    RetroPi
    7 Posts 4 Posters 3.9k Views 4 Watching
      bincorp
      I was thinking I’d be pretty slick if it was in like a iframe type thing.
      The mirrors made already… or else the two screen idea is pretty good.
      Is there a way to have On screen buttons on the MM to boot up apps?
        j.e.f.f Project Sponsor Module Developer @bincorp
        @bincorp I’m not sure how well this would work. Neither RetroPie nor the game emulators work in an HTML interface – an iframe probably wouldn’t work for this. But you might be able to get this to work full screen, with some kind of reaction to a button press.
        From what I understand about the RetroPie image, however, is I don’t think it works with the Raspbian desktop enabled. I believe it runs from the command line with it’s own UI. You would likely have to have some kind of script to stop MM and Pixel Desktop, then start RetroPie and EmulationStation, then another to reverse that process when you exit RetroPie.
        You might want to spend some time in the RetroPie forum and ask some questions there.
        https://retropie.org.uk/forum/
        • O Offline
          onetwankyfive
          I just put another pi behind my screen, and change the input to HDMI 2 … Since the screen is vertical, pacman and galaga work well
            j.e.f.f Project Sponsor Module Developer @onetwankyfive
            @onetwankyfive Does your screen support picture-in-picture? If so, you could superimpose HDMI 2 over the MagicMirror’s display. This way you could create a similar affect that you were trying to do with the iFrame solution.
            • O Offline
              onetwankyfive
              I think most TV’s don’t support PiP with 2 HDMI sources… its gotta be like a component and HDMI or tuner and HDMI… I like it full screen anyways
