    MMM-CalendarExt cant get the calendar to show
    23 Posts 8 Posters 15.8k Views 9 Watching
      A Former User @glitchgod
      @glitchgod
      Check pm2 log mm or npm start dev. Leave your error messages of terminal and browser dev console.
      In many cases, error(even from other modules) could prevent loading modules properly.
      cruunnerrC 1 Reply Last reply Reply Quote 0
      • G Offline
        glitchgod
        okay here it is
        pm2 log mm
        pi@MagicMirror:~ $ pm2 log mm --lines 1000
        [TAILING] Tailing last 1000 lines for [mm] process (change the value with --lines option)
        /home/pi/.pm2/logs/mm-error-0.log last 1000 lines:
        0|mm       |
        0|mm       | npm ERR! Linux 4.9.52-v7+
        0|mm       | npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start"
        0|mm       | npm ERR! node v6.11.4
        0|mm       | npm ERR! npm  v3.10.10
        0|mm       | npm ERR! code ELIFECYCLE
        0|mm       | npm ERR! magicmirror@2.1.3 start: `sh run-start.sh`
        0|mm       | npm ERR! Exit status 1
        0|mm       | npm ERR!
        0|mm       | npm ERR! Failed at the magicmirror@2.1.3 start script 'sh run-start.sh'.
        0|mm       | npm ERR! Make sure you have the latest version of node.js and npm installed.
        0|mm       | npm ERR! If you do, this is most likely a problem with the magicmirror package,
        0|mm       | npm ERR! not with npm itself.
        0|mm       | npm ERR! Tell the author that this fails on your system:
        0|mm       | npm ERR!     sh run-start.sh
        0|mm       | npm ERR! You can get information on how to open an issue for this project with:
        0|mm       | npm ERR!     npm bugs magicmirror
        0|mm       | npm ERR! Or if that isn't available, you can get their info via:
        0|mm       | npm ERR!     npm owner ls magicmirror
        0|mm       | npm ERR! There is likely additional logging output above.
        0|mm       |
        0|mm       | npm ERR! Please include the following file with any support request:
        0|mm       | npm ERR!     /home/pi/MagicMirror/npm-debug.log
        0|mm       | [811:1006/062246.323684:FATAL:bus.cc(1197)] D-Bus connection was disconnected. Aborting.
        0|mm       | #0 0x00000139f0c0
        0|mm       | #1 0x0000013ae0be
        0|mm       | #2 0x0000009d3172
        0|mm       |
        0|mm       | [812:1006/064303.600583:FATAL:bus.cc(1197)] D-Bus connection was disconnected. Aborting.
        0|mm       |
        0|mm       | [807:1006/065119.128269:FATAL:bus.cc(1197)] D-Bus connection was disconnected. Aborting.
        0|mm       |
        /home/pi/.pm2/logs/mm-out-0.log last 1000 lines:
        0|mm       | [DBXPIC] No scanned images in Dropbox.
        0|mm       | [DBXWLP] SCANNING: /home/
        0|mm       | [DBXWLP] SCANNING: /home/Apps/
        0|mm       | [DBXWLP] SCANNING: /home/Apps/background_pi_magicMirror
        0|mm       | [DBXWLP] SCANNING: /Apps/background_pi_magicMirror
        0|mm       | [DBXWLP] SCANNING: /background_pi_magicMirror
        0|mm       | [DBXWLP] DOWNLOAD_ERROR /background_pi_magicMirror
        and
        npm, start dev
        pi@MagicMirror:~ $ npm start dev
        npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start" "dev"
        npm ERR! code ENOENT
        npm ERR! errno -2
        npm ERR! syscall open
        npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
        npm ERR! enoent This is most likely not a problem with npm itself
        npm ERR! enoent and is related to npm not being able to find a file.
        npm ERR! enoent
        npm ERR!     /home/pi/npm-debug.log
          @glitchgod
          First. All of error messages [DBX...] are not related with CalendarExt. For clearer test, disable DropboxWallpaper.(and all other modules except for CalendarExt)
          Second, npm start dev should be run on your magic mirror directory(It might be ~/MagicMirror, not ~/)
          So, Just check again.
          npm start dev
          It could show your MM and an additional window for developer console. You might find error mark (red circled X mark and numbers, if exists). In that case, move to tab Console, you could see errors.
          • G Offline
            glitchgod
            @Sean said in MMM-CalendarExt cant get the calendar to show:
            r
            alright ran the dev mode in the proper directory
            the screen that showed up looks like the Chrome’s “F12” option
            There were no errors or issues highlighed or showing the X on them, however the calendar somewhat showed up in a weird way after i commented out everything but the calendar.
            It showed up in the bottom left with only "Tuesday /Wensday/ Thurday/ Friday " and a single calendar line.
