    Space Between Two Modules
    3 Posts 2 Posters 3.4k Views 2 Watching
      ArkantosArk
      Hi, I’m trying to add some space between two different modules following the instructions here ( https://forum.magicmirror.builders/topic/2435/space-between-analog-clock-and-data/2) , but I can’t really make it work.
      Somebody knows a simple way to add space between two different modules ( compliments and newsfeed in this case) ?.
      Thanks!
        j.e.f.f Project Sponsor Module Developer @ArkantosArk
        @ArkantosArk Assuming both modules are configured for the same region, you can add some bottom margin in custom.css, as follows:
        .module.compliments {
          margin-bottom: 50px; /* play with this until you're happy. */
        Keep in mind that there is likely already some margin defined – this will override whatever is set – so it’s possible that 50px is actually LESS than what is there. Keep playing with the number until you’re happy.
          ArkantosArk @j.e.f.f
          @j.e.f.f It worked! thank you!
