    MMM-CalendarExt cant get the calendar to show
    23 Posts 8 Posters 16.0k Views 9 Watching
      A Former User @glitchgod
      @glitchgod
      First. All of error messages [DBX...] are not related with CalendarExt. For clearer test, disable DropboxWallpaper.(and all other modules except for CalendarExt)
      Second, npm start dev should be run on your magic mirror directory(It might be ~/MagicMirror, not ~/)
      So, Just check again.
      npm start dev
      It could show your MM and an additional window for developer console. You might find error mark (red circled X mark and numbers, if exists). In that case, move to tab Console, you could see errors.
      • G
        glitchgod
        @Sean said in MMM-CalendarExt cant get the calendar to show:
        r
        alright ran the dev mode in the proper directory
        the screen that showed up looks like the Chrome’s “F12” option
        There were no errors or issues highlighed or showing the X on them, however the calendar somewhat showed up in a weird way after i commented out everything but the calendar.
        It showed up in the bottom left with only "Tuesday /Wensday/ Thurday/ Friday " and a single calendar line.
        Picture proof
        Im still running with the Default script
          module: 'MMM-CalendarExt',
                url: "http://mlb.am/tix/mariners_schedule_full"
        SSSoo some progress
        After letting the SSH run for a few minutes an error did show up
        Starting MagicMirror: v2.1.3
        Loading config ...
        Loading module helpers ...
        Module helper loaded: MMM-CalendarExt
        All module helpers loaded.
        Server started ...
        Connecting socket for: MMM-CalendarExt
        { Error: listen EADDRINUSE 127.0.0.1:8080
            at Object.exports._errnoException (util.js:1050:11)
            at exports._exceptionWithHostPort (util.js:1073:20)
            at Server.setupListenHandle [as _listen2] (net.js:1263:14)
            at listenInCluster (net.js:1304:12)
            at doListen (net.js:1428:7)
            at GetAddrInfoReqWrap.asyncCallback [as callback] (dns.js:62:16)
            at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:78:10)
          code: 'EADDRINUSE',
          errno: 'EADDRINUSE',
          syscall: 'listen',
          address: '127.0.0.1',
          port: 8080 }
        Launching application.
        pm2 log mm
          A Former User
          Ok, we are progressed.
          Try this. And you can know what was problem. ;)
                  system: {
                    show: ['month'],
                  views: {
                    month: {
                      position:'bottom_bar',
                  calendars :[
                      url:"http://mlb.am/tix/mariners_schedule_full"
            A Former User
            Ok. I tell you the truth.
            there is no more schedule for Seatle Mariners in this month. That is why empty frame is shown.
            Try this url : https://ics.fixtur.es/v2/eintracht-frankfurt.ics
            And, Port error is not related with modules (I think)
            • G
              glitchgod
              Alright it’s up and running.
              Thank you Sean
              the steep by steep fix you have given was excellent :)
              • G
                glitchgod
                After re enabling all the modules it seems
                “MMM-ethereum”
                causes it not to show up.
                The way i found out is commenting out each module one by one
                Just for future
                • cruunnerrC
                  cruunnerr @Guest
                  • cruunnerrC
                    cruunnerr
                    pm2 log mm
                    So i set a a new installation of MM 2.1.3
                    i can’t get the calendar to show up.
                    pi@raspberrypi:~ $ pm2 log mm
                    [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
                    /home/pi/.pm2/logs/mm-error-0.log last 15 lines:
                    0|mm       | ERROR! Could not validate main module js file.
