What's the difference?
@Mykle1 just do that in easypix
if (notification === 'HIDE_LUCY') { this.hide(1000); }
Mykle1 Project Sponsor Module Developerlast edited by Mykle1 Dec 25, 2017, 12:36 PM Dec 25, 2017, 12:35 PM
@strawberry-3.141 said in What’s the difference?:
Success! :-)
Now I plan to do it the right way. I’ll take another look at the DEVELOPER document and learn how to properly register my modules with MMM-voice.
Thank you!
Peace!
Is there any way to run the
bash dependencies.sh
command on a Windows machine? I see that it requires sudo, which Windows does not have, so the installation fails immediately. -
This is what I tried to get MMM-voice working under windows:
I successfully installed MMM-voice on a laptop that is running ubuntu. It works just fine there. So I copied the MMM-voice folder, the pocketsphinx folder and the sphinxbase folder from the ubuntu machine and pasted them in their respective directories on the Windows machine. I did get an “initializing” message once before getting the dreaded “ERROR” message. I triedmicrophone: 2,
(numbers 1 thru 5) but all failed.Anyway, if there is a way to install this under Windows I would really appreciate some direction. Thanks.
Peace!
@Mykle1 never tried to install it on windows, you need ti install all dependencies manually if they even exist for windows, then make sure when they get used that the path etc is correct
Ok, thanks. I’m looking into that right now
I can now use MMM-voice to hide and show any module individually or all at once . I currently have about 10 working. When I launch MM I only have one module showing. All others are hidden by design. I am quite pleased with this.
The past 2 days I’ve been trying to make the keyword put MMM-voice directly into voice mode, as I will only be using it in voice mode to hide and show modules, sort of like MMM-RemoteControl using voice. I’ve tried notifications and socketNotifications, triggered by the keyword, to send a VOICE notification to change the mode to VOICE but I am defeated. i would really appreciate some advice on how to accomplish this. Thanks
Peace!
@Mykle1 not sure if i understand there is a check if the current mode is voice if so there will be no notification sent, you need to remove that if it is what you want
Mykle1 Project Sponsor Module Developerlast edited by Mykle1 Jan 3, 2018, 10:54 PM Jan 3, 2018, 10:54 PM
I want the keyword (HELLO LUCY) to put MMM-voice directly into voice mode without having to say voice. RIght now I have to say, “HELLO LUCY VOICE”
I’m sorry that my explanation was confusing.
So, this should do that?
" there is a check if the current mode is voice if so there will be no notification sent, you need to remove that"And, thank you for your help
@Mykle1 you only have to say the mode voice once after system start it will be then allways in the voice mode if you dont exit it.
I guess by changig this to voice https://github.com/fewieden/MMM-voice/blob/master/node_helper.js#L63 you could also avoid saying it once
