    npm ERR! cb() never called! _ when trying to install MMM-RTSPStream
    6 Posts 2 Posters 5.0k Views 2 Watching
      shbatm Module Developer
      What version of node/npm are you using? And is this on a Raspberry Pi? The commands below will tell you the versions.
      node -v
      npm -v
      • cruunnerrC Offline
        cruunnerr
        hi,
        yes, its on a raspberry pi 3.
        pi@MagicMirror:~ $ node -v
        v6.12.2
        pi@MagicMirror:~ $ npm -v
        3.10.10
        edit:
        well, first it started to install something. i did it via ssh, so i changed to my browser to surf in the web while the raspberry is installing. When i looked back i just saw this message shown above.
          You may try and update node and npm then retry:
          Update npm:
          npm install -g npm
          Update node (should update npm too):
          sudo npm cache clean -f
          sudo npm install -g n
          sudo n stable
            cruunnerr
            @shbatm said in npm ERR! cb() never called! _ when trying to install MMM-RTSPStream:
            npm install -g npm
            as i typed in this, it started to install and shows this:
            npm ERR! Linux 4.9.59-v7+
            npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "-g" "npm"
            npm ERR! node v6.12.2
            npm ERR! npm  v3.10.10
            npm ERR! path /usr/lib/node_modules/npm/node_modules/abbrev
            npm ERR! code EACCES
            npm ERR! errno -13
            npm ERR! syscall access
            npm ERR! Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/abbrev'
            npm ERR!     at Error (native)
            npm ERR!  { Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/abbrev'
            npm ERR!   errno: -13,
            npm ERR!   code: 'EACCES',
            npm ERR!   syscall: 'access',
            npm ERR!   path: '/usr/lib/node_modules/npm/node_modules/abbrev' }
            npm ERR!
            npm ERR! Please try running this command again as root/Administrator.
            npm ERR!     /home/pi/npm-debug.log
            so i did it as root and rebooted my pi.
            now i installed your module and got some warnings AND some errors:
            pi@MagicMirror:~/MagicMirror/modules/MMM-RTSPStream $ npm install
            npm WARN registry Unexpected warning for https://registry.npmjs.org/: Miscellaneous Warning EINTEGRITY: sha1-QFUCsAfzGcP0cXXER0UnMA8qta0= integrity checksum failed when using sha1: wanted sha1-QFUCsAfzGcP0cXXER0UnMA8qta0= but got sha512-zr6QQnzLt3Ja0t0XI8gws2kn7zV2p0l/D3kreNvS6hFZhVU5g+uY/30l42jbgt0XGcNBEmBDGJR71J692V92tA==. (260 bytes)
            npm WARN registry Using stale package data from https://registry.npmjs.org/ due to a request error during revalidation.
            > MMM-RTSPStream@1.2.1 postinstall /home/pi/MagicMirror/modules/MMM-RTSPStream
            > ./install_sd_patch.sh && sudo npm i -g http-server
            Applying Graceful Shutdown patch to MagicMirror.
            error: Anwendung des Patches fehlgeschlagen: js/electron.js:96
            error: js/electron.js: Patch konnte nicht angewendet werden
            npm ERR! code ELIFECYCLE
            npm ERR! errno 1
            npm ERR! MMM-RTSPStream@1.2.1 postinstall: `./install_sd_patch.sh && sudo npm i -g http-server`
            npm ERR! Exit status 1
            npm ERR!
            npm ERR! Failed at the MMM-RTSPStream@1.2.1 postinstall script.
            npm ERR!     /home/pi/.npm/_logs/2017-12-22T17_39_55_666Z-debug.log
            edit:
            i took a look in the debug_log file after the reboot of the pi (2017-12-22T17_36_34_105Z-debug.log) :
            1 verbose cli [ '/usr/local/bin/node', '/usr/local/bin/npm', 'start' ]
            2 info using npm@5.6.0
            3 info using node@v9.2.1
            5 info lifecycle magicmirror@2.1.0~prestart: magicmirror@2.1.0
            6 info lifecycle magicmirror@2.1.0~start: magicmirror@2.1.0
            7 verbose lifecycle magicmirror@2.1.0~start: unsafe-perm in lifecycle true
            8 verbose lifecycle magicmirror@2.1.0~start: PATH: /usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirro$
            9 verbose lifecycle magicmirror@2.1.0~start: CWD: /home/pi/MagicMirror
            10 silly lifecycle magicmirror@2.1.0~start: Args: [ '-c', 'electron js/electron.js' ]
            11 silly lifecycle magicmirror@2.1.0~start: Returned: code: 1  signal: null
            12 info lifecycle magicmirror@2.1.0~start: Failed to exec start script
            13 verbose stack Error: magicmirror@2.1.0 start: `electron js/electron.js`
            13 verbose stack Exit status 1
            13 verbose stack     at EventEmitter.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:285:16)
            13 verbose stack     at EventEmitter.emit (events.js:159:13)
            13 verbose stack     at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
            13 verbose stack     at ChildProcess.emit (events.js:159:13)
            13 verbose stack     at maybeClose (internal/child_process.js:943:16)
            13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:220:5)
            14 verbose pkgid magicmirror@2.1.0
            15 verbose cwd /home/pi/MagicMirror
            16 verbose Linux 4.9.59-v7+
            17 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "start"
            18 verbose node v9.2.1
            19 verbose npm  v5.6.0
            20 error code ELIFECYCLE
            21 error errno 1
            22 error magicmirror@2.1.0 start: `electron js/electron.js`
            22 error Exit status 1
            23 error Failed at the magicmirror@2.1.0 start script.
            23 error This is probably not a problem with npm. There is likely additional logging output above.
            24 verbose exit [ 1, true ]
            could it be, that my downgrade to 2.1.0 is to blame?
              It may be the downgrade or a bug in the post install script for my module. Backstory: My module tries to install a patch to the main electron.js file on older MM versions so it can safely close the streams when you shut down the mirror - this is now included in the core MM code and is not installed if the code already exists.
              The errors with npm upgrade: it should be sudo before that line, that’s why you have a bunch of permission errore, but the node update took care of the npm update too.
              To fix the mirror install, replace MagicMirror/js/electron.js with a fresh copy from github for your version of MM to undo whatever the patch broke when it failed.
