    [Solved] MagicMirror ignoring zoom and font-size css
    7 Posts 3 Posters 4.9k Views 3 Watching
      dikkedimi @Mykle1
      @Mykle1 said in MagicMirror ignoring zoom and font-size css:
      @dikkedimi said in MagicMirror ignoring zoom and font-size css:
      I’ve tried everything I can think of
      Have you tried these key commands while MM is running and displayed on screen?
      Simultaneously pressing:
      Control and - (that’s a dash/minus key) For Zoom out
      Control and Shift and = For Zoom in
      Control and 0 (that’s a zero) For default size
      Thank you so much! Did indeed not think of that, as I assumed (never having used the browser on this machine), the default was set to 0 zoom.
      This seems to have fixed the problem, hitting ctrl+0 gave the desired element sizes. It even persists through reboot.
      Can you clarify why this fixed it?
        Mykle1 Project Sponsor Module Developer @dikkedimi
        @dikkedimi
        You’re welcome. You may have inadvertently hit the key command that zooms the display and as you see it persists through reboot, but who can say?
        All these key commands can be found in Menu bar while MM is running by pressing your Alt key.
          dikkedimi @Mykle1
          @Mykle1 said in [Solved] MagicMirror ignoring zoom and font-size css:
          @dikkedimi
          Useful info, hope it helps others as well!
          • yawnsY Offline
            yawns Moderator
            Today I picked up my raspberry again, played around with the installation including zoom in config.js. Then I saw there were 332 changes, so I ran a git pull & npm install and afterwards everything was totally tiny. Removing zoom from the config.js file did not help. Then I remembered I saw something related some days ago on this forum. Thank you mykle.
              Mykle1 Project Sponsor Module Developer @yawns
              @yawns said in [Solved] MagicMirror ignoring zoom and font-size css:
              Thank you mykle.
              Fantastic! You’re welcome. :-)
              I put this together the other day for easy referral.
              https://forum.magicmirror.builders/topic/5619/how-to-find-and-use-key-commands-in-mm-for-absolute-beginners
