    MMM-CalendarExt cant get the calendar to show
    23 Posts 8 Posters 16.2k Views 9 Watching
    • G
      glitchgod
      Alright it’s up and running.
      Thank you Sean
      the steep by steep fix you have given was excellent :)
      • G
        glitchgod
        After re enabling all the modules it seems
        “MMM-ethereum”
        causes it not to show up.
        The way i found out is commenting out each module one by one
        Just for future
        • cruunnerrC
          cruunnerr @Guest
          • cruunnerrC
            cruunnerr
            @Sean said in MMM-CalendarExt cant get the calendar to show:
            pm2 log mm
            So i set a a new installation of MM 2.1.3
            i can’t get the calendar to show up.
            pi@raspberrypi:~ $ pm2 log mm
            [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
            /home/pi/.pm2/logs/mm-error-0.log last 15 lines:
            0|mm       | ERROR! Could not validate main module js file.
            0|mm       | /home/pi/MagicMirror/modules/MMM-CalendarExt/MMM-CalendarExt.js:182
            0|mm       |   addCalendars: async function() {
            0|mm       |                       ^^^^^^^^
            0|mm       | SyntaxError: Unexpected token function
            0|mm       |     at Object.exports.runInThisContext (vm.js:76:16)
            0|mm       |     at Module._compile (module.js:528:28)
            0|mm       |     at Object.Module._extensions..js (module.js:565:10)
            0|mm       |     at Module.load (module.js:473:32)
            0|mm       |     at tryModuleLoad (module.js:432:12)
            0|mm       |     at Function.Module._load (module.js:424:3)
            0|mm       |     at Module.require (module.js:483:17)
            0|mm       |     at require (internal/module.js:20:19)
            0|mm       |     at Class.loadModuleDefaultConfig (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:254:17)
            0|mm       |     at /home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:211:10
            /home/pi/.pm2/logs/mm-out-0.log last 15 lines:
            0|mm       | Connecting socket for: MMM-NOAA
            0|mm       | Starting module: MMM-NOAA
            0|mm       | Connecting socket for: MMM-MyCommute
            0|mm       | ====================== Starting node_helper for module [MMM-MyCommute]
            0|mm       | Connecting socket for: MMM-SystemStats
            0|mm       | Connecting socket for: newsfeed
            0|mm       | Starting module: newsfeed
            0|mm       | Connecting socket for: MMM-CalendarExt
            0|mm       | Sockets connected & modules started ...
            0|mm       | Launching application.
            0|mm       | Create new calendar fetcher for url: xxx - Interval: 300000
            0|mm       | Create new calendar fetcher for url: http://i.cal.to/ical/61/nrw/feiertage/71e91ccb.83fad41c-d19fda68.ics - Interval: 300000
            0|mm       | Create new news fetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
            0|mm       | [RCREPO] Repository scanning...
            0|mm       | [RCREPO] modules.json is updated.
            pi@raspberrypi:~/MagicMirror $ npm start dev
            > magicmirror@2.1.3 start /home/pi/MagicMirror
            > sh run-start.sh "dev"
            Starting MagicMirror: v2.1.3
            Loading config ...
            Loading module helpers ...
            Module helper loaded: MMM-Remote-Control
            Module helper loaded: MMM-Remote-Control-Repository
            Module helper loaded: MMM-PIR-Sensor
            Module helper loaded: MMM-NOAA
            Module helper loaded: MMM-MyCommute
            Module helper loaded: MMM-SystemStats
            No helper found for module: MMM-GoogleMapsTraffic.
            Module helper loaded: MMM-CalendarExt
            All module helpers loaded.
            You're using a full whitelist configuration to allow for all IPs
            Server started ...
            Connecting socket for: MMM-Remote-Control
            Starting node helper for: MMM-Remote-Control
            Connecting socket for: MMM-Remote-Control-Repository
            Connecting socket for: MMM-PIR-Sensor
            { Error: listen EADDRINUSE 0.0.0.0:8080
                at Object.exports._errnoException (util.js:1026:11)
                at exports._exceptionWithHostPort (util.js:1049:20)
                at Server._listen2 (net.js:1253:14)
                at listen (net.js:1289:10)
                at net.js:1399:9
                at _combinedTickCallback (internal/process/next_tick.js:77:11)
                at process._tickCallback (internal/process/next_tick.js:98:9)
                at Module.runMain (module.js:592:11)
                at run (bootstrap_node.js:402:7)
                at startup (bootstrap_node.js:157:9)
              code: 'EADDRINUSE',
              errno: 'EADDRINUSE',
              syscall: 'listen',
              address: '0.0.0.0',
              port: 8080 }
            Any idea?
