    MMM-MyScoreboard
    277 Posts 60 Posters 650.4k Views 63 Watching
      j.e.f.f Project Sponsor Module Developer @emlowe
      @emlowe I haven’t been able to reproduce the first issue you are seeing… still a few things for me to try, so stay tuned.
      Meanwhile, I was able to track down the second issue. I published v2.0.1 to address that.
        @emlowe I’ve done more testing on this… still can’t reproduce it.
        Can you verify that you ran npm install in the MMM-MyScoreboard directory after you updated to the new version? Dependencies have changed, and MM will throw an error if you haven’t done so.
        Here is what I have tried so far, all with MMM-MyScoreboard using the default config:
        MM v 2.1.2 normal mode
        MM v 2.1.2 server only mode
        MM v 2.1.3 normal mode
        MM v 2.1.3 server only mode
        The error message you’re seeing makes reference to MMM-Remote-Control, so I installed that module then ran the above two 2.1.3 scenarios again, and I didn’t run into the issue.
        Interestingly, the error is starting with MMM-Remote-Control’s node_helper module, first on line 211:
        self.loadModuleDefaultConfig(currentModule, modulePath);
        then on line 254:
        var jsfile = require(filename);
        I don’t really know how the remote control module works, but it appears to be enumerating the modules to list in its UI, when you can turn them on and off individually. Can you try disabling MMM-Remote-Control temporarily to see if the problem goes away?
        • emloweE
          emlowe Module Developer
          Sorry for the delay in responding. Yes you fixed the one error and the other error is caused by some interaction with MMM-RemoteControl.
          Feature Request - I’d like it to say “No Games” or “No Games for selected teams” rather than just not showing anything
          Thanks - great module!
          • N
            nevint
            Hey there, I just noticed that the times listed for upcoming games appear to be Eastern Time, whilst my MM is showing the time as Mountain Time, which is correct. Any way to change that?
            J 1 Reply Last reply
              j.e.f.f Project Sponsor Module Developer @nevint
              @nevint The module is supposed to convert the game’s start time to whatever the local time zone is set for the mirror – basically so you know when you will start to see it live. e.g.: If the start time of the feed is 7:00 pm Pacific time, but if your mirror is is set to Eastern time, the mirror will display 10:00 pm as the start time.
              Just so I understand what you’re asking, your mirror is displaying the start times as mountain time, but you’d like to see the start times in Eastern Time regardless of what time zone your system is set to? Or are you expecting to see Mountain Time for the start times but instead are seeing Eastern? What time zone is your mirror set to?
              N 1 Reply Last reply
              • N
                nevint @j.e.f.f
                @j.e.f.f The mirror is set to MST (the clock module shows the correct time, so I assume it is set to MST!) but the upcoming games display in EST. For instance, the Roughrider game tonight shows a start time of 10pm, but it will start at 8pm MST.
                  @nevint ah I see. so the times aren’t being converted as expected… I’ll take a look.
                  • N
                    nevint @j.e.f.f
                    @j.e.f.f Correct sir! Thanks for checking!
                      @nevint Tracked it down. It affected all leagues using the using the SNET provider (NFL, MLB, CFL, NHL, MLS). ESPN leagues (NBA, NCAA) were fine. do a git pull and let me know if it fixes the issue for you.
                      N 2 Replies Last reply
                      • N
                        nevint @j.e.f.f
                        @j.e.f.f Bingo!! Worked like a charm! Thank you very much!!!
                        • L
                          Laserturtle
                          Just wanted to say thanks for your work on this module. Been using it for a while now and it is great!
                          • N
                            nevint @j.e.f.f
                            @j.e.f.f Now another strange issue, the CFL/NHL scores are not showing up. The only scores coming in are NBA.
                              @nevint Seems to be an issue with Sportsnet’s feed. I just went to Sportsnet’s website and the scoreboard at the top has the same issue.
                              e.g.: http://www.sportsnet.ca/hockey/nhl/
                              • N
                                nevint @j.e.f.f
                                @j.e.f.f Yeah it’s strange. The SN site appears to be working (at least for me) but the scores still don’t update on my MM.
                                J 3 Replies Last reply
                                  @nevint I’ll keep an eye on it tonight during the hockey game.
                                  I’m using the feed the powers the scoreboard across the top of the screen, which appears to operate independent of the scores in the body of the page. It’s the top scoreboard feed in particular that’s having problems, while the scores on the main part of the screen are working fine.
                                    @nevint GRRR!!! Sportsnet changed their feed URL… need to make an update
                                      @nevint k. do a git pull. I updated the URL and it looks like it still works fine. Hopefully it’s just the URL change and not a formatting change.
                                      • N
                                        nevint @j.e.f.f
                                        @j.e.f.f That fixed it! Hopefully they don’t change the url too often! Thanks for the update!
                                          @nevint I’m seeing a few parsing errors in my log… I’m starting to lose confidence that I can continue to use the SNET feed long term… trouble it’s my only option to include CFL without an API key…
                                          • lucallmonL
                                            lucallmon
                                            @j.e.f.f I’m loving the module. Do you think there’s any way to group NCAAF teams into conferences? I primarily focus on SEC teams and would like to see them all grouped together separate from my other favorite teams/sports. Or perhaps have the AP Top 25 ranked teams in their own group?
                                            Thoughts?
                                            J 2 Replies Last reply
                                            • 13
                                            • 14
                                            • 4 / 14
