    EoF's Touch Screen Magic Mirror (95% Completed)
    23 Posts 13 Posters 33.5k Views 16 Watching
      Phate @shgmongohh
      @shgmongohh
      This I think but not sure about the touch side.
      https://forum.magicmirror.builders/topic/38/simple-music-player-module
      • E Offline
        EoF
        Hi! Sorry, I did not see your reply @shgmongohh. Yes, it is simply my music player module.
          chrissttian
            chrissttian @EoF
            @EoF
            Hey Mark.
            I just want to say…WOW!
            Amazingly good!
            Can you please tell me where you find the two way mirror film and the touch screen frame??
            Thank you Mark!
            • E Offline
              EoF @chrissttian
              @chrissttian Hi.
              Touch screen kit: http://www.aliexpress.com/item/21-5Inch-Resistive-Touch-Screen-Panel-490x285mm-4Wire-USB-kit-for-21-5-monitor/32429848194.html
              Mirror film: https://www.amazon.com/One-Mirror-Silver-Silver-CHROME-Film/dp/B00NBXFA7G/ref=sr_1_3?ie=UTF8&qid=1469284739&sr=8-3&keywords=2+way+mirror+film
              (not exactly what I bought but something similar. This should work though I think).
                chrissttian @EoF
                @EoF Thank you so much for the info!
                Can you please give me the exact mirror film you use?
                I ask you this because your mirror looks perfect.
                Thank you again!
                • E Offline
                  EoF @chrissttian
                  @chrissttian Luckily I still had it in my order history
                  https://www.amazon.com/gp/product/B00NDWILJE/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
                    chrissttian @EoF
                    @EoF thank you again man!
                    I will order soon.
                    Did you applied the film directly on tv? How you manage to have a perfect fit and a perfect reflection?
                    Thank you!
                    • E Offline
                      EoF @chrissttian
                      @chrissttian The film is applied on the touch screen panel kit, not on the monitor itself. The touch works behind the mirror film since it is a resistive touch screen and works via pressure.
                      I used a credit card to squeegee the film on the panel, but I highly highly recommend using an actual “smoothie squeegee” as seen in the below video at 5:12. The credit card works okay, but it is way more prone to scratching the film (which my mirror actually does have some small scratches on it because of this).
                      https://www.youtube.com/watch?v=B22QdNHtb_8
                      I generally just followed this video for applying the film. Just instead of a window, you’re applying it to the touch screen panel.
                      • K Offline
                        konnorbeard
                        @EoF thanks for sharing your progress so far - looks great. What’s the best way that you’ve found to implement touch on the software side of things? Do you just have some javascript touch events setup in main.js that just search the DOM tree at that spot and forward a notification to the appropriate module?
                        • E Offline
                          EoF @konnorbeard
                          @konnorbeard They are simply click events. A touch is nothing more than a click. The mouse is just hidden, so you can’t see it.
                          oh and, thank you!
                            sorpionking674
                            is the kit multitouch?
                              bhepler Module Developer @sorpionking674
                              @sorpionking674 He said it was a resistive touch panel, so I suspect not.
                              • cowboysdudeC Offline
                                Looks really awesome… keep us up to date please… this is what I’m going to do for my 40" livingroom ‘control’ center ;)
                                • I Offline
                                  in_a_days
                                    PindaPower
                                    The old topic and this one, are around for some time but I’m just finding out. I’m loving the work that you made and would like to now where you bought your product and if you like them? The connect issue is in the past and think @EoF mirror is still running great!!
                                    Myself would love a version 2 off my mirror and touch screen is a nice upgrade :)