            ? 1 Reply Last reply
              A Former User @cruunnerr
              @cruunnerr
              Async functions are not supported by Node versions older than version 7.6.
              • cruunnerrC
                cruunnerr
                @Sean
                U think i need to do an update of node?
                So u wanna hear a fun fact?
                On my Mirror itself nothings shows up.
                BUT, when i go to the MagicMirror website via browser or the MMM-RemoteControl it is right there!
                Can anyone explain that?
                the config i test it:
                                        module: 'MMM-CalendarExt',
                                        position: "bottom_bar",
                                                      system: {
                                                      show: ['month'],
                                                      views: {
                                                      month: {
                                                      position:'bottom_bar',
                                                      calendars :[
                                                      url: "https://ics.fixtur.es/v2/eintracht-frankfurt.ics"
                alt text
                  Major
                  @cruunnerr
                  I just ran an update this morning and I am having the exact problem.
                  Same error, and it works through a web browser…
                  Have you found a resolution?
                  Did updating node help? If so, how do you update it?
                  Thank you for your help,
                  Major
                  F 1 Reply Last reply
                  • F
                    fering3 @Major
                    I’m having the same issue for the past few days.
                    Updated to the latest release of MM today hoping it would solve it somehow but no luck.
                    • F
                      fering3
                      Quick update. I hacked around some updates to Node, npm etc, but nothing seemed to work.
                      So I removed the async and the await from the addCalendars function so it looks something like this (file: MMM-CalendarExt.js)
                      addCalendars: function() {
                         var self = this
                         for (var c in this.CurrentConfigs.calendars) {
                           self.addCalendar(self.CurrentConfigs.getCalConfig(c))
                           sleep(1000)
                      Seems to work for now. But looking back through github I don’t see that these are recent additions so I don’t know why this started failing now. Hopefully somebody smarter than I will figure it out.
                      • cruunnerrC
                        cruunnerr
                        Significantly Changes in the new update is the use of electron 1.4.15.
                        I used it already before the update, but i don’t want to update (cause of the CPU trouble thing…) to check if it is the reason.
                        but that is the only thing that comes to my mind, since you both got the problem when updating to the newest MM-Version
                          A Former User
                          I doubt MM has downgraded its node version of electron for some reason.
                          Unfortunately, ‘async function’ is not working on the lower version of node. I think that is the reason for this issue.
                          I’ll check and patch this for some time. Sorry, I should do my job first before this. Plz wait for a while.
                          Hein-JanH 1 Reply Last reply
                          • Hein-JanH
                            Hein-Jan @Guest
                            @Sean
                            If I read this right:
                            Changed
                            * Calender week is now handled with a variable translation in order to move number language specific.
                            * Reverted the Electron dependency back to 1.4.15 since newer version don’t seem to work on the Raspberry Pi very well.
                            MM has indeed downgraded…
                            • cruunnerrC
                              cruunnerr
                              yeah, its all discussed in this thread: https://forum.magicmirror.builders/topic/4684/electron-cpu-usage?page=1
                              I had the problem, too. CPU Usage above 80%.
                              When i downgrade to electron 1.4.15 the CPU usage went to nearly 0% !
                              But then i went to the Problem that the CalendarExt Module only shows in an external web browser and not on the MM itself.
                              Think we have to hope, that Sean will find a solution. :D
                              (Or the electron Problem is gone…)
                              N 1 Reply Last reply
                              • N
                                ninjabreadman @cruunnerr
                                @cruunnerr Did you try the solution I suggested here? https://forum.magicmirror.builders/topic/6047/calendar-module-won-t-show-all-events/4
                                • cruunnerrC
                                  cruunnerr
                                  Yeah i saw this and tried it. Works great :) Thank you
                                  • T
                                    Turtle
                                    Hello my name is TL and I’m very very very new. I’m just trying to get something to show up and it seems that when I start the MagicMirror that I get all the other modules but the CalendarExt module. For some odd reason I have a feeling I’m missing something rather simple. Below is a copy of my config file and my npm start dev below:.
                                     * MIT Licensed.