            Picture proof
            Im still running with the Default script
              module: 'MMM-CalendarExt',
                    url: "http://mlb.am/tix/mariners_schedule_full"
            SSSoo some progress
            After letting the SSH run for a few minutes an error did show up
            Starting MagicMirror: v2.1.3
            Loading config ...
            Loading module helpers ...
            Module helper loaded: MMM-CalendarExt
            All module helpers loaded.
            Server started ...
            Connecting socket for: MMM-CalendarExt
            { Error: listen EADDRINUSE 127.0.0.1:8080
                at Object.exports._errnoException (util.js:1050:11)
                at exports._exceptionWithHostPort (util.js:1073:20)
                at Server.setupListenHandle [as _listen2] (net.js:1263:14)
                at listenInCluster (net.js:1304:12)
                at doListen (net.js:1428:7)
                at GetAddrInfoReqWrap.asyncCallback [as callback] (dns.js:62:16)
                at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:78:10)
              code: 'EADDRINUSE',
              errno: 'EADDRINUSE',
              syscall: 'listen',
              address: '127.0.0.1',
              port: 8080 }
            Launching application.
            pm2 log mm
              A Former User
              Ok, we are progressed.
              Try this. And you can know what was problem. ;)
                      system: {
                        show: ['month'],
                      views: {
                        month: {
                          position:'bottom_bar',
                      calendars :[
                          url:"http://mlb.am/tix/mariners_schedule_full"
                A Former User
                Ok. I tell you the truth.
                there is no more schedule for Seatle Mariners in this month. That is why empty frame is shown.
                Try this url : https://ics.fixtur.es/v2/eintracht-frankfurt.ics
                And, Port error is not related with modules (I think)
                • G Offline
                  glitchgod
                  Alright it’s up and running.
                  Thank you Sean
                  the steep by steep fix you have given was excellent :)
                  • G Offline
                    glitchgod
                    After re enabling all the modules it seems
                    “MMM-ethereum”
                    causes it not to show up.
                    The way i found out is commenting out each module one by one
                    Just for future
                    • cruunnerrC Offline
                      cruunnerr @Guest
                        cruunnerr
                        pm2 log mm
                        So i set a a new installation of MM 2.1.3
                        i can’t get the calendar to show up.
                        pi@raspberrypi:~ $ pm2 log mm
                        [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
                        /home/pi/.pm2/logs/mm-error-0.log last 15 lines:
                        0|mm       | ERROR! Could not validate main module js file.
                        0|mm       | /home/pi/MagicMirror/modules/MMM-CalendarExt/MMM-CalendarExt.js:182
                        0|mm       |   addCalendars: async function() {
                        0|mm       |                       ^^^^^^^^
                        0|mm       | SyntaxError: Unexpected token function
                        0|mm       |     at Object.exports.runInThisContext (vm.js:76:16)
                        0|mm       |     at Module._compile (module.js:528:28)
                        0|mm       |     at Object.Module._extensions..js (module.js:565:10)
                        0|mm       |     at Module.load (module.js:473:32)
                        0|mm       |     at tryModuleLoad (module.js:432:12)
                        0|mm       |     at Function.Module._load (module.js:424:3)
                        0|mm       |     at Module.require (module.js:483:17)
                        0|mm       |     at require (internal/module.js:20:19)
                        0|mm       |     at Class.loadModuleDefaultConfig (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:254:17)
                        0|mm       |     at /home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:211:10
                        /home/pi/.pm2/logs/mm-out-0.log last 15 lines:
                        0|mm       | Connecting socket for: MMM-NOAA
                        0|mm       | Starting module: MMM-NOAA
                        0|mm       | Connecting socket for: MMM-MyCommute
                        0|mm       | ====================== Starting node_helper for module [MMM-MyCommute]
                        0|mm       | Connecting socket for: MMM-SystemStats
                        0|mm       | Connecting socket for: newsfeed
                        0|mm       | Starting module: newsfeed
                        0|mm       | Connecting socket for: MMM-CalendarExt
                        0|mm       | Sockets connected & modules started ...
                        0|mm       | Launching application.
                        0|mm       | Create new calendar fetcher for url: xxx - Interval: 300000
                        0|mm       | Create new calendar fetcher for url: http://i.cal.to/ical/61/nrw/feiertage/71e91ccb.83fad41c-d19fda68.ics - Interval: 300000
                        0|mm       | Create new news fetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
                        0|mm       | [RCREPO] Repository scanning...
                        0|mm       | [RCREPO] modules.json is updated.
                        pi@raspberrypi:~/MagicMirror $ npm start dev
                        > magicmirror@2.1.3 start /home/pi/MagicMirror
                        > sh run-start.sh "dev"
                        Loading config ...
