    Nest Thermostat & Protect
    22 Posts 6 Posters 19.5k Views 6 Watching
    • W Offline
      Wilco89 @mochman
      @mochman i will look in it asap, i’m really busy atm.
        Sachin @mochman
        @mochman Works like a charm! The only thing I would like to see is the fan icon if the fan is running without the AC or Heat on.
          mochman Module Developer
          @Sachin Sure. I’m in the middle of a move right now, but once I get settled in I take a look at it. It should be pretty straightforward.
            Sachin @mochman
            @mochman Awesome, thank you!
              Aartsie
              Nice job @mochman i was working on it as well before i saw yours just on time.
              Maybe it is better to put the Nest API pin code on the config file and let the module get the auth code from the API.
              This because the auth code has a expire date so you will replace it every year and it makes it easyer to install.
              If you need some help… maybe i can help you with it.
                pugsly
                So I got around to setting this up today, got my product ID, the secret, and even the PIN code. Put it into the gettoken.sh and it spit out my token. I added it into my config.js and I see the little circle on my mirror, but the temp is different then what the nest shows. I’m also guessing that the % at the bottom is the inside humidity which also is not what the thermostat shows.
                Any ideas?
                  Can you take a screenshot of what it is showing you and what it should be showing?
                    mochman Module Developer @Aartsie
                    @Aartsie Any help would be great. I’ve been in the process of moving so all my stuff is still scattered around the house.
                      pugsly
                      ok, rebooted everything and its now showing the set temp, and turning blue while running but the number inside the circle showing the current temp never changes, stays at 68 even though the thermostat is showing the correct room temperature.
                      Humidity % also seems correct now.
                      • strawberry 3.141S Offline
                        maybe it’s a problem with the unit? °C and °F
                          mochman Module Developer @pugsly
                          @pugsly Can you take a screenshot and post it along with what it should be showing? The way I have it configured, the small number is your current temp and the big number is the target temp.
                            pugsly
                              pugsly
                              Doesn’t matter what the thermostat says the inside temp is, the mirror always says its 68 deg.
                                Hmm, it looks like you have it set up to heat/cool. I haven’t programmed that function so I don’t know if the data the Nest API sends is correct. Can you switch it over to cooling only and see if that fixes your temp?
                                  pugsly
                                  ah yes, that was it. I like keeping it in heat/cool mode and I have a program all setup, don’t really want to change it.
                                  How hard would it be for you to code it that way?
                                    It shouldn’t be that difficult. Can you add an issue to the repo and I’ll mess around with the code.
                                      pugsly
                                      Its a little better, its now showing what my HEAT temp is set to, but not the COOL. Ideally it would show both with the dot in the middle as in the screen shot above, or if that’s not possible show the COOL setting when cooling, and the HEAT setting when heating and have the circle change colors.
                                        @pugsly It should work as requested now. I merged the branch with the master so you can just update the master now. If the text looks weird it’s probably because I don’t know css and just made up stuff until it worked on my screen.
                                          Here’s what it should look like for you.
                                          Nest Module