                    0|mm       | /home/pi/MagicMirror/modules/MMM-CalendarExt/MMM-CalendarExt.js:182
                    0|mm       |   addCalendars: async function() {
                    0|mm       |                       ^^^^^^^^
                    0|mm       | SyntaxError: Unexpected token function
                    0|mm       |     at Object.exports.runInThisContext (vm.js:76:16)
                    0|mm       |     at Module._compile (module.js:528:28)
                    0|mm       |     at Object.Module._extensions..js (module.js:565:10)
                    0|mm       |     at Module.load (module.js:473:32)
                    0|mm       |     at tryModuleLoad (module.js:432:12)
                    0|mm       |     at Function.Module._load (module.js:424:3)
                    0|mm       |     at Module.require (module.js:483:17)
                    0|mm       |     at require (internal/module.js:20:19)
                    0|mm       |     at Class.loadModuleDefaultConfig (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:254:17)
                    0|mm       |     at /home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:211:10
                    /home/pi/.pm2/logs/mm-out-0.log last 15 lines:
                    0|mm       | Connecting socket for: MMM-NOAA
                    0|mm       | Starting module: MMM-NOAA
                    0|mm       | Connecting socket for: MMM-MyCommute
                    0|mm       | ====================== Starting node_helper for module [MMM-MyCommute]
                    0|mm       | Connecting socket for: MMM-SystemStats
                    0|mm       | Connecting socket for: newsfeed
                    0|mm       | Starting module: newsfeed
                    0|mm       | Connecting socket for: MMM-CalendarExt
                    0|mm       | Sockets connected & modules started ...
                    0|mm       | Launching application.
                    0|mm       | Create new calendar fetcher for url: xxx - Interval: 300000
                    0|mm       | Create new calendar fetcher for url: http://i.cal.to/ical/61/nrw/feiertage/71e91ccb.83fad41c-d19fda68.ics - Interval: 300000
                    0|mm       | Create new news fetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
                    0|mm       | [RCREPO] Repository scanning...
                    0|mm       | [RCREPO] modules.json is updated.
                    pi@raspberrypi:~/MagicMirror $ npm start dev
                    > magicmirror@2.1.3 start /home/pi/MagicMirror
                    > sh run-start.sh "dev"
                    Loading config ...
                    Module helper loaded: MMM-Remote-Control
                    Module helper loaded: MMM-Remote-Control-Repository
                    Module helper loaded: MMM-PIR-Sensor
                    Module helper loaded: MMM-NOAA
                    Module helper loaded: MMM-MyCommute
                    Module helper loaded: MMM-SystemStats
                    No helper found for module: MMM-GoogleMapsTraffic.
                    You're using a full whitelist configuration to allow for all IPs
                    Server started ...
                    Connecting socket for: MMM-Remote-Control
                    Starting node helper for: MMM-Remote-Control
                    Connecting socket for: MMM-Remote-Control-Repository
                    Connecting socket for: MMM-PIR-Sensor
                    { Error: listen EADDRINUSE 0.0.0.0:8080
                        at Object.exports._errnoException (util.js:1026:11)
                        at exports._exceptionWithHostPort (util.js:1049:20)
                        at Server._listen2 (net.js:1253:14)
                        at listen (net.js:1289:10)
                        at net.js:1399:9
                        at _combinedTickCallback (internal/process/next_tick.js:77:11)
                        at process._tickCallback (internal/process/next_tick.js:98:9)
                        at Module.runMain (module.js:592:11)
                        at run (bootstrap_node.js:402:7)
                        at startup (bootstrap_node.js:157:9)
                      code: 'EADDRINUSE',
                      syscall: 'listen',
                      address: '0.0.0.0',
                      port: 8080 }
                    Any idea?
                      A Former User @cruunnerr
                      @cruunnerr
                      Async functions are not supported by Node versions older than version 7.6.
                      • cruunnerrC
                        cruunnerr
                        @Sean
                        U think i need to do an update of node?
                        So u wanna hear a fun fact?
                        On my Mirror itself nothings shows up.
                        BUT, when i go to the MagicMirror website via browser or the MMM-RemoteControl it is right there!
                        Can anyone explain that?
                        the config i test it:
                                                position: "bottom_bar",
                                                              system: {
                                                              show: ['month'],
                                                              views: {
                                                              month: {
                                                              calendars :[
                                                              url: "https://ics.fixtur.es/v2/eintracht-frankfurt.ics"
                        alt text
                          Major
                          @cruunnerr
                          I just ran an update this morning and I am having the exact problem.
                          Same error, and it works through a web browser…
                          Have you found a resolution?
                          Did updating node help? If so, how do you update it?
                          Thank you for your help,
                          Major
                          • F
                            fering3 @Major
                            I’m having the same issue for the past few days.
