    Monthly Calendar
    43 Posts 24 Posters 59.3k Views 24 Watching
      Mar
      hahaha the Sunday thing was driving me nuts. Had to disable it for now. But this is excellent work! Thanks for sharing.
        jbeck615
        @KirAsh4 calendar worked flawlessly and thank you for posting… curious if there was a way to reduce the space between the columns of numbers? im not programmer at all just FYI but figured out mm through trial and error… wish i used this forum beforehand!
        J 1 Reply Last reply
          jbeck615 @jbeck615
          @jbeck615 i figured it out the width thing through another person who posted it today.
            McSorley
            Great module. Thank you.
            I am looking for some help with the css. I am looking to change the entire table to a maximum width rather than the 100% of the “top_left” that I have it at just now. I am also looking for the weekends to have a background color of #606060
            Any help would be appreciated.
            KimzerK 1 Reply Last reply
            • Sandy2503S
              Sandy2503
              Is there a bug or is there a problem with my pi and the mirror ?
              I have my mirror running 2 weeks without a restart of my pi and yesterday i see that your modul shows may 31st and not june 3rd.
              After a reboot of my pi your calendar shows the 3rd june …
              My Mirror and all other modules are up to date.
              Does anyone else have this problem too ???
              Sandy2503
              zdenekZ 1 Reply Last reply
              • zdenekZ
                zdenek @Sandy2503
                @Sandy2503 I’ve the same issue. I had to restart MM.
                Zdeněk
                R 1 Reply Last reply
                  rmrustem @zdenek
                  @zdenek @Sandy2503 noticed that too. I’ve filed an issue to the module rep and suggested a fix. @KirAsh4 please take a look.
                  https://github.com/KirAsh4/calendar_monthly/issues/2
                  • KimzerK
                    Kimzer @McSorley
                    @McSorley said in Monthly Calendar:
                    Did you figure this out? Also interested in it :)
                    M 1 Reply Last reply
                      McSorley @Kimzer
                      @Kimzer said in Monthly Calendar:
                      Being working on getting MMM-voice working recently. I’ll certainly come back to it though and let you know.
                      @Kimzer I have been working on the custom.css for the monthly_calendar but it wasn’t a success. I used MMM-remote to hide what I had in the same position (top_left) and once they were hidden the calendar went down to a size that I was comfortable with. When I show it again, the size increases again. This is specific to showing the the default calendar because adding the timer has an ok width.
                      Looks like its going to be changing the source CSS rather the custom CSS for monthly_calendar. The work continues…
                      • N
                        nitram
                        Hi, I’m having trouble setting this module up. I want Monday, rather than Sunday, to be the first day of the week, but can’t work out where to specify that. Can anyone point me in the right direction? Cheers.
                        P 1 Reply Last reply
                          pjkoeleman @nitram
                          @nitram That is done depending on your country / language settings in the config.js file.
                          For me I use language : ‘nl’, the calendar starts on Monday. When I use ‘us’ as language it starts on Sunday.
                          N 1 Reply Last reply
                          • N
                            nitram @pjkoeleman
                            @pjkoeleman Many thanks! and thanks for the speedy reply too. That set me on the right track - I am in the UK, so I thought the default setting of language: “en” would have been fine. Just in case anyone else ever gets stuck like I did, switching that to “en-GB” fixed it.
                              palmaren
                              Is it possible somehow to add week numbers to the monthly calendar? If so, how?
                                pjkoeleman @palmaren
                                @palmaren The monthly Calendar has no option for week numbers. When you want that option ask the creator of the module.
                                The default Clock module has the option showWeek, when set to ‘true’ is shows the actual week number under the clock.
                                  palmaren @pjkoeleman
                                  @pjkoeleman Thank you
                                    mirrX
                                    Is this module still working? I´ve set up a new system and the MM gives me an error and can´t start with this module. I have uploaded in the correct dir and also set up the config file correctly. But it won´t work.
                                      pjkoeleman @mirrX
                                      @mirrX said in Monthly Calendar:
                                      Mine is, so have a look at your config and check for errors
                                      • slametpsS
                                        slametps
                                        Mine is also with bug. It is not working well for new month. The calendar not showing nor highlight the 1st date. So, I must restart MM to make it works.
                                        regards,
                                        Slamet PS
                                        • N
                                          Novais
                                          Having an issue displaying the calendar. Got the config set properly as far as i can tell just using the defaults and i have confirmed the config doesn’t contain any errors but the monthly calendar wont display, MM does start up with the other modules.
                                            Jonae @slametps
                                            @slametps i have the same issue, calendar not refreshing at month start. no fix jet?
                                            BKeyportB 1 Reply Last reply
                                            • 2 / 3
