    Nest Thermostat & Protect
    22 Posts 6 Posters 20.1k Views 6 Watching
      Sachin @mochman
      @mochman Awesome, thank you!
      • A
        Aartsie
        Nice job @mochman i was working on it as well before i saw yours just on time.
        Maybe it is better to put the Nest API pin code on the config file and let the module get the auth code from the API.
        This because the auth code has a expire date so you will replace it every year and it makes it easyer to install.
        If you need some help… maybe i can help you with it.
        mochmanM 1 Reply Last reply
        • pugslyP
          pugsly
          So I got around to setting this up today, got my product ID, the secret, and even the PIN code. Put it into the gettoken.sh and it spit out my token. I added it into my config.js and I see the little circle on my mirror, but the temp is different then what the nest shows. I’m also guessing that the % at the bottom is the inside humidity which also is not what the thermostat shows.
          Any ideas?
          • mochmanM
            mochman Module Developer
            Can you take a screenshot of what it is showing you and what it should be showing?
            • mochmanM
              mochman Module Developer @Aartsie
              @Aartsie Any help would be great. I’ve been in the process of moving so all my stuff is still scattered around the house.
              • pugslyP
                pugsly
                ok, rebooted everything and its now showing the set temp, and turning blue while running but the number inside the circle showing the current temp never changes, stays at 68 even though the thermostat is showing the correct room temperature.
                Humidity % also seems correct now.
                • strawberry 3.141S
                  maybe it’s a problem with the unit? °C and °F
                  • mochmanM
                    mochman Module Developer @pugsly
                    @pugsly Can you take a screenshot and post it along with what it should be showing? The way I have it configured, the small number is your current temp and the big number is the target temp.
                    • pugslyP
                      pugsly
                      • pugslyP
                        pugsly
                        Doesn’t matter what the thermostat says the inside temp is, the mirror always says its 68 deg.
                        • mochmanM
                          Hmm, it looks like you have it set up to heat/cool. I haven’t programmed that function so I don’t know if the data the Nest API sends is correct. Can you switch it over to cooling only and see if that fixes your temp?
                          • pugslyP
                            pugsly
                            ah yes, that was it. I like keeping it in heat/cool mode and I have a program all setup, don’t really want to change it.
                            How hard would it be for you to code it that way?
                            • mochmanM
                              It shouldn’t be that difficult. Can you add an issue to the repo and I’ll mess around with the code.
                              • pugslyP
                                pugsly
                                Its a little better, its now showing what my HEAT temp is set to, but not the COOL. Ideally it would show both with the dot in the middle as in the screen shot above, or if that’s not possible show the COOL setting when cooling, and the HEAT setting when heating and have the circle change colors.
                                • mochmanM
                                  @pugsly It should work as requested now. I merged the branch with the master so you can just update the master now. If the text looks weird it’s probably because I don’t know css and just made up stuff until it worked on my screen.
                                  • mochmanM
                                    Here’s what it should look like for you.
                                    Nest Module
