    After Update to 2.1.3 nothing works anymore
    9 Posts 3 Posters 3.6k Views 3 Watching
      Mykle1 Project Sponsor Module Developer @fischi87
      @fischi87 said in After Update to 2.1.3 nothing works anymore:
      when i stop pm2 and start with
      DISPLAY=:0 npm start
      i get no error but i can not load the page on the port.
      Wait, are you running node server only? You didn’t mention that.
      what happened after the update of 2.1.3?
      I don’t know. I just work here. :^)
      • F Offline
        fischi87
        What do u mean?
        I Start my mirror with pm2 automatic.
        Befor Update everything works will. I just did
        git pull && npm install
          I’m not sure what you’re asking. Are you trying to view/administer the mirror remotely and you are being refused access?
          Or are you connected directly to the Pi and nothing is loading?
          • F Offline
            fischi87
            Good Morning,
            I Start my pi and normaly i can Go to the local page with ip:8090 but this page dosend work. When i do
            pm stop all
            And Start the mirror with
            DISPLAY:=0 npm start
            Then it Starts the run Script and load every modules i have but it dosent load the page at ip:8090, i get no awnser.
            • lavolp3L Offline
              lavolp3 Module Developer
              Have you added the following line to your config?
              var config = {
                      port: 8080,
                      address: "0.0.0.0",
              (the last one)
              With newer versions, you apparently need this line for being able to connect to the server side of the mirror.
              Has been discussed here in some thread.
              This solved the same problem for me.
              How to troubleshoot modules
              MMM-soccer v2, MMM-AVStock
              • F Offline
                fischi87
                Yes this is the Solution, thanks a lot. I read it also in a other topic.