                            Updated to the latest release of MM today hoping it would solve it somehow but no luck.
                            • F
                              fering3
                              Quick update. I hacked around some updates to Node, npm etc, but nothing seemed to work.
                              So I removed the async and the await from the addCalendars function so it looks something like this (file: MMM-CalendarExt.js)
                              addCalendars: function() {
                                 var self = this
                                 for (var c in this.CurrentConfigs.calendars) {
                                   self.addCalendar(self.CurrentConfigs.getCalConfig(c))
                                   sleep(1000)
                              Seems to work for now. But looking back through github I don’t see that these are recent additions so I don’t know why this started failing now. Hopefully somebody smarter than I will figure it out.
                              • cruunnerrC
                                cruunnerr
                                Significantly Changes in the new update is the use of electron 1.4.15.
                                I used it already before the update, but i don’t want to update (cause of the CPU trouble thing…) to check if it is the reason.
                                but that is the only thing that comes to my mind, since you both got the problem when updating to the newest MM-Version
                                  A Former User
                                  I doubt MM has downgraded its node version of electron for some reason.
                                  Unfortunately, ‘async function’ is not working on the lower version of node. I think that is the reason for this issue.
                                  I’ll check and patch this for some time. Sorry, I should do my job first before this. Plz wait for a while.
                                  • H
                                    Hein-Jan @Guest
                                    @Sean
                                    If I read this right:
                                    Changed
                                    * Calender week is now handled with a variable translation in order to move number language specific.
                                    * Reverted the Electron dependency back to 1.4.15 since newer version don’t seem to work on the Raspberry Pi very well.
                                    MM has indeed downgraded…
                                    • cruunnerrC
                                      cruunnerr
                                      yeah, its all discussed in this thread: https://forum.magicmirror.builders/topic/4684/electron-cpu-usage?page=1
                                      I had the problem, too. CPU Usage above 80%.
                                      When i downgrade to electron 1.4.15 the CPU usage went to nearly 0% !
                                      But then i went to the Problem that the CalendarExt Module only shows in an external web browser and not on the MM itself.
                                      Think we have to hope, that Sean will find a solution. :D
                                      (Or the electron Problem is gone…)
                                      • N
                                        ninjabreadman @cruunnerr
                                        @cruunnerr Did you try the solution I suggested here? https://forum.magicmirror.builders/topic/6047/calendar-module-won-t-show-all-events/4
                                        • cruunnerrC
                                          cruunnerr
                                          Yeah i saw this and tried it. Works great :) Thank you
                                          • T
                                            Turtle
                                            Hello my name is TL and I’m very very very new. I’m just trying to get something to show up and it seems that when I start the MagicMirror that I get all the other modules but the CalendarExt module. For some odd reason I have a feeling I’m missing something rather simple. Below is a copy of my config file and my npm start dev below:.
                                             * MIT Licensed.
