    Motion Detection with RaspiCam, Non-Module version
    47 Posts 13 Posters 56.0k Views 17 Watching
    • KimzerK
      Kimzer
      Ah my bad, poorly formulated on my end here.
      I am able to take snapshots, and i have gotten the camera to work just fine itself. It is the motion part i am struggling with.
      But i will have to test some more.
      • F
        Freebond
        • N
          Natacha3 @bhepler
          @bhepler It works perfectly !
          Thank you so much for sharing !
            stangarrang
            @bhepler I was hoping you could give me a hand. I’ve got your motion working but. Pm2 is not auto starting the motion. Everything is working fine if I manually “pm2 start motion” and " pm2 start mm" and I’ve tried adding @pm2 start motion to my auto start along side my “pm2 start mm” but that only breaks both processes. I’m trying to get both the magic mirror and the motion to auto start upon reboot.
            B 1 Reply Last reply
              bhepler Module Developer @stangarrang
              @stangarrang Sure, no problem. Quick question: Did you enter pm2 save after you started both the motion and the Magic Mirror processes?
                stangarrang
                @bhepler yes that was one of the first things I did but after reboot nothing was saving. Actually just as you replied I went through a couple steps for pm2 startup plus the command that came after. After that I did a pm2 save and now things are working well :) thanks for your prompt reply!
                • A
                  AnduriI
                  is it possible to use Motion to activate the screen and MMM-Facial-Recignition simultaneously? Maybe also use the on_event_start to activate some lights in the front of the MM to increase image quality…
                    bhepler Module Developer @AnduriI
                    @AnduriI It should be. The motion system will operate independently of the mirror and only controls the signal running down the HDMI cable to the monitor. The Pi camera and the Magic Mirror process are still running.
                    If you create a simple python script to control the pinouts on the Pi, you should be able to switch on some simple LED lights to illuminate the front of the mirror.
                      dam4
                      @bhepler
                      Hello, I am a true n00b and I am having issues with your process for getting the Pi camera to work. I copied and pasted your first line exactly and I get the following.
                      pi@raspberrypi:~ $ sudo apt-get install -y libjpeg-dev libavformat56 libavformat-dev libavcodec56 libavcodec-dev libavutil54 libavutil-dev libc6-dev zlib1g-dev libmysqlclient18 libmysqlclient-dev libpq5 libpq-dev
                      Reading package lists... Done
                      Building dependency tree
                      Package libmysqlclient-dev is not available, but is referred to by another package.
                      This may mean that the package is missing, has been obsoleted, or
                      is only available from another source
                      Package libmysqlclient18 is not available, but is referred to by another package.
                      E: Unable to locate package libavformat56
                      E: Unable to locate package libavcodec56
                      E: Unable to locate package libavutil54
                      E: Package 'libmysqlclient18' has no installation candidate
                      E: Package 'libmysqlclient-dev' has no installation candidate
                      pi@raspberrypi:~ $
                      What did I do wrong? Please help and thank you in advance.
                      Y 1 Reply Last reply
                      • Y
                        yawns Moderator @dam4
                        @dam4
                        Are you running raspbian Jessie or Stretch?
                        Looks like the names where changed
                        Jessie: https://packages.debian.org/jessie/libmysqlclient-dev
                        Stretch: https://packages.debian.org/stretch/default-libmysqlclient-dev
                        D 1 Reply Last reply
                          dam4 @yawns
                          @yawns I am pretty sure I am running Jessie. How do I know for sure?
                          • Y
                            @dam4
                            In the terminal run cat /etc/os-release
                            Maybe you need to run sudo cat /etc/os-release
                              dam4 @yawns
                              @yawns
                              It looks like I am running stretch. This is what I get;
                              pi@raspberrypi:~ $ cat /etc/os-release
                              PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
                              NAME="Raspbian GNU/Linux"
                              VERSION_ID="9"
                              VERSION="9 (stretch)"
                              ID=raspbian
                              ID_LIKE=debian
                              HOME_URL="http://www.raspbian.org/"
                              SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                              BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                              pi@raspberrypi:~ $
                              J 1 Reply Last reply
                                jasonarends @dam4
                                @dam4 I had the same problem and couldn’t get the correct dependencies resolved, but I just got it to work on stretch by following the Abbreviated Building Guide instructions here: http://htmlpreview.github.io/?https://github.com/Motion-Project/motion/blob/master/motion_guide.html
                                I had already tried the way you did so I had the motion.conf from the other build which I had modified, and it worked with that version.
