    [MMM-Skolmaten] Shows school lunch menus in Sweden from skolmaten.se
    19 Posts 7 Posters 11.0k Views 7 Watching
    • E Offline
      erq
      Hi!
      I have looked a long time for a module like this but I cannot get it to work.
      The module just says Laddar… (Loading…) bot no matter how long I wait I dont see anything else than that.
      I have tried both with my kids school and also your example.
      Please advise what to do next?
      • H Offline
        Henrik
        I get the same problem. @retroflex, this is the output log, may help if you want to fix the issue:
        TypeError: Parser.parseURL is not a function
            at Class.loadFeed (C:\Users\henri\MagicMirror\modules\MMM-Skolmaten\node_helper.js:44:10)
            at Class.socketNotificationReceived (C:\Users\henri\MagicMirror\modules\MMM-Skolmaten\node_helper.js:31:9)
            at Socket. (C:\Users\henri\MagicMirror\modules\node_modules\node_helper\index.js:113:11)
            at emitTwo (events.js:106:13)
            at Socket.emit (events.js:191:7)
            at C:\Users\henri\MagicMirror\node_modules\socket.io\lib\socket.js:513:12
            at _combinedTickCallback (internal/process/next_tick.js:67:7)
            at process._tickCallback (internal/process/next_tick.js:98:9)
          retroflex Project Sponsor Module Developer @Henrik
          @Henrik Thanks for the log. I’m not sure when I get the chance to look at it. I’ll try to reinstall from github on my mirror and see if I can reproduce when I get the time.
          If anyone wants to give it a go, just go ahead…
          • E Offline
            erq
            I get the same output log.
            • H Offline
              Henrik @retroflex
              @retroflex Sure, if you add me to the repo I’ll have a look. Github username is HenrikL6.
                @Henrik said in [MMM-Skolmaten] Shows school lunch menus in Sweden from skolmaten.se:
                Added you as a collaborator to the repo. I’m new to git so let me know if there’s anything else I must do. Follow up question: is it better to be a collaborator than to send pull requests? Or maybe just easier?
                H 1 Reply Last reply Reply Quote 1
                  @Henrik I had a quick look now and the exception seems to indicate that Parser cannot be found. Perhaps rss-parser package isn’t properly installed. Just to make sure: did you run “npm install” in the MMM-Skolmaten folder? Can you check if rss-parser is installed on your mirror?
                  • E Offline
                    erq
                    Yes, I did a npm install in the folder and yes, it seems that the parser is installed. I have a folder named ~/MagicMirror/modules/MMM-Skolmaten/node_modules/rss-parser with this content:
                    .npmignore
                    .travis.yml
                    LICENSE
                    README.md
                    bower.json
                    browser.js
                    dist/
                    index.js
                    lib/
                    package-lock.json
                    package.json
                    scripts/
                    test/
                    Thanks for looking in to it!
                    P R 2 Replies Last reply Reply Quote 1
                      Pertan @erq
                      @erq Do a “npm install rss-parser@2.12.0” inside MMM-Skolmat folder and it will work.
                        Jacco7702
                        Yes that did it. I had the same problem. I guess the dependency to rss-parser is hard coded to a specific version or that the latest works diffrent than this one