                                            var config = {
                                            	port: 8080,
                                            	language: "en",
                                            	timeFormat: 24,
                                            	units: "metric",
                                            			module: "alert",
                                            			module: "updatenotification",
                                            			position: "top_bar"
                                            			module: "clock",
                                            			position: "top_left"
                                            			position: "top_left", //anywhere. It is not related to real position of view
                                            			config: { // Read below
                                            			  system:{
                                            			    show: ['daily'],
                                            			    locale: '', //when omitted, default value would be your system default locale by moment.js
                                            			    showEmptyView: 1,
                                            			    fullDayEventLocalize: 1,
                                            			    redrawInterval: 30*60*1000, //minimum 60000
                                            			    useProfileConfig: 0,
                                              			    startProfile: ''
                                            			  defaultView: {
                                            			    position: 'bottom_bar',
                                            			    positionOrder: -1,
                                            			    overflowRolling: 0,
                                            			    overflowHeight: 0,
                                            			    overflowDuration: 2,
                                            			    timeFormat: 'HH:mm',
                                            			    dateFormat: "MMM Do",
                                            		    	    fullDayEventDateFormat: "MMM Do",
                                            			    ellipsis: 0,
                                            			    limit:0,
                                            			    oneLineEvent:0,
                                            			    replaceTitle:[],
                                            			    classPattern:[],
                                            			    classPatternWhere:["title"],
                                            			    symbolPattern:[],
                                            			    symbolPatternWhere:["title"]
                                            			  views: {
        month: {
                                            				showWeeks: 1,
                                            				weeksTitle: 'weeks',
                                            				weeksFormat: 'wo',
                                            				weekdayFormat: 'dd',
                                            				titleFormat : 'D',
                                            				overTitleFormat : 'MMM D',
                                            				monthTitleFormat: "MMMM",
                                            			     weeks: {
                                            				showWeeks: 1,
                                            				weeksFormat: 'wo',
                                            				titleFormat : 'MMM D',
                                            				counts: 4,
                                            			     daily: {
                                            			        direction: 'row',
                                            			        counts: 5,
                                            			        titleFormat: "D",
                                            			        overTitleFormat: "MMM D",
                                            				subtitleFormat: "ddd",
                                            			     weekly: {
                                            			        direction: 'row',
                                            			    	counts: 4,
                                            			    	titleFormat: "wo",
                                            			    	overTitleFormat: "gggg wo",
                                            			    	subtitleFormat: "MMM Do",
                                            			     monthly: {
                                            			    	direction: 'row',
                                            			    	counts: 3,
                                            			    	titleFormat: "MMMM",
                                            			    	overTitleFormat: "YYYY MMM",
                                            				subtitleFormat: "YYYY",
                                            			     current: {
                                            				title: 'Current',
                                                				useRelative: 1
                                            			     upcoming: {
                                            				title: 'Upcoming',
                                                				useRelative: 1
                                            		          defaultCalendar: {
                                            			     profiles: [],
                                            				views: [],
                                            				symbol: "",
                                            				styleName: "",
                                            				replaceTitle:[],
                                            				classPattern: [],
                                            				classPatternWhere: ["title"],
                                            				symbolPattern: [],
                                            				symbolPatternWhere: ["title"],
                                            				maxEntries:50,
                                            				maxDays:180,
                                            				interval: 1800000,
                                            			      name: "Schooldays of John",
                                            				url: "https://school.com/schedule.ics",
                                            				auth: {
                                            				user:'john',
                                            				pass:'abcd1234',
                                            				method:'bearer'
                                            			      name: "US Holiday",
                                            				url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics",
                                            				profile: ['daddy'],
                                            				views: ['month', 'upcoming'],
                                            				styleName: "style1",
                                            				symbol: 'us@fi',
                                            				maxEntries: 50,
                                            				maxDays:365,
                                            				interval: 24*60*60*1000,
                                            			  profileConfigs: {
                                            			    "Tom" : {},
                                            			module: "compliments",
                                            			position: "lower_third"
                                            			module: "currentweather",
                                            				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                                            			module: "weatherforecast",
                                            			header: "Weather Forecast",
                                            				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                                            			module: "newsfeed",
                                            				feeds: [
                                            						title: "New York Times",
                                            				showSourceTitle: true,
                                            				showPublishDate: true
                                            Here is my npm start dev:
                                            npm ERR! Error: ENOENT: no such file or directory, open '/home/pi/MagicMirror/node_modules/dev/package.json'
                                            npm ERR!     at Error (native)
                                            npm ERR! If you need help, you may report this *entire* log,
                                            npm ERR! including the npm and node versions, at:
                                            npm ERR!
                                            npm ERR! System Linux 4.9.59-v7+
                                            npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "start" "dev"
                                            npm ERR! cwd /home/pi/MagicMirror
                                            npm ERR! node -v v4.8.2
                                            npm ERR! npm -v 1.4.21
                                            npm ERR! path /home/pi/MagicMirror/node_modules/dev/package.json
                                            npm ERR! syscall open
                                            npm ERR! code ENOENT
                                            npm ERR! errno -2
                                            npm ERR!
                                            npm ERR! Additional logging details can be found in:
                                            npm ERR!     /home/pi/MagicMirror/npm-debug.log
                                            npm ERR! not ok code 0
                                            Thank you.
