    Simple Music Player Module
    musicaudioplayer
    41 Posts 19 Posters 56.9k Views 21 Watching
      broberg Project Sponsor @dbaler
      @dbaler My higly noobish answer is Samba, and mount a network folder.
      D 1 Reply Last reply
        dbaler @broberg
        @broberg Just change the directory in which JS file?
        B 1 Reply Last reply
          @dbaler If you are not using the default Music folder you could actually mount your network folder directly in that folder. No need to alter anything in the js files
          Here is a easy to follow tutorial on how you mount a smb share in linux :
          https://www.howtogeek.com/176471/how-to-share-files-between-windows-and-linux/
            Preve @cowboysdude
            @cowboysdude Is that “show list” already available?
            • aro28A
              aro28
              Hi Eof,
              Do you know why mm-music-player module is not loading even i added below code to config file? I downloaded and copied mm-music-player folder to MM’s Modules folder. Do i need to do something else?
              module: ‘mm-music-player’,
              position: ‘bottom_left’,
              startingVolume: 20,
              fadeDuriation: 2000
              Thank you!
                DrCastor
                Hi aro28,
                I had the same problem, so I decided to take a look at why this module couldn’t be loaded.
                The issues is in the Node_Helper.js given, which is mistaken. The structure is wrong. It looks like a quick adaptation of a ctrl+C/ctrl+V made from index.js, found in the node_helper folder (MM core folders).
                I’m actually tweeking it a bit. I’ll give you news when i get it worked nicely.
                (In fact, it seems i can now load it, but since my speaker are broke, i cant be sure it reads files… I’ll change them tomorrow)
                aro28A 1 Reply Last reply
                • aro28A
                  aro28 @DrCastor
                  @DrCastor
                  Great! Thank you for reply. I hope you will succeed.
                    DrCastor
                    Ok, found bad speakers, but at least, they allow me to test it. It works :). I’m a real noob, so some useless things may still be there. But at least, it will do the trick
                    Go to the node_helper.js file, and change it this way:
                    var Class = require("../../js/class.js");
                    var express = require("express");
                    var path = require("path");
                    	init: function() {
                    		console.log("Initializing mm-music-player module helper ...");
                    	start: function() {
                    		this.expressApp.get('/music', function (req, res) {
                    			var fs = require('fs');
                    			var path = require('path');
                    			var files = [];
                    			fs.readdir('modules/mm-music-player/music', (err, data) => {
                    				for(i = 0; i < data.length; i++){
                    					if(path.extname(data[i]) == ".mp3"){
                    						files.push(data[i]);
                    				res.send(files);
                    	/* setExpressApp(app)
                    	 * Sets the express app object for this module.
                    	 * This allows you to host files from the created webserver.
                    	 * argument app Express app - The Express app object.
                    	setExpressApp: function(app) {
                    		this.expressApp = app;
                    		var publicPath = this.path + "/public";
                    		app.use("/" + this.name, express.static(publicPath));
                    If luck is by your side, it will work ;)
                    • aro28A
                      aro28 @DrCastor
                      @DrCastor said in Simple Music Player Module:
                      Could you please send a full code of “node_helper.js” file?
                      Thanks in advance,
                        DrCastor
                        It seems that I don’t have enough priviledges for uploading a file directly in this reply, and I don’t really want to provide you a link to some uploading site, since I don’t know if it is allowed in the rules of this site. I’ll try to find a way.
                        Since then, just try what I told you. You juste have to cut and paste what I wrote. I’m sure you can do it, be confident in yourself ;)
                        • aro28A
                          aro28 @DrCastor
                          @DrCastor
                          Manay thanks!
                          Resolved.
                            DrCastor
                            Happy to have helped you :). It is sad that just for a problem of syntax, the source file was never edited :$
                            • aro28A
                              aro28 @DrCastor
                              @DrCastor
                              Last question.
                              Do you know how to write a code for a volume buttons for that player?
                              I know that “MMM-TouchPlayerBasic” module has that feature.
                                DrCastor
                                no, I’m a noob in this. You should take a look at the files of MMM-TouchPlayerBasic, and try to enderstand how the volume is managed. Good luck!
                                  Milk
                                  would it be possible to make it so I could use a keyboard to control the music?
                                  • aro28A
                                    aro28 @Milk
                                    @Milk
                                    I use the built-in Monitor’s hard buttons to control the sound.
                                    There’s “alsamixer” command to control volume. But this is not convenient.
                                      Milk
                                      			'use strict';
                                      			var playingnow = false;
                                      			document.addEventListener('keypress', (event) => {
                                      				const keyName = event.key;
                                      				if(keyName == " " && playingnow == false){
                                      					$(audioElement).trigger('play');
                                      					$(currentlyPlaying).html(songs[current]).fadeIn(fadeDuriation);
                                      					playingnow = true;
                                      				}else if(keyName == " " && playingnow == true){
                                      					$(audioElement).trigger('pause');
                                      					$(currentlyPlaying).fadeOut(fadeDuriation);
                                      					playingnow = false;
                                      				if(keyName == "."){
                                      					next();
                                      				if(keyName == ","){
                                      					back();
                                      I have added this code to the mm-music player.js and it now accepts key presses
                                        Rolandb
                                        Hi Guys,
                                        I have a problem with the MM-Music_player module.
                                        I just can not get it to work.
                                        No matter what I do. I’ve already tried with the proposed solutions from you, but it does not work.
                                        I do not even know if I have the module installed correctly nor where I need to add it everywhere (config.js, defaultmodules.js)
                                        I am grateful for any help.
                                        • aro28A
                                          aro28 @Rolandb
                                          @Rolandb
                                          Hi, are you still facing the issue?
                                          • 2 / 3
