Asterisk - Call log and active Call
Hello everyone,
It would be nice to a have mnodule like the one for FRITZ, but for Asterisk.
@luvien I have a pushbullet module coming up in a week (due to traveling). This gives you live phone updates for any notification and includes active incoming call notification. Hoping that would help.
+1 on this module
Hello guys!
I’m using the awesome Pushbullet module from Ronny and with a script, I can trap Asterisk events and send them to Pushbullet. I will post the script this weekend. It’s working good so far.
LJ
@luvien Thanks for the kind words! Excellent work on Asterisk - I look forward to seeing your module!
Hi Everyone!
I know this is a late chime in, but has the integration/module for asterisk been posted? I can’t seem to find it. I started my MM, and had my freepbx system push to pushbullet through the superfect module, then pull that into into MM via pushbullet. Worked quite well, but I didn’t test it thoroughly before I had to abandon the project. But hopefully I will be able to restart it soon. Would like to see other implementations.One thing that I didn’t like was not having active calls displayed (quite visibly). I have seen now there is a IFTT module, which allows info to be sent by web call to MM. A simple curl script in the incoming call processing on Asterisk could be used to send to this module as opposed to IFTTT then MM. Can’t wait to give that a try too.
@luvien What kind of call log?, This is possible do it by AMI.