                        Module helper loaded: MMM-Remote-Control
                        Module helper loaded: MMM-Remote-Control-Repository
                        Module helper loaded: MMM-PIR-Sensor
                        Module helper loaded: MMM-NOAA
                        Module helper loaded: MMM-MyCommute
                        Module helper loaded: MMM-SystemStats
                        No helper found for module: MMM-GoogleMapsTraffic.
                        You're using a full whitelist configuration to allow for all IPs
                        Server started ...
                        Connecting socket for: MMM-Remote-Control
                        Starting node helper for: MMM-Remote-Control
                        Connecting socket for: MMM-Remote-Control-Repository
                        Connecting socket for: MMM-PIR-Sensor
                        { Error: listen EADDRINUSE 0.0.0.0:8080
                            at Object.exports._errnoException (util.js:1026:11)
                            at exports._exceptionWithHostPort (util.js:1049:20)
                            at Server._listen2 (net.js:1253:14)
                            at listen (net.js:1289:10)
                            at net.js:1399:9
                            at _combinedTickCallback (internal/process/next_tick.js:77:11)
                            at process._tickCallback (internal/process/next_tick.js:98:9)
                            at Module.runMain (module.js:592:11)
                            at run (bootstrap_node.js:402:7)
                            at startup (bootstrap_node.js:157:9)
                          code: 'EADDRINUSE',
                          syscall: 'listen',
                          address: '0.0.0.0',
                          port: 8080 }
                        Any idea?
                          A Former User @cruunnerr
                          @cruunnerr
                          Async functions are not supported by Node versions older than version 7.6.
                            cruunnerr
                            @Sean
                            U think i need to do an update of node?
                            So u wanna hear a fun fact?
                            On my Mirror itself nothings shows up.
                            BUT, when i go to the MagicMirror website via browser or the MMM-RemoteControl it is right there!
                            Can anyone explain that?
                            the config i test it:
                                                    position: "bottom_bar",
        system: {
        show: ['month'],
        views: {
        month: {
        calendars :[
        url: "https://ics.fixtur.es/v2/eintracht-frankfurt.ics"
                            alt text
                              Major
                              @cruunnerr
                              I just ran an update this morning and I am having the exact problem.
                              Same error, and it works through a web browser…
                              Have you found a resolution?
                              Did updating node help? If so, how do you update it?
                              Thank you for your help,
                              Major
                              • F Offline
                                fering3 @Major
                                I’m having the same issue for the past few days.
                                Updated to the latest release of MM today hoping it would solve it somehow but no luck.
                                • F Offline
                                  fering3
                                  Quick update. I hacked around some updates to Node, npm etc, but nothing seemed to work.
                                  So I removed the async and the await from the addCalendars function so it looks something like this (file: MMM-CalendarExt.js)
                                  addCalendars: function() {
                                     var self = this
                                     for (var c in this.CurrentConfigs.calendars) {
                                       self.addCalendar(self.CurrentConfigs.getCalConfig(c))
                                       sleep(1000)
                                  Seems to work for now. But looking back through github I don’t see that these are recent additions so I don’t know why this started failing now. Hopefully somebody smarter than I will figure it out.
                                    cruunnerr
                                    Significantly Changes in the new update is the use of electron 1.4.15.
                                    I used it already before the update, but i don’t want to update (cause of the CPU trouble thing…) to check if it is the reason.
                                    but that is the only thing that comes to my mind, since you both got the problem when updating to the newest MM-Version
                                      A Former User
                                      I doubt MM has downgraded its node version of electron for some reason.
                                      Unfortunately, ‘async function’ is not working on the lower version of node. I think that is the reason for this issue.
                                      I’ll check and patch this for some time. Sorry, I should do my job first before this. Plz wait for a while.
                                      • H Offline
                                        Hein-Jan @Guest
                                        @Sean
                                        If I read this right:
                                        Changed
                                        * Calender week is now handled with a variable translation in order to move number language specific.
                                        * Reverted the Electron dependency back to 1.4.15 since newer version don’t seem to work on the Raspberry Pi very well.
                                        MM has indeed downgraded…
                                          cruunnerr
                                          yeah, its all discussed in this thread: https://forum.magicmirror.builders/topic/4684/electron-cpu-usage?page=1
                                          I had the problem, too. CPU Usage above 80%.
                                          When i downgrade to electron 1.4.15 the CPU usage went to nearly 0% !
                                          But then i went to the Problem that the CalendarExt Module only shows in an external web browser and not on the MM itself.
                                          Think we have to hope, that Sean will find a solution. :D
                                          (Or the electron Problem is gone…)
                                          • N Offline
                                            ninjabreadman @cruunnerr
                                            @cruunnerr Did you try the solution I suggested here? https://forum.magicmirror.builders/topic/6047/calendar-module-won-t-show-all-events/4
