Unsolved Nest Thermostat & Protect
@Aartsie Any help would be great. I’ve been in the process of moving so all my stuff is still scattered around the house.
ok, rebooted everything and its now showing the set temp, and turning blue while running but the number inside the circle showing the current temp never changes, stays at 68 even though the thermostat is showing the correct room temperature.
Humidity % also seems correct now.
maybe it’s a problem with the unit? °C and °F
@pugsly Can you take a screenshot and post it along with what it should be showing? The way I have it configured, the small number is your current temp and the big number is the target temp.
Doesn’t matter what the thermostat says the inside temp is, the mirror always says its 68 deg.
Hmm, it looks like you have it set up to heat/cool. I haven’t programmed that function so I don’t know if the data the Nest API sends is correct. Can you switch it over to cooling only and see if that fixes your temp?
ah yes, that was it. I like keeping it in heat/cool mode and I have a program all setup, don’t really want to change it.
How hard would it be for you to code it that way?
It shouldn’t be that difficult. Can you add an issue to the repo and I’ll mess around with the code.
Its a little better, its now showing what my HEAT temp is set to, but not the COOL. Ideally it would show both with the dot in the middle as in the screen shot above, or if that’s not possible show the COOL setting when cooling, and the HEAT setting when heating and have the circle change colors.
