    No Country (Bluetooth) For Old Men
    45 Posts 5 Posters 36.5k Views 6 Watching
      d3r @Mykle1
      @Mykle1
      Ya. Pulseaudio stays.
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @d3r
        @d3r said in No Country (Bluetooth) For Old Men:
        Ok, I thought so. I’ll have an update in a little while
        D 1 Reply Last reply
          d3r @Mykle1
          @Mykle1 you might have to be remove (forget) the speaker on your pi bluetooth and restart the pi again once you remove blueman.
          • Mykle1M
            I haven’t tried that. Pairing doesn’t seem to be my problem. The speaker pairs automatically.
            Let me explain my sequence and result
            The first thing I have to do is RUN start-pulseaudio-x11 because I don’t have it in startup yet. This enables the Volume Control where I clearly see the speaker connected.
            Click on the Bluetooth icon and again, I see the speaker is paired
            Right click the Volume icon and I see the speaker but it is not chosen yet.
            Following the directions of the link you gave, I click on HMDX in the drop down menu of the volume icon, but this is the result
            My pulseaudio is up to date.
            I’ll remove the speaker and add it again if you think that will help
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @Mykle1
              @Mykle1 said in No Country (Bluetooth) For Old Men:
              As it turns out, that was a bad idea. Now the Pi does not see the speaker.
                d3r @Mykle1
                @Mykle1 Sorry to hear it’s not working.
                When you reboot try it without running the start-pulseaudio-x11 command. If that doesn’t work, I’m lost.
                Iirc, when I set mine up, I paired the speaker, then did the right click on the speaker icon to change it to the bluetooth speaker.
                • Mykle1M
                  @d3r
                  I can’t try anything right now. The Pi doesn’t see the speaker since I removed it. I can’t add it because it doesn’t appear in the Add Device window
                    d3r @Mykle1
                    @Mykle1 try the command line instead of the gui to pair your speaker.
                    Run bluetoothctl in terminal.
                    Then type:
                    power on
                    Default-agent
                    Agent on
                    Scan on
                    then see if bluetoothct sees the speaker.
                    • Mykle1M
                      @d3r
                      Seemed like it pair, but then says COnnected: no
                      Discovery started
                      [CHG] Controller B8:27:EB:78:6F:82 Discovering: yes
                      [NEW] Device 5D:7C:05:CD:53:E2 5D-7C-05-CD-53-E2
                      [NEW] Device A0:E9:DB:89:37:82 HMDX RAVE
                      [CHG] Device 5D:7C:05:CD:53:E2 RSSI: -72
                      [CHG] Device 5D:7C:05:CD:53:E2 RSSI: -89
                      [CHG] Device A0:E9:DB:89:37:82 RSSI: -66
                      [CHG] Device A0:E9:DB:89:37:82 RSSI: -53
                      [CHG] Device 5D:7C:05:CD:53:E2 RSSI: -90
                      [bluetooth]# pair A0:E9:DB:89:37:82
                      Attempting to pair with A0:E9:DB:89:37:82
                      [CHG] Device A0:E9:DB:89:37:82 Connected: yes
                      Request PIN code
                      [agent] Enter PIN code: 0000
                      [CHG] Device A0:E9:DB:89:37:82 UUIDs:
                      	0000110b-0000-1000-8000-00805f9b34fb
                      	0000110e-0000-1000-8000-00805f9b34fb
                      [CHG] Device A0:E9:DB:89:37:82 Paired: yes
                      Pairing successful
                      [CHG] Device A0:E9:DB:89:37:82 Connected: no
                      [bluetooth]#
                        d3r @Mykle1
                        @Mykle1 Can you try the right click on the speaker icon now to see if it works?
                        • Mykle1M
                          @d3r
                          The speaker was there but I got this error when I clicked on it
                          FatalError: Unable to connect to PulseAudio: OK
                          • Mykle1M
                            Getting something to drink, in lieu of a sedative.
                              d3r @Mykle1
                              @Mykle1 Getting close.
                              Run pulseaudio --start then try the speaker thing again.
                              Mykle1M 3 Replies Last reply
                              • Mykle1M
                                pulseaudio --start
                                • Mykle1M
                                  Getting close
                                  I thought so too, and I thank you for your help but I had one hell of a day and I am exhausted. Instead of hitting this thing with a hammer I’ll walk away and start again tomorrow.
                                  Go get yourself a beer. Sorry for all the troubles.
                                  • Mykle1M
                                    @d3r
                                    I realized that I may have scared you off but I thought you might like to know that I got bluetooth to work.
                                    How? I took my mirror off the wall. Put in a new SD card with a new installation of Jessie 2017-07-05. Installed mpg123 as my mp3 player. Connected to bluetooth using your instructions. Saw the green check mark next to my speaker when right clicking the Volume icon in the menu bar and clicking on my speaker.
                                    Here comes the HOLY SHIT moment.
                                    I have exactly ONE mp3 on my Pi (HA) In the terminal I navigate to the mp3 file. I type mpg123 Nicole.mp3 (A song I wrote for my daughter many moons ago) and BLAM! The song starts playing, plays all the way through, no crash, no freeze. Just music to my ears!
                                    H O L Y S H I T !
                                    So, thank you for your help and advice and all the time you spent trying to get me up and running
                                      d3r @Mykle1
                                      @Mykle1 Awesome, I’m glad it worked out in the end.
                                      • Mykle1M
                                        Raspbian Stretch also changed some stuff about bluetooth, maybe take a look at that if you have a spare sd card lying around. I personally haven’t tried it yet.
                                        A few words of caution about Raspbian Stretch
                                        I’ve been doing some testing recently, mostly concerning CPU usage with different versions of Raspian and MM. Once I got bluetooth to work, I continued testing with newer and newer versions, until I got to Raspbian Stretch.
                                        The firmware update that accompanies Stretch disabled my Wifi and Bluetooth, and no amount of backward flashing to earlier firmware versions is fixing the issue. When I say disabled, I mean the Pi doesn’t recognize its own Wifi or Bluetooth adapter, as if it doesn’t have them. Google it BEFORE you attempt this upgrade.
                                          d3r @Mykle1
                                          @Mykle1 I haven’t tried stretch yet. I don’t have a spare microsd card. Did you check your /boot/config.txt?
                                          Maybe both wifi and bt are disabled in the config.
                                          Mykle1M 2 Replies Last reply
                                          • Mykle1M
                                            @d3r
                                            No mention of wifi or BT at all in the /boot/config.txt file
                                            • 2 / 3
