    Errors trying to run MM on Pi3
    8 Posts 3 Posters 4.2k Views 2 Watching
    • E Offline
      Esinem
      Help! I’m a complete noob trying to go through the installation tutorial. https://forum.magicmirror.builders/topic/236/complete-setup-tutorial/6 but it’s complaining about node install.js I tried updating npm but still get this:
      magicmirror@2.1.3 start /home/pi/MagicMirror
      sh run-start.sh
      run-start.sh: 4: run-start.sh: electron: not found
      npm ERR! file sh
      npm ERR! code ELIFECYCLE
      npm ERR! errno ENOENT
      npm ERR! syscall spawn
      npm ERR! magicmirror@2.1.3 start: sh run-start.sh
      npm ERR! spawn ENOENT
      npm ERR!
      npm ERR! Failed at the magicmirror@2.1.3 start script.
      npm ERR! /home/pi/.npm/_logs/2018-01-01T01_22_06_331Z-debug.log
      Any suggestions in extremely plain English very welcome. Thanks and happy New Year.
      • bheplerB Offline
        bhepler Module Developer @Esinem
        @Esinem It seems that you do not have Electron installed on your Pi. If you install electron, it should overcome that error.
        First, go to your home directory: cd ~
        Then install electron: npm install electron@1.4.15
        Once that is complete, try starting the mirror again.
        Good luck!
        NOTE: This won’t work (see below). Instead cd ~/MagicMirror.
        • E Offline
          Esinem
          Thanks but it didn’t seem to work :-( I tried what you said and then continued with the steps in the tutorial but as you can see it failed. I tried running it again but more errors.
          I’m off to bang my head on a wall! :-) I’m quite prepared to believe I’m doing something idiotic as I’m a total Pi/Raspbrian/Python virgin.
          pi@raspberrypi:~ $ magicmirror@2.1.3 start /home/pi/MagicMirror
          bash: magicmirror@2.1.3: command not found
          pi@raspberrypi:~ $ cd MagicMirror/config
          pi@raspberrypi:~/MagicMirror/config $ cp config.js.sample config.js
          pi@raspberrypi:~/MagicMirror/config $ cd $HOME/MagicMirror
          sh run-start.sh
          npm ERR! file sh
          npm ERR!
          npm ERR! /home/pi/.npm/_logs/2018-01-01T17_47_18_127Z-debug.log
          pi@raspberrypi:~/MagicMirror $ cd ~
          pi@raspberrypi:~ $ npm install electron@1.4.15
          electron@1.4.15 postinstall /home/pi/node_modules/electron
          node install.js
          npm WARN saveError ENOENT: no such file or directory, open ‘/home/pi/package.json’
          npm WARN enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
          npm WARN pi No description
          npm WARN pi No repository field.
          npm WARN pi No README data
          npm WARN pi No license field.
          • electron@1.4.15
            updated 1 package in 42.487s
            pi@raspberrypi:~ $
          • strawberry 3.141S Offline
            strawberry 3.141 Project Sponsor Module Developer @Esinem
            @Esinem you installed it in /home/pi instead of /home/pi/MagicMirror
            • E Offline
              Esinem @strawberry 3.141
              @strawberry-3.141 Thanks. Isn’t that what I was told to do or am I completely misunderstanding things?
              I think I need to study some very basic tutorials before I even try to install stuff!
                @Esinem its a dependency of magicmirror so it should be installed in the magicmirror directory or globally. Try cd ~/MagicMirror and then the install command again
                • E Offline
                  Esinem
                  Aha! Many thanks. We seem to be getting somewhere now but not out of the woods yet. MM loads, which is a result, and I get a black screen with a little drop-down with options like full screen, properties, session info but no data displayed. Something flashed up fast as it loaded which I think indicated it couldn’t find something. Helper module? I’m not sure it’s relevant as I see some modules don’t have helper files
                  I had errors relating to electron@1.17.10 so tried installing that but no change.
                  Here’s my screen: https://photos.app.goo.gl/4Qbew2OasrjvqhWH2 Doh! Just figured out the drop down is to do with VNC not MM.
                  I ran dev and I can see the line with config.js is highlighted. It tested without syntax errors. I appreciate sample stuff needs localising but should the clone of the sample show something or do I need to make any changes to display anything?
                  • E Offline
                    Esinem @Esinem
                    Hurrah!! I found a post dated 3 days ago by Lange which solved it:
                    npm install --unsafe-perm
                    Thanks for your input.
