    Custom.css
    10 Posts 4 Posters 7.1k Views 3 Watching
    • KirAsh4K Offline
      KirAsh4 Moderator
      You don’t need a monitor on the pi to see the console. Any browser, anywhere, that can access the pi, can see the HTML output. In Chrome, hit 'F12' to open the console. At the top, make sure 'Elements' is selected. Now twiddle down the little arrows on the left, starting with the BODY tag. As you hover over the ones that just popped up, it highlights in the browser. 'region top bar' is where the calendar lives, twiddle that open. Hover over the 'region top left, center, right' and you can figure out where to go from there …
      • bscaranoB Offline
        bscarano
        Not to Hijack the thread, but is there a way to change the color on just specific calendars if I have more than one in the module?
        MichMichM 1 Reply Last reply Reply Quote 0
        • MichMichM Offline
          MichMich @bscarano
          @bscarano It’s not officially supported, but every module instance get’s it’s own id. If you take a look at the generated html, you’s see something like: id="module_2_calendar". This means you can use the following css:
          #module_2_calendar td {
            color: #ff0000;
          But please note: since this isn’t an official feature, I can’t give any support on this, nor do I promise it will keep working in the future.
          • bscaranoB Offline
            bscarano
            Maybe what’s I’m asking isn’t possible.
            I have the calendar module that pulls from 2 different calendars (main and FB birthdays. Both display together. What I’d like to do is show one calendar in one color and the other in another one.
            Is this possible to do or am I asking too much?
            Brendon
            • MichMichM Offline
              MichMich
              I have two calendars in one calendar module as well. I use different icons for both calendar.
              With this in mind, you could do some fancy css like:
              tr:has(.fa-icon1) td .bright{
                 color: red;
              tr:has(.fa-icon2) td .bright{
                 color: green;
              I did not try it out, but It might work.