                                    var config = {
                                    	port: 8080,
                                    	language: "en",
                                    	timeFormat: 24,
                                    	units: "metric",
                                    			module: "alert",
                                    			module: "updatenotification",
                                    			position: "top_bar"
                                    			module: "clock",
                                    			position: "top_left"
                                    			position: "top_left", //anywhere. It is not related to real position of view
                                    			config: { // Read below
                                    			  system:{
                                    			    show: ['daily'],
                                    			    locale: '', //when omitted, default value would be your system default locale by moment.js
                                    			    showEmptyView: 1,
                                    			    fullDayEventLocalize: 1,
                                    			    redrawInterval: 30*60*1000, //minimum 60000
                                    			    useProfileConfig: 0,
                                      			    startProfile: ''
                                    			  defaultView: {
                                    			    position: 'bottom_bar',
                                    			    positionOrder: -1,
                                    			    overflowRolling: 0,
                                    			    overflowHeight: 0,
                                    			    overflowDuration: 2,
                                    			    timeFormat: 'HH:mm',
                                    			    dateFormat: "MMM Do",
                                    		    	    fullDayEventDateFormat: "MMM Do",
                                    			    ellipsis: 0,
                                    			    limit:0,
                                    			    oneLineEvent:0,
                                    			    replaceTitle:[],
                                    			    classPattern:[],
                                    			    classPatternWhere:["title"],
                                    			    symbolPattern:[],
                                    			    symbolPatternWhere:["title"]
                                    			  views: {
        month: {
                                    				showWeeks: 1,
                                    				weeksTitle: 'weeks',
                                    				weeksFormat: 'wo',
                                    				weekdayFormat: 'dd',
                                    				titleFormat : 'D',
                                    				overTitleFormat : 'MMM D',
                                    				monthTitleFormat: "MMMM",
                                    			     weeks: {
                                    				showWeeks: 1,
                                    				weeksFormat: 'wo',
                                    				titleFormat : 'MMM D',
                                    				counts: 4,
                                    			     daily: {
                                    			        direction: 'row',
                                    			        counts: 5,
                                    			        titleFormat: "D",
                                    			        overTitleFormat: "MMM D",
                                    				subtitleFormat: "ddd",
                                    			     weekly: {
                                    			        direction: 'row',
                                    			    	counts: 4,
                                    			    	titleFormat: "wo",
                                    			    	overTitleFormat: "gggg wo",
                                    			    	subtitleFormat: "MMM Do",
                                    			     monthly: {
                                    			    	direction: 'row',
                                    			    	counts: 3,
                                    			    	titleFormat: "MMMM",
                                    			    	overTitleFormat: "YYYY MMM",
                                    				subtitleFormat: "YYYY",
                                    			     current: {
                                    				title: 'Current',
                                        				useRelative: 1
                                    			     upcoming: {
                                    				title: 'Upcoming',
                                        				useRelative: 1
                                    		          defaultCalendar: {
                                    			     profiles: [],
                                    				views: [],
                                    				symbol: "",
                                    				styleName: "",
                                    				replaceTitle:[],
                                    				classPattern: [],
                                    				classPatternWhere: ["title"],
                                    				symbolPattern: [],
                                    				symbolPatternWhere: ["title"],
                                    				maxEntries:50,
                                    				maxDays:180,
                                    				interval: 1800000,
                                    			      name: "Schooldays of John",
                                    				url: "https://school.com/schedule.ics",
                                    				auth: {
                                    				user:'john',
                                    				pass:'abcd1234',
                                    				method:'bearer'
                                    			      name: "US Holiday",
                                    				url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics",
                                    				profile: ['daddy'],
                                    				views: ['month', 'upcoming'],
                                    				styleName: "style1",
                                    				symbol: 'us@fi',
                                    				maxEntries: 50,
                                    				maxDays:365,
                                    				interval: 24*60*60*1000,
                                    			  profileConfigs: {
                                    			    "Tom" : {},
                                    			module: "compliments",
                                    			position: "lower_third"
                                    			module: "currentweather",
                                    				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                                    			module: "weatherforecast",
                                    			header: "Weather Forecast",
                                    				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                                    			module: "newsfeed",
                                    				feeds: [
                                    						title: "New York Times",
                                    				showSourceTitle: true,
                                    				showPublishDate: true
                                    Here is my npm start dev:
                                    npm ERR! Error: ENOENT: no such file or directory, open '/home/pi/MagicMirror/node_modules/dev/package.json'
                                    npm ERR!     at Error (native)
                                    npm ERR! If you need help, you may report this *entire* log,
                                    npm ERR! including the npm and node versions, at:
                                    npm ERR!
                                    npm ERR! System Linux 4.9.59-v7+
                                    npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "start" "dev"
                                    npm ERR! cwd /home/pi/MagicMirror
                                    npm ERR! node -v v4.8.2
                                    npm ERR! npm -v 1.4.21
                                    npm ERR! path /home/pi/MagicMirror/node_modules/dev/package.json
                                    npm ERR! syscall open
                                    npm ERR! code ENOENT
                                    npm ERR! errno -2
                                    npm ERR!
                                    npm ERR! Additional logging details can be found in:
                                    npm ERR!     /home/pi/MagicMirror/npm-debug.log
                                    npm ERR! not ok code 0
                                    Thank you.
