    Nest Thermostat & Protect
    22 Posts 6 Posters 19.7k Views 6 Watching
    • strawberry 3.141S Offline
      maybe it’s a problem with the unit? °C and °F
        mochman Module Developer @pugsly
        @pugsly Can you take a screenshot and post it along with what it should be showing? The way I have it configured, the small number is your current temp and the big number is the target temp.
          pugsly
            pugsly
            Doesn’t matter what the thermostat says the inside temp is, the mirror always says its 68 deg.
              Hmm, it looks like you have it set up to heat/cool. I haven’t programmed that function so I don’t know if the data the Nest API sends is correct. Can you switch it over to cooling only and see if that fixes your temp?
                pugsly
                ah yes, that was it. I like keeping it in heat/cool mode and I have a program all setup, don’t really want to change it.
                How hard would it be for you to code it that way?
                  It shouldn’t be that difficult. Can you add an issue to the repo and I’ll mess around with the code.
                    pugsly
                    Its a little better, its now showing what my HEAT temp is set to, but not the COOL. Ideally it would show both with the dot in the middle as in the screen shot above, or if that’s not possible show the COOL setting when cooling, and the HEAT setting when heating and have the circle change colors.
                      @pugsly It should work as requested now. I merged the branch with the master so you can just update the master now. If the text looks weird it’s probably because I don’t know css and just made up stuff until it worked on my screen.
                        Here’s what it should look like for you.
                        Nest Module
