    Trafficmaps
    63 Posts 11 Posters 91.2k Views 12 Watching
    • T
      tyho
      Woow nice writing! Thnx for the motivating words :) i’ll keep trying to make things work.
      • K
        KirAsh4 Moderator
        Just as an example, while I don’t necessarily know yet what I want to do with buttons, I still wanted to integrate one with my mirror. And I don’t particularly like to use a tactile toggle or momentary switch (although I still might later), so instead I opted to use a touch sensor and get that working. So what does it do right now? It started with it simply displaying random messages whenever touched:
                        messages: [
                                "That tickles!",
                                "Stop that!",
                                "Was it as good for you as it was for me?",
                                "Stop touching me!",
                                "HEY!",
                                "Did that feel good?",
                                "Are you having fun yet?",
                                "Don't forget to wash your finger later ...",
                                "Must you keep touching me?",
                                "Can't a Sensor get some rest around here?",
                                "I need touch pad sanitizer.",
                                "Are you done yet?",
        (yes, I realize those are kinda funny)
        Then I reconfigured it so that when touched, it fades away all the modules so I end up with nothing being displayed, and when I want things back, I just touch it again.
        The next step was reconfiguring it so that it triggered the HDMI output and turn it off or on, however I quickly abandoned that because my monitor, when it loses the HDMI signal, will turn to a bright blue background instead of going black. And since it doesn’t support HDMI CEC commands, I’m stuck. I reverted back to turning off the modules instead.
        My point here is, that this was a slow and calculated build up of that specific part: the touch sensor:
        1. Connect it and see if it responds how I expect it to
        2. Get it to do something, display a random message
        3. Reconfigure it to turn off all the modules
        4. Reconfigure it to power down HDMI - oh, that works but produces an undesirable result, go back to #3
        Now that I have that figured out, I can focus on something else that may or may not incorporate the touch sensor. I made sure the sensor works first, and it works as expected, no fuss, no errors, nothing.
        S T 2 Replies Last reply
          shgmongohh @KirAsh4
          @KirAsh4
          Hi do you have a Homepage or Tutorial where I can learn and train to programming?
          K 1 Reply Last reply
          • T
            tyho @KirAsh4
            @KirAsh4
            Yea the buttons would be nice to switch between maps.
            But the thing is i can’t even display a map of the JS api of google: https://maps.googleapis.com/maps/api/js
            There is also an static map api from google that just display’s an image of the map. This should be easier to push to a module. But i want the traffic functionallity that only is possible in the JS api…
            I don’t know if the google JS api allows to get requests from a node module.
            (my first 3 pages of google are already purple ^^)
            • K
              KirAsh4 Moderator @shgmongohh
              @shgmongohh, I do not. However, Google is your friend. W3Schools is another.
              • K
                KirAsh4 Moderator @tyho
                @tyho, there is a huge difference on how you use the Google Maps API to display a map in a browser, compared to how it needs to be done within the core module system of MagicMirror. MagicMirror isn’t simply a browser that displays HTML or JS … it processes the information fed to it, and that information needs to be in a very specific format to be processed successfully. This is why my recommendation to you was to try and understand the core system first, before you try to integrate something as complex as any of the Google APIs, not just the maps one.
                • T
                  tyho
                  in basics i untherstand the concept of node.js. It’s not like a website where you can load a page from a server. node js is basicly the server that creates and push the website when requested.
                  I will have to learn some more i guess ^^ I always want to go the fast way :P
                  • T
                    tyho
                    I have to give up on this one. I found topics where people said its really hard to call the google maps js api in nodejs environment. Even just only displaying a map. That explains why there are no codes of others available to learn from.
                    I think i just go for the static map (image) url from the google api. But that won’t be a trafficmap couse that’s not possible.
                    @KirAsh4 Thanks for your motivating words and help. I will expand my notification module for the voicecontrol module from alexyak96, that is working very well!. Maybe i come back later on this one when i got more knowledge or if someone else made a basic map module that i can expand for traffic ^^.
                    • MichMichM
                      MichMich
                      More importantly, It’s not just a Node.js environment. It’s a frontend framework that does most of the UI work for you.
                      T 1 Reply Last reply
                      • T
                        tyho @MichMich
                        @MichMich yea i noticed that. But it’s still too hard for me to implent a simple javascript like google maps js api. The js code is simple to untherstand but i still need the node-modules that are used by it. And it’s still not as straight forward because node is server sided. I got the idea but not the knowledge.
                        • T
                          tyho
                          Does anybody know what modules i have to use to get the maps js api working? Angular? Async? Express? Or somerhing like a google api module?
                          MichMichM 1 Reply Last reply
                          • MichMichM
                            MichMich @tyho
                            @tyho you don’t need no modules. The only thing that is important is that you fully understand the MagicMirror framework. As told, the best way to learn this, is by start building a real simple module.
                            • K
                              KirAsh4 Moderator
                              You could also look at what’s already been done, such as https://github.com/moshen/node-googlemaps …
                              • T
                                tyho
                                @KirAsh4 i’ve seen that one ;) but i don’t know where to start. That module uses some different dependeties that are already in magicmirror. As suggested by @MichMich i should first build a simple module. (Well i’ve build one already that works very well but i don’t know if thats the right way of writing code and if it’s fail proof). Anyway i will keep try some stuff. I die got a map on my mirror with static map. But i want this trafficlayer. So i need to use the javascript api.