                                edit:
                                sudo apt-get install autoconf automake build-essential pkgconf libtool libzip-dev libjpeg-dev git libavformat-dev libavcodec-dev libavutil-dev libswscale-dev libavdevice-dev
                                cd ~
                                git clone https://github.com/Motion-Project/motion.git
                                cd motion
                                autoreconf -fiv
                                ./configure
                                make
                                make install
                                  dam4 @jasonarends
                                  @jasonarends
                                  I just tried git clone https://github.com/Motion-Project/motion.git and it tells me this;
                                  fatal: destination path ‘motion’ already exists and is not an empty directory.
                                  I did a ls -al and it doesn’t show up as a directory. Should I remove the ‘motion’ that is in green from the home directory and try again?
                                  I have to go to work so I will have to work on this tomorrow. Thank you for your help.
                                    jasonarends @dam4
                                    @dam4
                                    yep, you have the original motion binary in your home directory still, you can just remove that.
                                    D 2 Replies Last reply
                                      dam4 @jasonarends
                                      @jasonarends
                                      Thank you for your help. I have tried this and it seemed to install. The only thing I had an issue with was when I entered make install it would not create a directory and it failed. I then ran it as sudo make install and it seemed to install. I am running my MagicMirror now to see if it works. How long does it take to turn the monitor off? Again thank you for your help.
                                        dam4 @jasonarends
                                        @jasonarends
                                        How long does it take for the screen to blank out? So far the screen has stayed on and hasn’t even flickered. I have something in front of the Pi camera so it doesn’t pick up any movement and it has been over an hour now. Please help.
                                          jasonarends @dam4
                                          @dam4
                                          Hi, make sure that you’ve edited your motion.conf file that it is using according to the instructions in the original post:
                                          framerate 4 - run the detection video at 4 frames per second
                                          threshold 2500 - increase the # of pixels to trigger the screen. We want them to get close to the mirror
                                          minimum_motion_frames 2 - Motion must be detected in 2 consecutive frames (at 4 FPS)
                                          event_gap 60 - This is important. This is how long in seconds after no motion the screen will turn off.
                                          output_pictures off - Do not save images
                                          ffmpeg_output_movies off - Do not record video
                                          stream_port 0 - Turn off remote viewing
                                          webcontrol_port 0 - Turn off HTTP control of camera
                                          on_event_start vcgencmd display_power 1 - Important! This is the command to turn on the screen
                                          on_event_end vcgencmd display_power 0 - Important! This is the command to turn off the screen
                                          I’ve copied my config here: https://pastebin.com/61hiygKX (edit: updated conf)
                                          If you put motion.conf in /etc/motion it should pick it up by default without having to specify anything.
                                          Make sure you’ve set the event_gap, on_event_start, and on_event_end at the very least for testing.
                                          You can also just try running the command
                                          by itself to make sure the command works to turn off the monitor.
                                            dam4 @jasonarends
                                            @jasonarends
                                            My motion.conf is located in my home directory. I looked for /etc/motion and I don’t have a directory called motion in /etc. So I made one and put motion.conf in there. My screen still doesn’t shut off. I did look over my motion.conf file and all my settings were exactly like yours. I did follow all the steps at the beginning of this post. I can also type in vcgencmd display_power 0 and it turns off the monitor and vcgencmd display_power 1 turns it back on. This is really getting frustrating. Thank you for your help.
                                            I also copied your updated_motion.conf.sh and double checked it and they match with the exception yours has a .sh at the end where mine does not. Is it supposed to have the .sh on the end of the file name or did it get added due to it being uploaded?
                                            • 2 / 3
