    Email
    92 Posts 36 Posters 132.4k Views 39 Watching
      Phate
      Thats awesome
        ronny3050 Module Developer @Phate
        @Phate Thank you so much! :)
          Phate
          As soon as I get a chance I’ll give it a go… :-)
            @Phate said in Email:
            Let me know how it goes. There are a lot of problems, but I’d like you to test it. IMAP causes a lot of problems and isn’t as straightforward as I thought it would be! :(
              amanzimdwini @ronny3050
              @ronny3050
              Looks interesting.
              Request: Multiple email accounts?
              OR - better still since I just need the ALERT: any way I can just get a NUMBER of emails I need to read:
              joeshmoe@gmail.com - 17 unread
              suzieQ@public.com - 5 unread
              UncleSam@gov.com - 0 unread
              I’ll have a look at your module once I sort one other problem on my MM2 out.
                ronny3050 Module Developer @amanzimdwini
                @amanzimdwini Thank you!
                That seems very interesting. I will take a look at that and get back to you! It is definitely possible, however, I’d like to get an audio notification (on new incoming emails) working before I proceed.
                  @ronny3050
                  Thx. In the meanwhile: I’d like to change the font size you use for display to small/tiny (I have about a zillion emails in 12+ different accounts)… so I have to fix my custom.css
                  Judging from previous problems (look at the bottom of
                  https://forum.magicmirror.builders/topic/254/sachin-s-mirror/21
                  ) I stink at finding the properties myself - any hints would be most welcome.
                    @amanzimdwini
                    That’s a good idea. Note:
                    1. Number of emails to display is customizable and the default is 5.
                    2. Instead of enforcing people to play around with css, I can have a config property where you can set the font size as ‘big’, ‘medium’, ‘small’.
                    Please let me know when you get this module up and running, and whether the above helps.
                      @ronny3050
                      Git pull was easy.
                      npm install yielded
                      pi@MagicMirror2:~/MagicMirror/modules $ npm install
                      npm WARN enoent ENOENT: no such file or directory, open
                      '/home/pi/MagicMirror/modules/package.json'
                      npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/node_modules/node_helper/packa        ge.json'
                      npm WARN modules No description
                      npm WARN modules No repository field.
                      npm WARN modules No README data
                      npm WARN modules No license field.
                      I’ll go ahead, but thought you might want to know.
                      Note from admin: Please use Markdown on code and shell snippets!
                      R E 2 Replies Last reply Reply Quote 0
                        @amanzimdwini
                        I am sorry if my instructions weren’t clear, I’ll update the README. You need to run “npm install” inside the “email” folder.
                        A 1 Reply Last reply Reply Quote 1
                        • 10
                        • 1 / 10
