    MMM-CalendarExt cant get the calendar to show
    23 Posts 8 Posters 14.4k Views 9 Watching
    • G Offline
      glitchgod
      okay here it is
      pm2 log mm
      pi@MagicMirror:~ $ pm2 log mm --lines 1000
      [TAILING] Tailing last 1000 lines for [mm] process (change the value with --lines option)
      /home/pi/.pm2/logs/mm-error-0.log last 1000 lines:
      0|mm       |
      0|mm       | npm ERR! Linux 4.9.52-v7+
      0|mm       | npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start"
      0|mm       | npm ERR! node v6.11.4
      0|mm       | npm ERR! npm  v3.10.10
      0|mm       | npm ERR! code ELIFECYCLE
      0|mm       | npm ERR! magicmirror@2.1.3 start: `sh run-start.sh`
      0|mm       | npm ERR! Exit status 1
      0|mm       | npm ERR!
      0|mm       | npm ERR! Failed at the magicmirror@2.1.3 start script 'sh run-start.sh'.
      0|mm       | npm ERR! Make sure you have the latest version of node.js and npm installed.
      0|mm       | npm ERR! If you do, this is most likely a problem with the magicmirror package,
      0|mm       | npm ERR! not with npm itself.
      0|mm       | npm ERR! Tell the author that this fails on your system:
      0|mm       | npm ERR!     sh run-start.sh
      0|mm       | npm ERR! You can get information on how to open an issue for this project with:
      0|mm       | npm ERR!     npm bugs magicmirror
      0|mm       | npm ERR! Or if that isn't available, you can get their info via:
      0|mm       | npm ERR!     npm owner ls magicmirror
      0|mm       | npm ERR! There is likely additional logging output above.
      0|mm       |
      0|mm       | npm ERR! Please include the following file with any support request:
      0|mm       | npm ERR!     /home/pi/MagicMirror/npm-debug.log
      0|mm       | [811:1006/062246.323684:FATAL:bus.cc(1197)] D-Bus connection was disconnected. Aborting.
      0|mm       | #0 0x00000139f0c0
      0|mm       | #1 0x0000013ae0be
      0|mm       | #2 0x0000009d3172
      0|mm       |
      0|mm       | [812:1006/064303.600583:FATAL:bus.cc(1197)] D-Bus connection was disconnected. Aborting.
      0|mm       |
      0|mm       | [807:1006/065119.128269:FATAL:bus.cc(1197)] D-Bus connection was disconnected. Aborting.
      0|mm       |
      /home/pi/.pm2/logs/mm-out-0.log last 1000 lines:
      0|mm       | [DBXPIC] No scanned images in Dropbox.
      0|mm       | [DBXWLP] SCANNING: /home/
      0|mm       | [DBXWLP] SCANNING: /home/Apps/
      0|mm       | [DBXWLP] SCANNING: /home/Apps/background_pi_magicMirror
      0|mm       | [DBXWLP] SCANNING: /Apps/background_pi_magicMirror
      0|mm       | [DBXWLP] SCANNING: /background_pi_magicMirror
      0|mm       | [DBXWLP] DOWNLOAD_ERROR /background_pi_magicMirror
      and
      npm, start dev
      pi@MagicMirror:~ $ npm start dev
      npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start" "dev"
      npm ERR! code ENOENT
      npm ERR! errno -2
      npm ERR! syscall open
      npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
      npm ERR! enoent This is most likely not a problem with npm itself
      npm ERR! enoent and is related to npm not being able to find a file.
      npm ERR! enoent
      npm ERR!     /home/pi/npm-debug.log
        A Former User @glitchgod
        @glitchgod
        First. All of error messages [DBX...] are not related with CalendarExt. For clearer test, disable DropboxWallpaper.(and all other modules except for CalendarExt)
        Second, npm start dev should be run on your magic mirror directory(It might be ~/MagicMirror, not ~/)
        So, Just check again.
        npm start dev
        It could show your MM and an additional window for developer console. You might find error mark (red circled X mark and numbers, if exists). In that case, move to tab Console, you could see errors.
        • G Offline
          glitchgod
          @Sean said in MMM-CalendarExt cant get the calendar to show:
          r
          alright ran the dev mode in the proper directory
          the screen that showed up looks like the Chrome’s “F12” option
          There were no errors or issues highlighed or showing the X on them, however the calendar somewhat showed up in a weird way after i commented out everything but the calendar.
          It showed up in the bottom left with only "Tuesday /Wensday/ Thurday/ Friday " and a single calendar line.
          Picture proof
          Im still running with the Default script
            module: 'MMM-CalendarExt',
                  url: "http://mlb.am/tix/mariners_schedule_full"
          SSSoo some progress
          After letting the SSH run for a few minutes an error did show up
          Starting MagicMirror: v2.1.3
          Loading config ...
          Loading module helpers ...
          Module helper loaded: MMM-CalendarExt
          All module helpers loaded.
          Server started ...
          Connecting socket for: MMM-CalendarExt
          { Error: listen EADDRINUSE 127.0.0.1:8080
              at Object.exports._errnoException (util.js:1050:11)
              at exports._exceptionWithHostPort (util.js:1073:20)
              at Server.setupListenHandle [as _listen2] (net.js:1263:14)
              at listenInCluster (net.js:1304:12)
              at doListen (net.js:1428:7)
              at GetAddrInfoReqWrap.asyncCallback [as callback] (dns.js:62:16)
              at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:78:10)
            code: 'EADDRINUSE',
            errno: 'EADDRINUSE',
            syscall: 'listen',
            address: '127.0.0.1',
            port: 8080 }
          Launching application.
          pm2 log mm
            A Former User
            Ok, we are progressed.