                                On the mirror i can already see what i have to wear, where i have to go (appointments), and what happend in the world before i go. Wouldn’t it be cool if we can display traffic info and map before we leave to work. :D
                                • T
                                  tyho
                                  anyone who want to show a google staticmap on there mirror. Here is the code:
                                  /* global Module */
                                  /* Magic Mirror
                                   * Module: staticmap
                                  Module.register("staticmap",{
                                  	defaults: {
                                  		center: "new york",
                                  		zoom: 14,
                                  		mapwidth: 600,
                                  		mapheight: 500,
                                  		highway: "on",
                                  		arterial: "on",
                                  		local: "on"
                                  start: function(){
                                  	Log.info('Starting module: ' + this.name);
                                  	getDom: function() {
                                  		var img = document.createElement("img");
                                  		img.src = "https://maps.googleapis.com/maps/api/staticmap?center=" + this.config.center +
                                  		"&zoom=" + this.config.zoom +
                                  		"&size=" + this.config.mapwidth + "x" + this.config.mapheight +
                                  		"&maptype=roadmap" +
                                  		"&style=feature:road.highway|visibility:" + this.config.highway +
                                  		"&style=feature:road.arterial|visibility:" + this.config.arterial +
                                  		"&style=feature:road.local|visibility:" + this.config.local +
                                  		"&style=feature:road|invert_lightness:true|saturation:-100|weight:1|lightness:1" +
                                  		"&style=feature:administrative|invert_lightness:true|saturation:-100|weight:1|lightness:1|visibility:on" +
                                  		"&style=feature:poi|invert_lightness:true|weight:1|saturation:-100|lightness:1|visibility:on" +
                                  		"&style=feature:transit|invert_lightness:true|saturation:-100|lightness:1|weight:1|visibility:on" +
                                  		"&style=feature:landscape|invert_lightness:true|weight:1|saturation:-100|lightness:1|visibility:on" +
                                  		"&style=feature:water|invert_lightness:true|weight:1|saturation:-100|lightness:1|visibility:on" +
                                  		"&style=feature:road|element:labels.text.fill|lightness:100" +
                                  		"&style=feature:road|element:labels.text.stroke|lightness:-100";
                                  		img.width = this.config.mapwidth;
                                  		img.height = this.config.mapheight;
                                  		wrapper.appendChild(img);
                                  		return wrapper;
                                  • A
                                    alexyak
                                    Instead of Google, you could also use Microsoft’s Bing service to get a map with accidents:
                                    https://msdn.microsoft.com/en-us/library/hh441726
                                    https://msdn.microsoft.com/en-us/library/hh305205.aspx
                                    • T
                                      tyho
                                      Good one! i will see if i can get something working.
                                      What i try to do is:
                                      • Get a map with a route to my work.
                                      • Get traffic status along this route.
                                      • Style the maps so it’s nice visable through the mirror. (black/white maps and red lines/triangels for traffic jam.
                                      • Abillity to switch route with @alexyak voicecontrol module. (work me = to amsterdam) (work girlfriend = to utrecht)
                                      This are a few wishes. But i am happy already if i get the first two working ^^ i am not skilled at node and js at all… any help is appreciated.
                                      • T
                                        tyho
                                        ok just for the record. if i got the most simple maps js api code:
                                        <!DOCTYPE html>
                                        <html>
                                          <head>
                                            <title>Simple Map</title>
                                            <meta name="viewport" content="initial-scale=1.0">
                                            <meta charset="utf-8">
                                            <style>
                                              html, body {
                                                height: 100%;
                                                margin: 0;
                                                padding: 0;
                                              #map {
                                                height: 100%;
                                            </style>
                                          </head>
                                          <body>
                                            <div id="map"></div>
                                            <script>
                                              var map;
                                              function initMap() {
                                                map = new google.maps.Map(document.getElementById('map'), {
                                                  center: {lat: -34.397, lng: 150.644},
                                                  zoom: 8
                                            </script>
                                            <script src="https://maps.googleapis.com/maps/api/js?key=YOUR_API_KEY&callback=initMap"
                                            async defer></script>
                                          </body>
                                        </html>
                                        can i just create a module with:
                                        var x = document.getElementById("map").id;for the div?
                                        var x = document.createElement("SCRIPT");for the script tags? (w3schools said it supports async and defer)
                                        and then create 2 functions. 1 for the src api url that i can callback within the script tags and 1 for the initMap that i can callback after the scr url?
                                        Is this good thinking or is it not that simple?
                                        • T
                                          tyho
                                          i am feeling close but also so far far away ^^ ghehe
                                          Module.register("trafficmaps",{
                                          	defaults: {
                                          	start: function(){
                                          	initMap: function(){
                                          		var map;
                                                    zoom: 8
                                          		var mapdiv = document.getElementById("map");
                                          		wrapper.appendChild(mapdiv);
                                          		var maps = document.createElement('script');
                                          		maps.type = 'text/javascript'; maps.async = true; maps.defer = true;
                                          		maps.src="https://maps.googleapis.com/maps/api/js?key=YOUR_API_KEY&callback=" + this.initMap;
                                          		wrapper.appendChild(maps);
                                          		return wrapper;
                                          This script hangs… and it prevents other modules loading…
                                          • T
                                            tyho
                                            I am also trying the bing option seperately but also no result. I’ll keep trying. I am wondering why there arn’t any scripts on the web yet. I think this is for there experts among us ^^
                                            • 1 / 4
