    Annother IPWhitelist question
    12 Posts 4 Posters 8.1k Views 4 Watching
      roramirez Core Contributors @Mykle1
      @Mykle1 What configuration for your ipWhiteList have it?
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @roramirez
        @roramirez
        In v2.1.1.
        var config = {
        	port: 8080,
        	ipWhitelist: [], // Set [] to allow all IP addresses.
        I tried this in v 2.1.2 and it crashed the mirror
        R 1 Reply Last reply
          @Mykle1 said in Annother IPWhitelist question:
          Can you provider more information of the crash…?
          • Mykle1M
            @roramirez said in Annother IPWhitelist question:
            No, because I was unable to get out of the mirror to look at the console or the terminal. I had to power down the mirror and reboot. I deleted the install of 2.1.2 and moved back to v 2.1.1
            P 1 Reply Last reply
              See https://forum.magicmirror.builders/post/27658
                psteimann @Mykle1
                @Mykle1 @roramirez
                Exactly the same issue and behaviour here…
                  B3nihana
                  When I use
                  ipWhitelist: [],
                  Any IP I use shows as blocked. I’m using an RPi 2 with “node serveronly”.
                    roramirez Core Contributors @B3nihana
                    @B3nihana Please, use a develop branch or apply the patch https://github.com/MichMich/MagicMirror/commit/a7297d2685f5ed9b6b34df496065f05ee0d36568#diff-9d4f93dd73c92e4e5730a5c2e0146ad4L33
                      psteimann @roramirez
                      @roramirez Works like a charm…
                      Thaaaaank you!!!
                      • Mykle1M
                        I went to the develop branch. I would also like to confirm that the Whitelist issue, as far as this entry is concerned, has been fixed:
                        var config = {
                        	address: "localhost",
                        	port: 8080,
                        	ipWhitelist: [],
                        So, thank you @roramirez
