    Powering my mirror?
    45 Posts 6 Posters 37.6k Views 4 Watching
    • T Offline
      The Bean
      I’m actually not sure what to check for watt consumption. I’m only seeing volt and amp.
      cruunnerrC 1 Reply Last reply Reply Quote 0
        MadScientist
        You could use something like this:
        alt text
        alt text
        You plug in the wall outlet and then you plug the power supply into this device. It will show you voltage, amperage, wattage, etc. They are very cheap. I think I paid for mine around 5€ 5 years ago.
        Or, if you know how much ampere is used at a known voltage, you can easily calculate the wattage by multiplying amere A with voltage V, e.g. 3A at 12V would result in 36W.
        • T Offline
          The Bean @MadScientist
          @MadScientist ok so you example is exactly the specs for my display. And from what I’ve seen RasPi3’s won’t reach 4 watts. So any psu over 40 should work, correct?
            MadScientist @The Bean
            @The-Bean
            They say the power supply should be able to do 20-30% more than what you need. So better aim for 45W. Something like this should do. Just check Amazon or eBay in your local country. They are usually very cheap and do the job just fine. I use 2 of those (30W) to drive LEDs for years now.
            • cruunnerrC Offline
              cruunnerr @The Bean
              @The-Bean said in Powering my mirror?:
              W = V * A (Watt = Volts * Ampere)
                doubleT Module Developer
                I put a hole in the drywall and made a neat little sunk in box with outlets for power (with a PIR for the monitor) and usb (for the pi 24/7) – no visible cables – but I know sometimes that’s not possible.
                My plan b was a cable that I’d sleeve really nice so it doesn’t look too bad that goes to small cable box where the cable is split and connected with a plug for the monitor (or in your case the psu) and a converter with a usb plug. Just be careful when working with electricity. I learned a painful lesson on that when I built my Mirror.
                • T Offline
                  @MadScientist probably an ignorant question. But will that still work if split between the step down to a 5v, as well as the 12v controller board?
                    @The-Bean
                    In my case the RaPi takes less than 0.4A with very short peaks just above that. So the consumption is around 2-2.5W incl. keyboard and mouse. Add this to your screen consumption and add 20-30% on top of that. So 45W is the minimum, 50W and above should be the better choice. But it also depends how long the screen will be on. If it’s just for a couple of minutes every hour or so, 45W will do.
                    The 12V/3A of your screen, are they measured values, or are they from your manual? What screen are you using?
                    • T Offline
                      @MadScientist it is the recommended power for the controller board https://rover.ebay.com/rover/0/e11400.m1842.l5919/7?euid=5138ba89bae64ecd98354e79c15592eb&bu=44095069551&loc=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fvod%3Ftransid%3D1755030964001%26itemid%3D112175476566%26qu%3D2&sojTags=bu=bu
                      It’s an old laptop screen.
                        MadScientist
                        I can’t open that link because it links to your personal order details.
                        Edit: If it’s a universal LCD controller board (like the V29, V56, or V59), then it also depends what LCD panel you’re using? Can you give me the panel number? Should be a sticker on the back of it. I’ll have a look at the datasheet.
                        • 1 / 5
