    How I got my Magic Mirror working on a Raspberry Pi 0 (zero)
    raspberry pipi0zeropizeropi1
    204 Posts 47 Posters 654.2k Views 47 Watching
      Doubleve
      I took everything back with the first post everything works !!!
      H 1 Reply Last reply Reply Quote 1
      • H Offline
        Hawking @Doubleve
        @Doubleve
        Can you tell me which Linux distribution (lsb_release -a), node version ( node -v ) and version of MM you are using?
          delusional112
          Hi guys, I saw someone asked before, isn’t there anyone who has a working image for MM2 on a Pi Zero. I tried a lot of things before, cant get it to work. Now, I don’t have a lot of time to experiment with it, school and work are killing me. My mirror is lying around, unused. Please help me out here,
          Thanks!!
          • N Offline
            noorm91 @delusional112
            @delusional112
            Here is an image, it has a couple of errors that needs fixing but the magicmirror starts at least.
            If you have any solutions please keep us informed…this image is made by Sebtota.
            https://mega.nz/#!XlIU3QjI!QSdvAE3yXp1oMsdRGNte6lt4SncgvfozSDU7xhxtbbM
            Here is the topic I found the image at.
            https://forum.magicmirror.builders/topic/1183/how-i-got-my-magic-mirror-working-on-a-raspberry-pi-0-zero/85?page=9
            • N Offline
              noorm91
              Any clue on what is trying to start and not functioning alright here?
              Starting MagicMirror: v2.1.0
              Loading config ...
              Loading module helpers ...
              All module helpers loaded.
              Starting server op port 8080 ...
              Server started ...
              Starting module: newsfeed
              Ready to go! Please point your browser to: http://localhost:8080
              { [Error: listen EADDRINUSE :::8080]
                code: 'EADDRINUSE',
                errno: 'EADDRINUSE',
                syscall: 'listen',
                address: '::',
                port: 8080 }
              (EE)
              Fatal server error:
              (EE) Server is already active for display 0
                      If this server is no longer running, remove /tmp/.X0-lock
                      and start again.
              (EE)
              (EE)
              Please consult the The X.Org Foundation support
                       at http://wiki.x.org
               for help.
              (EE)
              XIO:  fatal IO error 11 (Resource temporarily unavailable) on X server ":0"
                    after 7 requests (7 known processed) with 0 events remaining.
                bhepler Module Developer @noorm91
                @noorm91 said in How I got my Magic Mirror working on a Raspberry Pi 0 (zero):
                Whoops! There was an uncaught exception…
                8080]
                This usually means that you already have a process trying to serve up web pages on port 8080. In my experience, this happens when you do not terminate your previous attempt to run the MM process and start up another one. The new one also tries to serve up pages on port 8080 and you get that error.
                You can use ps ax | grep node to see if node is running when you attempt to start your mirror. If it is, node is already serving up pages, so you will want to stop whatever process is running first. Alternately, if you are running a web server on port 8080 already, you can switch the port of the MM process in the config.js file.
                • MarWindM Offline
                  MarWind
                  So did anyone get MM2 on a Pi Zero W with Raspian Stretch lite running?
                  Or is it better to stay with Jessie?
                  ~ride bikes and boards not always on top~
                  • H Offline
                    Hawking @MarWind
                    @MarWind
                    I still didn’t get it to work using Midori in combination with Raspian Stretch Lite.
                    On this distribution, I could only get it to work using Epiphany or Chromium. However, their performance is much slower than Midori (which worked fine in Jessie Lite). I can’t tell if this is due to some general changes in Stretch or in the newer versions of Midori.
                    • N Offline
                      noorm91
                      How did you install Chromium on rpi 0 ?
                      • MarWindM Offline
                        MarWind
                        @hawking, thanks for your answer!
                        I’ll do some more testing:
                        *So my main issue will be now the update of mm2 :-(
                        I’m running an working image on the pi zero w with npm 2.14 and node 4.2.1 for month’s now.
                        But after updating MM2 last week with git pull && npm install it’s broken :-(
                        • H Offline
                          Hawking @noorm91
                          @noorm91
                          I simply did
                          sudo apt-get install chromium-browser
                          and the start is by
                          chromium-browser --incognito --kiosk http://localhost:8080
                          I don’t know if this is a new possibility in Stretch light or is also possible in Jessie Lite (I know that there were some issues in the past). However, as I said, the performance is slow and not stable (I see that the free amount of memory gets low and the system freezes every few hours). Therefore I would prefer to use still Midori, whoch worked fine for me in Jessie. However, using Midori with Stretch I simply get a black screen. I don’t know if this is due to an error in my installation, due to changes from Jessie to Stretch, due to changes in the Midori browser, due to changes in MM (I tried to install an older version, which didn’t help) or yet another reason.
                            Parth Bhandari
                              Parth Bhandari @Kobie
                              @Kobie said in How I got my Magic Mirror working on a Raspberry Pi 0 (zero):
                              sudo npm install
                              Thanks. I was stuck on the 6th step.
                              Andrius okA 1 Reply Last reply Reply Quote 0
                              • Andrius okA Offline
                                Andrius ok @Parth Bhandari
                                @Parth-Bhandari check this thread https://forum.magicmirror.builders/post/32731
                                • L Offline
                                  lasharor @Andrius ok
                                  Couldn’t get this to work at all on the new distro:
                                  (chromium-browser:1470): Gtk-WARNING **: cannot open display:
                                  I’ll check if the image works for me.
                                  @Andrius-ok would be nice if you could create and upload an image.
                                    PipoloyJo
                                    Hi everyone, I did not read all 16 pages of this thread but I successfully setup my MM on a Raspberry Pie Zero W, following this answer https://forum.magicmirror.builders/topic/1183/how-i-got-my-magic-mirror-working-on-a-raspberry-pi-0-zero/8
                                    I decided to compile all instructions in a basic bash script since some of these steps can be quite long to execute: https://github.com/PipoloyJo/MMConfig/blob/master/setup-mirror.sh
                                    Maybe someone else has already done the same, but I did not found it.
                                    Only difference so far is the use of chromium over midori (I got some issues setting it up).
                                    Thanks for this thread!
                                    L 1 Reply Last reply Reply Quote 2
                                      Andrius ok @lasharor
                                      @lasharor did you using Raspberry Pi Zero W ?
                                      • L Offline
                                        @Andrius-ok Yes.
                                        Tried the Image also. works fine after upgrading. Was not succesfull upgrading magicmirror however. Trying PipoloyJo solution now.
                                          @lasharor ok tomorrow I will share the image
                                          • L Offline
                                            lasharor @PipoloyJo
                                            @PipoloyJo So I also tried this. Can you please specify which distro you are using? As this is not working on Jessie.
                                            Also the script should contain apt-get upgrade in the beginning. Otherwise you’ll not be able to download most packages due to incorrect links.
                                            Trying now on stretch.
                                            Edit: having problems with rpi-update (or upgrade), will not download the full image can’t run chrome in sandboxed mode. So tried to run MM by disabling sandboxed mode. End up with working Chrome but blank black screen.
                                            • 10
                                            • 11
                                            • 8 / 11