            Try this. And you can know what was problem. ;)
                    system: {
                      show: ['month'],
                    views: {
                      month: {
                        position:'bottom_bar',
                    calendars :[
                        url:"http://mlb.am/tix/mariners_schedule_full"
              A Former User
              Ok. I tell you the truth.
              there is no more schedule for Seatle Mariners in this month. That is why empty frame is shown.
              Try this url : https://ics.fixtur.es/v2/eintracht-frankfurt.ics
              And, Port error is not related with modules (I think)
              • G Offline
                glitchgod
                Alright it’s up and running.
                Thank you Sean
                the steep by steep fix you have given was excellent :)
                • G Offline
                  glitchgod
                  After re enabling all the modules it seems
                  “MMM-ethereum”
                  causes it not to show up.
                  The way i found out is commenting out each module one by one
                  Just for future
                  • cruunnerrC Offline
                    cruunnerr @Guest
                      cruunnerr
                      pm2 log mm
                      So i set a a new installation of MM 2.1.3
                      i can’t get the calendar to show up.
                      pi@raspberrypi:~ $ pm2 log mm
                      [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
                      /home/pi/.pm2/logs/mm-error-0.log last 15 lines:
                      0|mm       | ERROR! Could not validate main module js file.
                      0|mm       | /home/pi/MagicMirror/modules/MMM-CalendarExt/MMM-CalendarExt.js:182
                      0|mm       |   addCalendars: async function() {
                      0|mm       |                       ^^^^^^^^
                      0|mm       | SyntaxError: Unexpected token function
                      0|mm       |     at Object.exports.runInThisContext (vm.js:76:16)
                      0|mm       |     at Module._compile (module.js:528:28)
                      0|mm       |     at Object.Module._extensions..js (module.js:565:10)
                      0|mm       |     at Module.load (module.js:473:32)
                      0|mm       |     at tryModuleLoad (module.js:432:12)
                      0|mm       |     at Function.Module._load (module.js:424:3)
                      0|mm       |     at Module.require (module.js:483:17)
                      0|mm       |     at require (internal/module.js:20:19)
                      0|mm       |     at Class.loadModuleDefaultConfig (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:254:17)
                      0|mm       |     at /home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:211:10
                      /home/pi/.pm2/logs/mm-out-0.log last 15 lines:
                      0|mm       | Connecting socket for: MMM-NOAA
                      0|mm       | Starting module: MMM-NOAA
                      0|mm       | Connecting socket for: MMM-MyCommute
                      0|mm       | ====================== Starting node_helper for module [MMM-MyCommute]
                      0|mm       | Connecting socket for: MMM-SystemStats
                      0|mm       | Connecting socket for: newsfeed
                      0|mm       | Starting module: newsfeed
                      0|mm       | Connecting socket for: MMM-CalendarExt
                      0|mm       | Sockets connected & modules started ...
                      0|mm       | Launching application.
                      0|mm       | Create new calendar fetcher for url: xxx - Interval: 300000
                      0|mm       | Create new calendar fetcher for url: http://i.cal.to/ical/61/nrw/feiertage/71e91ccb.83fad41c-d19fda68.ics - Interval: 300000
                      0|mm       | Create new news fetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
                      0|mm       | [RCREPO] Repository scanning...
                      0|mm       | [RCREPO] modules.json is updated.
                      pi@raspberrypi:~/MagicMirror $ npm start dev
                      > magicmirror@2.1.3 start /home/pi/MagicMirror
                      > sh run-start.sh "dev"
                      Loading config ...
                      Module helper loaded: MMM-Remote-Control
                      Module helper loaded: MMM-Remote-Control-Repository
                      Module helper loaded: MMM-PIR-Sensor
                      Module helper loaded: MMM-NOAA
                      Module helper loaded: MMM-MyCommute
                      Module helper loaded: MMM-SystemStats
                      No helper found for module: MMM-GoogleMapsTraffic.
                      You're using a full whitelist configuration to allow for all IPs
                      Server started ...
                      Connecting socket for: MMM-Remote-Control
                      Starting node helper for: MMM-Remote-Control
                      Connecting socket for: MMM-Remote-Control-Repository
                      Connecting socket for: MMM-PIR-Sensor
                      { Error: listen EADDRINUSE 0.0.0.0:8080
                          at Object.exports._errnoException (util.js:1026:11)
                          at exports._exceptionWithHostPort (util.js:1049:20)
                          at Server._listen2 (net.js:1253:14)
                          at listen (net.js:1289:10)
                          at net.js:1399:9
                          at _combinedTickCallback (internal/process/next_tick.js:77:11)
                          at process._tickCallback (internal/process/next_tick.js:98:9)
                          at Module.runMain (module.js:592:11)
                          at run (bootstrap_node.js:402:7)
                          at startup (bootstrap_node.js:157:9)
                        code: 'EADDRINUSE',
                        syscall: 'listen',
                        address: '0.0.0.0',
                        port: 8080 }
                      Any idea?
                        A Former User @cruunnerr
                        @cruunnerr
                        Async functions are not supported by Node versions older than version 7.6.
