Possible sytax error in my config.js file?
(Resubmitted to remove personal info) I’m probably just an idiot, but I can’t figure out what my syntax error is here. Does someone else see it?
/* Magic Mirror Config Sample * * By Michael Teeuw http://michaelteeuw.nl * MIT Licensed. * * For more information how you can configurate this file * See https://github.com/MichMich/MagicMirror#configuration * */ var config = { port: 8080, ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses // or add a specific IPv4 of 192.168.1.5 : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"], // or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"], language: "en", timeFormat: 24, units: "imperial", modules: [ { module: "alert", }, { module: "updatenotification", position: "top_bar" }, { module: "clock", position: "top_left" }, { module: "calendar", header: "Family Calendar", position: "top_left", config: { calendars: [ { symbol: "calendar-check-o ", url: "MY CALENDAR URL" } ] } }, { module: "compliments", position: "lower_third" config: { updateInterval: 30000, compliments: { morning: [ "Good morning, sunshine!", "Looking good!", "Go get em!", "You look great!", "Perfect circle!", "I bet you do the crossword in ink.", "You're more fun than bubble wrap!" ], afternoon: [ "What a gorgeous day!", "Looking good!", "Go get em!", "You look great!", "Perfect circle!", "I bet you do the crossword in ink.", "You're more fun than bubble wrap!" ], evening: [ "It was such a great day!" "Looking good!", "Go get em!", "You look great!", "Perfect circle!", "I bet you do the crossword in ink.", "You're more fun than bubble wrap!" ] } } }, { module: "currentweather", position: "top_right", config: { location: "New York", locationID: "", //ID from http://www.openweathermap.org/help/city_list.txt appid: "YOUR_OPENWEATHER_API_KEY" } }, { module: "weatherforecast", position: "top_right", header: "Weather Forecast", config: { location: "Frisco", locationID: "5422503", //ID from http://www.openweathermap.org/help/city_list.txt appid: "87ef9f3a1f3d7e4738344c85226dfd00" } }, { module: "newsfeed", position: "bottom_bar", config: { feeds: [ { title: "New York Times", url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml" } ], showSourceTitle: true, showPublishDate: true } }, ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== "undefined") {module.exports = config;}
Since there isn’t yet so much “customized” stuff in there, i would suggest, you start again with the dummy file provided in the /config folder.
Then add the first module, if this is working then, add the second… and so on.
Otherwise you will go crazy. -
Your problems are with the compliments module. You are missing a comma after
and another comma after"It was such a great day!"
in the evening array. -
Valid
/* Magic Mirror Config Sample * * By Michael Teeuw http://michaelteeuw.nl * MIT Licensed. * * For more information how you can configurate this file * See https://github.com/MichMich/MagicMirror#configuration * */ var config = { port: 8080, ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses // or add a specific IPv4 of 192.168.1.5 : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"], // or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"], language: "en", timeFormat: 24, units: "imperial", modules: [ { module: "alert", }, { module: "updatenotification", position: "top_bar" }, { module: "clock", position: "top_left" }, { module: "calendar", header: "Family Calendar", position: "top_left", config: { calendars: [ { symbol: "calendar-check-o ", url: "MY CALENDAR URL" } ] } }, { module: "compliments", position: "lower_third", config: { updateInterval: 30000, compliments: { morning: [ "Good morning, sunshine!", "Looking good!", "Go get em!", "You look great!", "Perfect circle!", "I bet you do the crossword in ink.", "You're more fun than bubble wrap!" ], afternoon: [ "What a gorgeous day!", "Looking good!", "Go get em!", "You look great!", "Perfect circle!", "I bet you do the crossword in ink.", "You're more fun than bubble wrap!" ], evening: [ "It was such a great day!", "Looking good!", "Go get em!", "You look great!", "Perfect circle!", "I bet you do the crossword in ink.", "You're more fun than bubble wrap!" ] } } }, { module: "currentweather", position: "top_right", config: { location: "New York", locationID: "", //ID from http://www.openweathermap.org/help/city_list.txt appid: "YOUR_OPENWEATHER_API_KEY" } }, { module: "weatherforecast", position: "top_right", header: "Weather Forecast", config: { location: "Frisco", locationID: "5422503", //ID from http://www.openweathermap.org/help/city_list.txt appid: "87ef9f3a1f3d7e4738344c85226dfd00" } }, { module: "newsfeed", position: "bottom_bar", config: { feeds: [ { title: "New York Times", url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml" } ], showSourceTitle: true, showPublishDate: true } }, ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== "undefined") {module.exports = config;}
@yawns That was it, thanks!
