
                                          BTW I forgot to set to RPI, but it actually still worked just fine when set to ATB by default.
                                            @randomnoise screen controlling and measuring temperatures are different between rpi and atb.
                                            randomnoiseR 1 Reply Last reply
